3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Mar 3, 2021 at 4:49 PM
    #4501
    DawgLover
    DawgLover Well-Known Member
    Jordan
    McDonough, GA
    2020 Cement SR5 DCSB
    Leather, TRD cat-back performance exhaust, Predator side steps, black overlays, 4R TRD Pro wheels, Nitto Terra Grappler G2s 265/70/17, TRD Pro shift knob, bed mat, Diamondback SE, TRD Pro grille, OV Tune, interior LEDs
    This feels like Christmas Eve... the hours just before Crash’s review.
  2. Mar 3, 2021 at 6:41 PM
    #4502
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    LOL. I’ll finish the high beam testing tonight, full review post will likely be the following day though.
    Ilove2dubb, Canadian Caber and 907rx7 like this.
  3. Mar 3, 2021 at 6:56 PM
    #4503
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    always look forward to seeing his results...
    crashnburn80[OP] likes this.
  4. Mar 4, 2021 at 1:43 PM
    #4504
    bacon_st
    bacon_st Well-Known Member
    San Diego
    16' Taco TRD sport
    hey @crashnburn80 , when we turn on headlights, highbeams, and the rest, who powers them? Is it the battery or the alternator? Does the battery provide any power to the lights too?
    I know alternator has varying rpms depending upon the load, so is there a minimum Amps the alternator always put out when the lights are ON?
  5. Mar 4, 2021 at 1:45 PM
    #4505
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Depends if the motor is on or not...
    bacon_st[QUOTED] likes this.
  6. Mar 4, 2021 at 1:46 PM
    #4506
    bacon_st
    San Diego
    16' Taco TRD sport
    I forgot. You're right. Lets assume the case of motor is ON.
  7. Mar 4, 2021 at 1:47 PM
    #4507
    ryanvar42
    None
    Then it is the alternator. The battery is basically just to get it all started.
  8. Mar 4, 2021 at 1:50 PM
    #4508
    bacon_st
    San Diego
    16' Taco TRD sport
    Do the varying RPM of the result in variation in the lights intensity? For example, I know Alternators have a Hot Idle RPM and then there's a MAX RPM. At Max RPM the tow package Alternator puts out 130Amps I believe.
  9. Mar 4, 2021 at 1:52 PM
    #4509
    ryanvar42
    None
    They should not change the light intensity as that would not be safe in low RPM situations like driving slow
  10. Mar 4, 2021 at 1:57 PM
    #4510
    slowboater
    slowboater Well-Known Member
    This is an awesome thread. The OP(s) are incredibly informative. How about a simple list of 'these are what I think are the best/easiest replacements'? Maybe a table?
    After I get through the 12th review with pix etc - i still don't have a simple answer to 'what is the simplest most reasonably priced way to get better output?'.
    I'm not being snide because I fully appreciate the scientific approach. This is how it should be done!
    But, it would be really helpful to have a way to pick some lights.
    I'm not thrilled with my lights and would be happy to replace them - but this is too much data to parse in order to come to a conclusion.
    THanks for the great work!
  11. Mar 4, 2021 at 2:06 PM
    #4511
    sandiegohasthebesttacos
    sandiegohasthebesttacos Well-Known Member
    https://www.tacomaworld.com/threads...11-projector-headlights.589465/#post-19689309
  12. Mar 4, 2021 at 2:07 PM
    #4512
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    ^^ Philips H9 w bulb base mod to fit H11 low beam location. That is the cliff notes answer.
  13. Mar 4, 2021 at 2:12 PM
    #4513
    slowboater
    Thank you!
  14. Mar 4, 2021 at 2:26 PM
    #4514
    aozer
    aozer Well-Known Member
    Dallas
    2020 Tacoma TRD OR Cement
    seems like offering the truck with the OEM LEDs in cold regions would be a liability risk for toyota, wouldnt it?
    Jpalafox and whiseve like this.
  15. Mar 4, 2021 at 2:27 PM
    #4515
    Burica
    Burica Raptor Deracinator
    Texas
    Crashnburn80,
    Any chance you’ll test the halogen H11 Sylvania SilverStar Ultra? I know you don’t like them but a comparison would be interesting.
    They are easy for most people to get at an auto parts store.
    I like the results of mine compared to the stock halogens in a 2020 TRD OR. The forward throw and side throw is significant. And they are white enough to look “modern.”
  16. Mar 4, 2021 at 2:43 PM
    #4516
    this has happened twice now this week but Amazon shipped me 9006 instead of h9. I've called in to Amazon both times so they can double check their stock. I'm ordering ANOTHER set tonight and see if they can get it right on the third try.
  17. Mar 4, 2021 at 3:36 PM
    #4517
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Halogen light output will vary some with voltage intensity, the voltage does fluctuate while driving depending on battery charge and load. It is typically highest right after startup to replenish the battery charge that was used to start the engine. You can see my alternator charge + AGM battery thread here which has my plotted alternator output readings over time:
    https://www.tacomaworld.com/threads/the-northstar-agm-battery-voltage-booster-upgrade.604478/
    I don't plan on it, but if someone wants to send/lend me a set I'll add them.
    xxTacocaTxx likes this.
  18. Mar 4, 2021 at 6:44 PM
    #4518
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Not any more than any other company offering a compliant LED headlight. I don't beleive there has been any updated SAE language or nhtsa reports on the need for heated lenses. Unfortunately there may not be an impetus for that until there have been a sufficient number of deaths attributed to frozen over headlights. And realistically that number should be fairly small - even halogen headlamps can freeze over if the weather is sufficiently bad, they just have the advantage of utilizing what is otherwise waste energy to keep their lenses clear.
    daveeasa likes this.
  19. Mar 4, 2021 at 9:59 PM
    #4519
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    This is interesting news to me. I briefly ran a set of retrofitted projector headlights in my Corvette. Because the headlamp circuit runs on 55w bulbs to operate correctly, the HID kit had to be 55w. Of course, this meant if the battery was not fully charged (like sitting 2-3 days was enough to drain the system) your headlights didn't work until you drove the car for 20-30 minutes. If you went to shut the lights off you'd run into having to use the high beams to get the lamps to pop down.
    I always figured it was BS components, but I didn't realize quite how bad they were. Those issues I've mentioned happened with any of the generic PnP kits people ran. I ditched the projectors because there was too much slop in the pop-up assembly causing the cutoff line to dazzle, but had I know this then, I'd have never spent the money. After seeing how crummy 95% of the LED bulbs are, I've gone with the less awesome version of the HIR bulb by Vosla, but it's hilarious getting into arguments with the old guys over there about why an LED bulb is a dumb idea.
    Taco2021LB and xxTacocaTxx like this.
  20. Mar 4, 2021 at 10:45 PM
    #4520
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    55w HID bulbs needed to operate correctly? Did this have to do with the up/down mechanism? There is no reason why a 35w kit in that instance wouldn't work from a light function standpoint, there also should be no reason to need to drive for 20-30min for your lights to work.
