3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Nov 26, 2021 at 7:51 PM
    #5441
    Spike Spiegel
    Spike Spiegel Well-Known Member
    2019 Super White Toyota 4Runner TRD Off-road Premium
    Eibach Pro Truck Lift, JBA High Caster UCA’s, Falken Wildpeak 275/70/17, Spidertrax Spacers
    I'm wondering if it has to do with the 4Runner bumper design getting hit near the middle portion causing it to reflect light. I'll have to test this theory with a black fabric later.
    Maybe @Diode Dynamics has some insight?
  2. Nov 26, 2021 at 8:39 PM
    #5442
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Is that just a OEM halogen to OEM led swap?
  3. Nov 27, 2021 at 12:07 AM
    #5443
    Spike Spiegel
    For headlight housings, yes.
    NMTrailRider[QUOTED] likes this.
  4. Nov 27, 2021 at 12:49 AM
    #5444
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Spaceship artifacts are 100% courtesy of Toyota.
  5. Nov 28, 2021 at 8:22 AM
    #5445
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    @crashnburn80 Just looking through the recommendations in post 2 and I couldn't help but notice Amazon says that all but the Phillips are unavailable. Do you have any updated recommendations or links? Specifically for the GE links.
  6. Nov 28, 2021 at 8:39 AM
    #5446
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Thanks for pointing that out, those GE bulbs are now sold under the Tungsram label. I need to update those links.
    Tungsram H11-55NHP/BP2 Nighthawk Platinum Automotive Bulb, 2-pack https://www.amazon.com/dp/B08B8Y259H
    Tungsram Megalight Ultra +130 H11 Brighter Headlamp Bulbs (Twin Pack) https://www.amazon.com/dp/B08BK5TC5M
  7. Nov 28, 2021 at 2:12 PM
    #5447
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Did my first night drive the other night in about 11 months and the Hikari Ultras worked great. That's all, and nothing else to compare them to.
  8. Nov 29, 2021 at 4:13 AM
    #5448
    sporin
    sporin Well-Known Member
    Dave
    Vermont USA
    '21 Tacoma TRD-Offroad
    Just wanted to add that I did the H9 Philips upgrade on my low beams and it's definitely an improvement thank you VERY much for the recommendation. It's not "great" but it takes what I thought was a borderline dangerous stock light to a reasonably acceptable level. I got the yellow connector inserts from daveeasa so no trimming or anything, very simple.
    I leased this one but my next rig will be a keeper and it MUST have the OEM light package, no doubt about it.
  9. Nov 29, 2021 at 4:09 PM
    #5449
    RedWings44
    Michigan
    Please do! Just ordered a set of these and the Phillips H9 bulbs. Looking forward to seeing how the compare to my stock halogens I normally run in the winter as well as my LEDs.
  10. Dec 2, 2021 at 6:11 AM
    #5450
    sporin
    Dave
    Vermont USA
    I'll tell you what, now that I've got a few nights of driving under my belt, I think I've stumbled on a big problem... my OEM headlights are aimed way too low. Like they feel like they are pointed at the ground about 30 feet in front of the truck.
    The new H9s are throwing more light for sure but it just isn't going any farther because of the poor aiming. I'll have to address that this weekend.
    Has anyone else noticed this?
  11. Dec 2, 2021 at 6:22 AM
    #5451
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
  12. Dec 2, 2021 at 7:14 AM
    #5452
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It’s been commented a few times in this thread that the OEM halogen lights are aimed too low from the factory.
    grogorat and sporin[QUOTED] like this.
  13. Dec 2, 2021 at 8:53 AM
    #5453
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Before you do any re-aiming, make sure your bulbs are fully / correctly seated. If you haven't re-aimed your headlights or haven't had any collision work done, the factory aim is pretty accurate.
  14. Dec 2, 2021 at 8:57 AM
    #5454
    klavender1
    klavender1 Well-Known Member
    Columbia/Lugoff, South Carolina
    2005 GX 470
    Try aiming old SilveRAYdo headlights! :rofl:
    Since they're only held in place by 2 metal pins, they jiggle around while driving.
  15. Dec 2, 2021 at 9:04 AM
    #5455
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Good to check the bulbs, though much harder to improperly seat in 3rd Gen. 2nd Gens didn’t seem to have an aiming issue, but several 3rd Gen owners have reported low aim from the factory in this thread. I don’t have a 3rd Gen so I can’t provide my own data, or validate that claim. But I wouldn’t place it out of the realm of possibilities based on what others have reported.
    Too Stroked[QUOTED] likes this.
  16. Dec 2, 2021 at 9:19 AM
    #5456
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
  17. Dec 2, 2021 at 10:43 AM
    #5457
    sporin
    Dave
    Vermont USA
    Good advice but I am 100% sure they are seated properly as I just put in the new bulbs very carefully. Plus both sides are aimed at the same level.
    I'm confident they are too long right now, I did another search and found a couple of other people mentioning it so it can happen. Maybe it just wasn't as noticeable with the weak-ass OEM H11's but now that the H9s are throwing more light it's pretty clear the cutoff is WAY too close out front of me.
  18. Dec 2, 2021 at 2:03 PM
    #5458
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    yup. Here’s my aiming instructions
    https://www.tacomaworld.com/threads...ector-headlights.589465/page-93#post-21977215
    sporin[QUOTED] likes this.
  19. Dec 2, 2021 at 3:35 PM
    #5459
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Must be a GM thing. The play in the pop-up assemblies on my C5 is hilarious. I had a set of bi-xenon HID retrofits in it for about a year but the assemblies bounced so much the cutoff line would practically strobe. I accidentally pulled a few people over before I ripped them out and with with HIR bulbs. I'm still sad, they were amazing but unusable.
    klavender1[QUOTED] likes this.
  20. Dec 2, 2021 at 6:52 PM
    #5460
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Any idea or thoughts on whether the vland led clones would be a better light than the alpharex version since the weak spot on those was the projectors but this one is a reflector? I'm certain the opinion will not be positive but surely there are aftermarket products that are at least as good as OEM, no? Especially when the original OEM halogens weren't even that great to begin with
    VLAND Full LED Headlights Compatible For Toyota Tacoma 2016-2019 3rd Generation N300 Pickup Truck with Clear Reflective Bowl,Plug and Play No Need Bulbs 2PCS https://www.amazon.ca/dp/B09KRNL1GX/ref=cm_sw_r_apan_glt_i_SE4VH3JS8YXWYMV5NJNQ
