3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Apr 26, 2021 at 2:53 PM
    #4741
    Steve Armstrong
    Steve Armstrong Well-Known Member
    SoCal
    2021 TRD Sport DCSB
    Good stuff! :thumbsup:
  2. Apr 26, 2021 at 5:48 PM
    #4742
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    I know this is a headlight thread, but I still wish they made an inexpensive replacement bulb for the weak foglight bulbs in my 19 Limited.
  3. Apr 26, 2021 at 6:43 PM
    #4743
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Swap halogen assembly’s with a TRD truck to get a huge boost in output with H11 based TRD fogs. Lots of performance options there. Otherwise swap to SAE LED fogs (see the SAE thread), Diode Dynamics are some of the best and will outperform the halogen options.
  4. Apr 28, 2021 at 4:41 PM
    #4744
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Thought one of my Philips H9s blew today. As I'm removing the dust cap, I'm smelling sometime burnt. This is one of those adapters I bought from Amazon.
    907rx7 likes this.
  5. Apr 28, 2021 at 5:25 PM
    #4745
    tclavell
    Troy
    Phoenix, AZ
    G70
  6. Apr 28, 2021 at 11:07 PM
    #4746
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Was that the adapter linked in the thread? I've not tested them but added the link based on others recommendations. If so, I'll remove it in lieu of something better as that is completely unacceptable for one of my threads.
  7. Apr 29, 2021 at 1:12 AM
    #4747
    replica9000
    2019 T4R ORP
    This is the set I ordered:
    https://www.amazon.com/dp/B00TXRWOPA/ref=cm_sw_r_cp_awdb_imm_NJNTEQDTPDAKWPQ5PYJF?_encoding=UTF8
    I bought them 18 months ago, and the 4Runner low beams are sealed behind a dust cover, so i know moisture didn't cause this :notsure:
  8. Apr 29, 2021 at 1:14 AM
    #4748
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    907rx7 and replica9000[QUOTED] like this.
  9. Apr 29, 2021 at 2:30 AM
    #4749
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Is there data on the current draw for the high beam on the OEM LED headlights? I saw the low beam was 2.34A at 13.8V, but didn't see any data on the high beam.
  10. Apr 29, 2021 at 4:46 AM
    #4750
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    +1 on this. I had a similar experience.
    replica9000[QUOTED] likes this.
  11. Apr 29, 2021 at 6:01 AM
    #4751
    Aws123
    Aws123 Well-Known Member
    Adam
    Colorado
    2019 tacoma trd off road
  12. Apr 29, 2021 at 6:15 AM
    #4752
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I have bags of these from various sources. I can post more photos of them. They aren’t something I am happy with myself. OEM quality feels different to my hands and eyes.
    The h9 female connectors I like best (Aptiv aka Delphi aka Metripack) I cannot seem to find sockets (terminals) for. I will keep trying. I also can’t seem to find OEM connectors which are an exact match. That would make me happiest.
    I’m not certain that it is easy to depin the OEM females but since the male connectors are cheap, easy to find, and seal well with the OEM females, and since they would be farther from the heat source, there isn’t a great argument to doing the extra work vs a short extension harness.
    The key to the whole thing is finding a good female.
    73C839B6-2803-4898-92C7-793EE2305AB1.jpg 01CEBAC9-EAF3-4CD3-A363-8958FC299E27.jpg F050E56C-1672-47D5-BF90-11E6EFE06A35.jpg
    OEM connectors for visual comparison
    A2C4008F-4919-4FA2-912C-5EE4BB52A40E.jpg A523A2D9-019E-49EB-92E6-C7321940D168.jpg 5CB55835-0471-48E7-81DE-58E062BCF87A.jpg
    907rx7 and tclavell like this.
  13. Apr 29, 2021 at 7:25 AM
    #4753
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    I just cut the stock plastic on the H11 bulb plug. I guess one could get an oem h9 plug to replace the h11 plug.
    The adaptors of Amazon were total junk.
  14. Apr 29, 2021 at 7:48 AM
    #4754
    klavender1
    klavender1 Well-Known Member
    Columbia/Lugoff, South Carolina
    2005 GX 470
    I have a sharp flush cut wire cutter. Snipped the tab inside the H9 very cleanly and just plugged into the factory tab. Much simpler than using adapters.
    atc250r likes this.
  15. Apr 29, 2021 at 8:01 AM
    #4755
    Aws123
    Adam
    Colorado
    If you get the oem male h9 connectors it comes with no wire. So then if you break the factory h11 connector depinning it, it won't be a big deal. Then you can just snap in the new h9 connector. I can get you an oem part number from our parts guys but they probably will be on the pricey side.
    I've done this several times on customer cars and it's like new again. Sometimes connectors get smashed in a wreck and the wires are fine.. Depinning can be tricky, but it's not bad once you do a few of them. You just need a mini flathead screwdriver.
  16. Apr 29, 2021 at 8:06 AM
    #4756
    daveeasa
    David
    PNW
    If you can get a bunch at reasonable prices and some socket terminals (or identify the manufacturer’s part numbers for connector and sockets) that would help out the community as I could build them into an extension harness. I have no inside connections with parts departments and am having no luck finding OEM quality from the usual vendors.
    I wouldn’t expect someone who finds an H9 bulb base mod difficult to feel comfortable depinning an OEM connector. Hence the harness as a plug and play option.
  17. Apr 29, 2021 at 8:27 AM
    #4757
    Aws123
    Adam
    Colorado
    82824-04060 is the oem h9 connector. $30 though. Pretty crazy lol. That's with no wire though. Better off just modding the bulb.
  18. Apr 29, 2021 at 8:34 AM
    #4758
    daveeasa
    David
    PNW
    The part number alone might get me over the hump. Thanks for that. Research continues.
    Aws123[QUOTED] likes this.
  19. Apr 29, 2021 at 8:44 AM
    #4759
    Aws123
    Adam
    Colorado
    No problem. You could contact a mobile wire repair and diagnostic company. We sublet some work out to them for certain things we don't want to mess with in the shop. They usually have a stock of connectors and whatnot. They may have another source.
  20. Apr 29, 2021 at 9:18 AM
    #4760
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The latest Philips LED with top-mount circuitry came in from the UK yesterday. The cross section is thicker than I hoped for, but still the thinnest out of the mainstream brands trying to build a compliant product.
    xxTacocaTxx, a2lowvw, 907rx7 and 4 others like this.
