3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. May 6, 2021 at 12:13 PM
    #4801
    MrMccrackin
    MrMccrackin Well-Known Member
    Gilbert, AZ
    2004 TRDOR PreRunner, 2017 MGM TRDOR 4x4
    Did not want this to get lost!
    can I assume that would be $10 shipped?
  2. May 6, 2021 at 12:15 PM
    #4802
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Yes, exactly. That hopefully allows me to get out of the red on the deal within a year which seems reasonable. First class in a padded envelope with tracking. I’ll post a link to the BST thread once I receive them.
  3. May 6, 2021 at 6:29 PM
    #4803
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Added a few more notes to the Philips LED review. Also of interest, those units had integrated drivers like the latest Hikaris. Driver technology must have significantly improved recently or substantially benefitted from being fan cooled to offset the performance penalty of being mounted on the LED. Might have to go back and give the latest Hikaris another look.
    tclavell likes this.
  4. May 6, 2021 at 9:17 PM
    #4804
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I assume led bulbs as turn signals are as bad as any other led in reflectors?
  5. May 6, 2021 at 9:50 PM
    #4805
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Depends on the bulb design and the design of the signal assembly, so there isn’t a one size fits all answer. Scatter isn’t an issue like a low beam or fog, since signals are more flood like. But visibility can be a concern, LEDs do not provide uniform output like an incandescent, so visibility might be good from one angle but possibly not others. And in direct daylight sometimes they can appear dimmer than stock since the assembly isn’t fully uniformly lit to the same level. Some companies will try to compensate by boosting output to extreme levels, but then just end up with blinding signals at night, so that isn’t good either.
    Signals are also difficult with the hyper flash issues. Sometimes you can replace the flasher module with one designed for lower power draw LEDs, but often the solution is to add resisters. Resisters waste energy by turning it into heat by getting hot, and effectively will often burn themselves out. So you don’t end up reducing power usage and introduce failure prone resisters. You’ve then lost the LED advantage of both lower power draw and improved reliability. Which then begs the question, why? The OEM signals should last 8+ years easy, so there isn’t a good longevity argument either. IMO LED retrofit bulbs in the signals are more trouble than they are worth, with no advantage. Compared to a brake light application for example where faster LED illumination response might buy that extra critical split second savings in communication to the vehicle behind you without having to deal with resisters and hyper flash, though the earlier comments on light uniformity still apply.
    daveeasa likes this.
  6. May 6, 2021 at 10:42 PM
    #4806
    viruszzz94
    viruszzz94 Active Member
    That will be nice.
    About the philips test. Where does the hotspot locate? Is it near the cut off like the halogen? If lower, how much lower than the halogen?
  7. May 6, 2021 at 10:47 PM
    #4807
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It is lower than a halogen. I should have taken a pic of the peak intensity location. What I really need to do for better quantitative data is setup the 42’ test and try the 3 leading replacement LEDs and note the hot spot drop distance from the cut off line.
  8. May 6, 2021 at 11:13 PM
    #4808
    daveeasa
    David
    PNW
    I can think of one other fun thing to test at 42' :)
  9. May 6, 2021 at 11:17 PM
    #4809
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Just one? ;)
    What are, the latest 2nd Gen Morimoto LED assemblies? For $900.
    Arriving tomorrow.
    But! You likely meant those other assemblies in the boxes in my garage. :)
  10. May 6, 2021 at 11:23 PM
    #4810
    daveeasa
    David
    PNW
    Yep, you got me. The 2nd gen is far more interesting to Tacoma owners. I'm curious on that one too, will they pull a Phillips out of their hat or fall on their face like the bartender when she crushed a pint glass all over my wife tonight? You just gotta wonder, there's no sure bet these days...
    crashnburn80[OP] likes this.
  11. May 7, 2021 at 9:11 AM
    #4811
    MrMccrackin
    Gilbert, AZ
    going to check on my Amazon adapters and pop off my plastic covers this morning!
    daveeasa[QUOTED] likes this.
  12. May 7, 2021 at 9:31 AM
    #4812
    MrMccrackin
    Gilbert, AZ
    well that was stupid easy.
    Amazon adapters looked ok, the green plastic caps pop right off, including across the garage.
  13. May 7, 2021 at 9:33 AM
    #4813
    MrMccrackin
    Gilbert, AZ
    Thinking about this, it makes perfect sense.
    Mass production of a single connector for multiple bulb types.
    Insert specific cap for specified bulb type.
    Toy_Runner and daveeasa like this.
  14. May 7, 2021 at 9:40 AM
    #4814
    daveeasa
    David
    PNW
    The theory on melted plastic is a loose connection due to poor socket quality/fit. Leading to increased resistance over time as wires jiggle. Creating an increase in heat due to increased resistance which then causes melting. I don’t believe the 55w to 65w difference between H9 and H11 plays any role.
    My initial focus was on securing small quantities of high quality H9 connectors. I found some I like very much which are affordable but the terminal is special order and 4000 minimum quantity.
    This plan is better if indeed the connectors I sourced are a clean match. That’s the lone remaining question. I will test figment on my truck to know for sure, both a center swap and a de-pin / re-pin.
  15. May 7, 2021 at 10:05 AM
    #4815
    MrMccrackin
    Gilbert, AZ
    4000 seems excessive :rofl:
  16. May 7, 2021 at 2:55 PM
    #4816
    MrMccrackin
    Gilbert, AZ
    so if the connectors don’t pan out, it doesn’t seem to difficult to modify the green connector to work with the H9.
  17. May 7, 2021 at 2:57 PM
    #4817
    daveeasa
    David
    PNW
    You should be 100% a-ok with no inner plastic part. I suppose you could cut it with a knife but I don't think that has a ton of purpose.
    MrMccrackin[QUOTED] likes this.
  18. May 7, 2021 at 5:58 PM
    #4818
    xxTacocaTxx
    xxTacocaTxx Well Unknown Member
    Best Slope CO
    2017 TRD OR DCLB 4x4 OMGWTFLOLBBQ
    RCI skid plates Mobtown sliders Lots of patches and MESO stuff
    I have no comment about the front turn signals, but I have the @MESO total tail stage 2 kit for the rear blinkers and brake lights, and it has worked great. Super bright, and as an added bonus, it relocates the turn signal to where the reverse lights are, and uses amber LEDs. Check out the video at the link if that doesn't make sense. It shows stock and modified blinkers.
    No clue why Toyota switched to having red blinkers on the third gen after using amber for the first and second gen.
  19. May 7, 2021 at 7:43 PM
    #4819
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    That is confusing. Most typically it is American brands that use red signals. Amber is the more appropriate and safer color choice for a signal.
  20. May 7, 2021 at 7:55 PM
    #4820
    Loan Wolve
    Loan Wolve ‘18 DCSB OR 4x4
    San Diego
    Cement ‘18 OR 4x4
    It honestly drives me bonkers. I chucked out the cash for the Meso Total Tails to convert mine to yellow.
