3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Mar 2, 2019 at 1:09 PM
    #521
    dampainter
    dampainter Member
    2016trd sport dclb
    nothing yet
    i am cornfused on what to get and will be better for me to just ask: i have a new to me 2016 trd sport dclb 6 cyl. i would like to change out the front low/high beams and fog lights and light up the nite better than the stocks without blinding others. brand, part # if i need or harness?
    from what i see it looks like hella h9 for high beams. ge+130 for low, is this right?? and no harnesses needed? fog lights are ???
  2. Mar 2, 2019 at 1:27 PM
    #522
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    High Beam: Hella Osram Hyper H9s
    Low Beam: Hella Osram Hyper H9 (if you don't mind trimming the plastic internal tab on the bulb) or GE +130 for plug and play
    Fogs: GE +130
    For the low beam the Hellas will provide a bit more of a higher intensity fuller pattern where as the GEs will be more center focused for distance projection. Hot spot intensity is similar. The GEs are a little whiter at 3500k in color then the Hellas are 3200k. Both are outstanding options and you cannot go wrong either way.
    Some like to color match their low beams and fogs, meaning:
    Low: GE+130, Fog: GE +130
    or
    Low: Hella Osram Hyper H9, Fog: Volsa H11 +120: https://store.candlepower.com/voh111sbrli.html
    The Volsa's are not as bright as the GEs or Hellas, but they are the best plug and play option to color match the Hellas.
  3. Mar 2, 2019 at 1:32 PM
    #523
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    So far, the LEDs in my 4Runner don't seem that bad. I won't argue that their not optional in halogen protectors. When another car with factory LEDs is beside me on the highway, they don't appear to be illuminating anything further away than I am. :notsure:
  4. Mar 2, 2019 at 1:52 PM
    #524
    dampainter
    dampainter Member
    2016trd sport dclb
    nothing yet
    crashnburn80 , thank you!! printing info and ordering soon.
    crashnburn80[OP] likes this.
  5. Mar 2, 2019 at 2:08 PM
    #525
    dampainter
    dampainter Member
    2016trd sport dclb
    nothing yet
    can`t find hella osram hyper H9`s
  6. Mar 2, 2019 at 2:33 PM
    #526
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    gurneyeagle likes this.
  7. Mar 2, 2019 at 2:37 PM
    #527
    Sirpopeington
    Sirpopeington Well-Known Member
    17' TRD Off-road 4x4
    Is the light output of the blue coated hella h9’s still superior to stock h11’s?
  8. Mar 2, 2019 at 2:47 PM
    #528
    dampainter
    dampainter Member
    2016trd sport dclb
    nothing yet
  9. Mar 2, 2019 at 2:51 PM
    #529
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Should be, since the H9 puts out much higher output. But the blue coated ones will not match the output of the clear ones, and the coated ones will have shorter life.
    No, these are the H11 GEs:
    https://www.powerbulbs.com/us/product/ge-megalight-ultra-h11-twin
  10. Mar 2, 2019 at 3:01 PM
    #530
    Sirpopeington
    I was going to ask you in the other thread you were helping me with but I low key didn’t want to annoy you with my constant headlight questions lol.
  11. Mar 2, 2019 at 5:31 PM
    #531
    dampainter
    dampainter Member
    2016trd sport dclb
    nothing yet
    crashnburn80 could not have done it without u man thanks alot!! just finished ordering.
  12. Mar 2, 2019 at 5:36 PM
    #532
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Great write-up @crashnburn80. For the past 3 years I've wondered what the heck causes the "bounce," which became much more pronounced once I installed my HID lights. Seeing that the projectors themself may be loose seems like the only logical explanation, considering the bulbs are clearly secured and have no play between them and the housing (at least in my case.) I guess this gives them that much more of a reason to pull the OEM housings apart and drop in a worthy replacement projector with high beam capability.
    perkj and crashnburn80[OP] like this.
  13. Mar 2, 2019 at 11:33 PM
    #533
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Are those the Amazon ones?
  14. Mar 3, 2019 at 7:13 AM
    #534
    johnnyroid
    johnnyroid Well-Known Member
    Vine Grove (Fort Knox) Kentucky
    2017 Black Tacoma Sport TRD
    Ditto!
  15. Mar 5, 2019 at 8:50 AM
    #535
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    This is a great post and my deepest appreciation to the OP for all the work he’s put into it. I read through most of the first post but ran out of time and will have to revisit. In the mean time can someone just break it down and basically let me know before I head out for my first long trip, if you had to go to the auto parts store and buy a replacement bulb, which would be a good choice for a 2019 Taco?
    Thanks in advance...
  16. Mar 5, 2019 at 9:00 AM
    #536
    Edgar
    Edgar Well-Known Member
    San Diego
    2018 TRD OR 2wd DCSB MGM
    The best would be to order these
    https://www.rallylights.com/hl78178-h9-12v-65w-xenon-bulb.html
    As for what you find in an auto parts store I don’t know
    Dryfly24[QUOTED] likes this.
  17. Mar 5, 2019 at 9:05 AM
    #537
    Raistlen0
    Raistlen0 Well-Known Member
    PA
    2017 TRD Sport DCLB AT QS
    Those for your high and lows and the GE's for the fogs.
  18. Mar 5, 2019 at 9:43 AM
    #538
    ANTupLIFE
    ANTupLIFE Well-Known Member
    Anthony
    Chester, VA
    '16 TRD Sport 4x4 DCLB SW
    If it were my preference, Sylvania Ultras. They are better performance wise than the ZXE.
  19. Mar 5, 2019 at 9:53 AM
    #539
    Dryfly24
    George
    NM
  20. Mar 5, 2019 at 11:42 AM
    #540
    Raistlen0
    PA
