3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Mar 2, 2021 at 11:31 PM
    #4481
    Logisticz
    Logisticz Well-Known Member
    Tustin, CA
    2016 TRD Sport 4x4 Blazing Blue Pearl
    I just went with DDM Tuning in Huntington Beach, CA. 55w 5500k HID kit
  2. Mar 2, 2021 at 11:36 PM
    #4482
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    No reputable company would recommend a 55w HID kit.
  3. Mar 2, 2021 at 11:39 PM
    #4483
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Morimoto low beam testing complete. Will knock out the high beam tomorrow and post results shortly. Of course the brand new neighbors had to come out and stare at me like WTF is that guy doing. Sigh.
  4. Mar 2, 2021 at 11:40 PM
    #4484
    Logisticz
    Tustin, CA
    Still running fine after 1 year!
  5. Mar 2, 2021 at 11:56 PM
    #4485
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Your only getting a minor bump in output vs increased power as the majority of the extra power is going to waste heat in cooking your bulbs. Bulb life will be seriously diminished. The color temp will be wrong, overdriving bulbs causes them to run warmer than spec. There is no such thing as a "55w HID" they are just selling you a 35w HID capsule with a cheap China ballast overdriving the bulbs causing reduced bulb life while also burning your expensive OEM assemblies. That and the illegal levels of glare caused to oncoming drivers, despite running in a projector housing, because cheap China rebased halogen HIDs. Every reputable company would steer you away from that garbage. Any company willing to sell that either doesn't care about their customers, or has no idea what they are doing.
    xxTacocaTxx, TacoFergie and ryanvar42 like this.
  6. Mar 2, 2021 at 11:56 PM
    #4486
    Logisticz
    Tustin, CA
    eh, im selling the truck anyways lol
  7. Mar 3, 2021 at 12:19 AM
    #4487
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    @daveeasa posted some combined output specs. But, if you live in an area where snow is a serious concern, I'd favor the H9 mod over OEM LED. OEM LED will not clear snow. Yes the OEM LED is better performing, but having your headlights effectively fail due to weather conditions should be a non-starter for your safety if you live in an environment where that is a factor.
    Canadian Caber and xxTacocaTxx like this.
  8. Mar 3, 2021 at 5:14 AM
    #4488
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    HB is ghetto
    snowtaco2 likes this.
  9. Mar 3, 2021 at 5:15 AM
    #4489
    cop414
    cop414 Well-Known Member
    Tim
    Central PA
    2022 Blue Crush DCSB Sport
    Good to know sir, thank you.
  10. Mar 3, 2021 at 6:39 AM
    #4490
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    To add to this for future reference on whatever replacement vehicle you get. 50w ballasts over drive the bulb creating more UV ray output, which is the reason for "burnt" bowls. Even high quality HID specific projectors WILL burn, sometimes as soon as 1 year, most don't last more than 2 years. Once the lining of the bowl is burnt the light output is heavily decreased since you have no reflective surface anymore, you have to replace the projector or the whole headlight. What makes it worse is that the majority of HID bulbs made to replace an H series (h11, h9, h4, etc) do not hav a UV protective coating which further increase the degradation of the projector, even with a 35w ballast.
    xxTacocaTxx likes this.
  11. Mar 3, 2021 at 6:48 AM
    #4491
    TacoFergie
    Iowa
    davidstacoma likes this.
  12. Mar 3, 2021 at 6:54 AM
    #4492
    tclavell
    Troy
    Phoenix, AZ
    G70
    TacoFergie[QUOTED] likes this.
  13. Mar 3, 2021 at 7:22 AM
    #4493
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Not to contradict crash in any way, but, I don’t believe we have any documented cases of OEM LED getting covered with snow as we do with various LED fog lights.
    It is possible that lens shape plays some role here. I’d imagine vehicle speed does as well. It will be an interesting topic to track.
  14. Mar 3, 2021 at 9:07 AM
    #4494
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    FWIW I have hikaris and live in Alaska. In my experience Headlight snow only comes up off the road mixed with dirt, not from falling snow. I park in a heated garage every night. But I still make a point to clean my headlights frequently. On long road trips gas station stops include cleaning headlights as well, mostly dirt and slush. I have yet to drive longer that 120 miles in snow conditions yet but I will let everyone know if I do.
  15. Mar 3, 2021 at 1:36 PM
    #4495
    YDCtaco
    YDCtaco Well-Known Member
    Alexandria, VA
    2016 DCSB TRD OR 4x4-Auto
    longtime follower of this thread. reporting on a solid 2+ years of the phillips h9!
    But i do ponder if LED retrofits will ever be able to produce a bulb/package that will actually work in halogen projector efficiently
    grogorat, davidstacoma and 907rx7 like this.
  16. Mar 3, 2021 at 1:40 PM
    #4496
    RoostrC0gburn
    RoostrC0gburn Well-Known Member
    Oregon
    2017 Super White DCLB TRD Sport 4x4
  17. Mar 3, 2021 at 2:19 PM
    #4497
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Unsure specifically about OEM LED, but OEM halogen lights running LEDs yes, below. Not all snow will collect on the headlights, if the snow is very dry to where it doesn't stick to the truck it isn't much of an issue. The headlight shape is less prone to buildup than the fogs which are basically snow collecting buckets. But wet sticky snow that collects on other parts of the vehicle will collect on the headlights as well.
  18. Mar 3, 2021 at 2:21 PM
    #4498
    daveeasa
    David
    PNW
    I stand corrected. Though a better test in this situation would be one H11 LED and one H9 so we can see the delta. We assume the H9 would fully clear the lens but it'd be great to confirm that experimentally.
    That's rather impressive buildup indeed.
  19. Mar 3, 2021 at 2:26 PM
    #4499
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I don't have pics on hand, but I have seen pics where halogens on a 3rd Gen have cleared the area immediately in front of the projector maintaining output while the rest of the headlight was covered in snow.
    daveeasa[QUOTED] likes this.
  20. Mar 3, 2021 at 2:28 PM
    #4500
    TacoFergie
    Iowa
