3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Jun 3, 2021 at 12:12 PM
    #4881
    BadDogMax
    BadDogMax Well-Known Member
    IdahoLand
    2019 TRD Pro
    I’m at 1.5 years still going
  2. Jun 13, 2021 at 6:06 PM
    #4882
    shark56
    shark56 Well-Known Member
    Question for the folks that have done the H9 upgrade.
    Are you having any issues with other vehicles flashing you because of the brighter light?
    One thing I dislike on my wife's Rav4 Limited with LED's is the constant flashing by on coming vehicles.
    I'm hesitant for that reason to upgrade to LED's on my Tacoma.
  3. Jun 13, 2021 at 8:07 PM
    #4883
    blaklabl
    blaklabl Well-Known Member
    Eric
    Cave Creek, AZ
    2021 Cement TRD Off Road
    Nope, no issues with H9 swap.
  4. Jun 13, 2021 at 8:22 PM
    #4884
    Aws123
    Aws123 Well-Known Member
    Adam
    Colorado
    2019 tacoma trd off road
    Is your wifes Rav4 running factory led headlights or aftermarket bulbs? Even factory LED headlamps have legal levels of glare and uplight, but they are still around that 6000k color which is much harsher on the human eye than your typical halogens. Thats most likely why your getting flashed.
    Been running the philips H9 in the low beams for over a year now and no issues. Its the same beam pattern as your stock H11 bulb. Just about twice as bright though. Your beam pattern will change when you drop in LED bulbs..some worse than others.
  5. Jun 14, 2021 at 9:24 AM
    #4885
    shark56
    Thanks for the confirmation.
    The Rav4 is the Limited with OEM Led's. On some of the Rav forums the Led's and getting "flashed" seemed to be an issue.
    I'm going to swap the bulbs in my OR and see how I like them. I really don't do a lot of night driving anymore but would like a little more light.
    Aws123 likes this.
  6. Jun 14, 2021 at 2:49 PM
    #4886
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    xxTacocaTxx and Loan Wolve like this.
  7. Jun 17, 2021 at 1:53 AM
    #4887
    Sasquatchian
    Sasquatchian Well-Known Member
    If you're having issues with being flashed, more than likely you need to have your headlights professionally aimed - y'know - with a beamsetter alignment device if you can find someone who has one and knows how to use it. When I had the stock lights in my Tacoma, I tried all the legal options including H9 and all the high performance H11 halogens on the market and was never flashed once, but my lights were properly aligned - and the Taco's headlights are higher off the ground than the RAV4's, too. When I upgraded to the 2020 Tacoma LED's, once they were properly aligned there's never been a flash. Not that being flashed or not being flashed is indicative of anything really. I mean, if you get flashed by someone in their 911, it's because they're so low they're looking straight into the dazzle. Not much you can do about that.
  8. Jun 22, 2021 at 11:57 PM
    #4888
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Missed it a short while back, but this thread has crossed over 500,000+ views.
    atc250r, xxTacocaTxx, DWD484 and 10 others like this.
  9. Jun 23, 2021 at 5:42 AM
    #4889
    johnnyroid
    johnnyroid Well-Known Member
    Vine Grove (Fort Knox) Kentucky
    2017 Black Tacoma Sport TRD
    And is probably the most actually informative thread on here. Wealth of knowledge and lots of traffic driven here from elsewhere.
  10. Jul 7, 2021 at 1:18 PM
    #4890
    Chris33
    Chris33 Active Member
    2021 Cement Tacoma TRD Off-road
    I’m somewhat new on here and the information is probably somewhere in here but what is an easy upgrade to make the 2020 OR headlights brighter/whiter without breaking the bank?
  11. Jul 7, 2021 at 1:27 PM
    #4891
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Buy 2-4 of these, take off the green plastic piece from your low beam connector use the same H9 bulb for high and low beams.
  12. Jul 7, 2021 at 1:44 PM
    #4892
    Chris33
    Thanks
  13. Jul 7, 2021 at 2:53 PM
    #4893
    WTH_SR5
    WTH_SR5 Well-Known Member
    2017 Silver Sky Tacoma SR5 4X2
    Do they have to be phillips H9's ?
  14. Jul 7, 2021 at 2:55 PM
    #4894
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    No, but Philips H9s are tested to be the highest performing. The Hella H9s are decent too.
    daveeasa and tclavell like this.
  15. Jul 7, 2021 at 3:08 PM
    #4895
    WTH_SR5
    Ok... Do I need daveeasa's connectors?
  16. Jul 7, 2021 at 3:17 PM
    #4896
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You can use dapters, pull the plastic green insert from the OEM connector and run without or swap in the yellow ones, or trim the plastic internal bulb tab with a small knife.
  17. Jul 7, 2021 at 3:24 PM
    #4897
    blaklabl
    Eric
    Cave Creek, AZ
    FWIW, I use Dave's connectors with the Hella H9 bulbs, and am very happy with them. I wanted the OEM LED headlights, but at $1500 aftermarket I just couldn't justify it for as little as I drive at night. The H9's give a nice upgrade, and the Hella's are a little bit whiter than the Phillips.
    tclavell likes this.
  18. Jul 7, 2021 at 6:28 PM
    #4898
    daveeasa
    David
    PNW
    And the Phillips are dirt cheap so they win on both price and performance. If you are looking for a zero effort no-brainer swap, it's the obvious choice.
    I run Phillips H9 in the minivan. I don't have overflowing love for them, tbh. At the price paid, though, I have zero complaints.
  19. Jul 12, 2021 at 11:33 PM
    #4899
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  20. Jul 22, 2021 at 4:57 PM
    #4900
    tclavell
    Troy
    Phoenix, AZ
    G70
