3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Oct 2, 2022 at 1:22 PM
    #5861
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    Thanks for the clarification. So I only need two bulbs, for the low beams, and it is fine that they won't be white as long as they are *brighter* so I can see better at night.
    EDIT: there's SO much information here, especially in the first few posts, that it would be nice to find a Cliff's Notes edition that skips the awesome details and just gives a few recommendations in certain combinations.
  2. Oct 2, 2022 at 1:25 PM
    #5862
    smikec
    smikec Well-Known Member
    That is correct.
    To make it fit, you will need to modify the H11 plug (remove plastic), or trim the H9 bulb base to fit, or buy a conversion harness.
    The first option seems to be the easiest.
    S
  3. Oct 2, 2022 at 1:31 PM
    #5863
    NorrinRadd
    WA
    Sounds good. I was also looking at these (Tungsram Megalight Ultra (formerly GE) H11 +130) but there is so much more to read about in this thread that I will put that off for another day...or year...or two..
  4. Oct 2, 2022 at 1:47 PM
    #5864
    smikec
    post #2 achieves that goal
    it gives specific recommendations and how to install them
    there is even a hyperlink at the top of post #1 at the top that says "latest product recommendations"
    3rd Gen HID vs LED vs Halogen H11 projector headlights | Tacoma World
    I started with GE Megalight 130 as I wanted whiter - they didn't last long
    Now using Nighthawks, but are relatively expensive especially in Canada, but still not really that expensive when you consider the other wear items and gas
    H9's are dirt cheap
  5. Oct 2, 2022 at 1:56 PM
    #5865
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Just pop out the green center plastic, 3s and it's out, bulb fits right in, no need to mod anything on the base. Trim the metal tab if desired, or get the right angle and it goes in without trimming.
    Greg.Brakes.Tacos and scouterjan like this.
  6. Oct 2, 2022 at 2:00 PM
    #5866
    daveeasa
    David
    PNW
    Cliffs notes:
    1. Buy Philips H9 (rock auto may have best pricing at $6/bulb) for both low and high beam
    2. Don't stress about China vs Germany as far as country of origin
    3. Pop out center plastic on H11 or order H9's from me and de-pin/re-pin or just swap yellow plastic for green plastic
    4a. If still unsatisfied, OEM LED at a rough cost of $1200-$1600 and some labor but genuinely considered worthwhile, just not cheap and won't melt snow
    4b. Morimoto xb v2 but accept lousy build quality and no light above cutoff and beam issues in return for max output possible and their self proclaimed "badass startup sequence" which I find a total turnoff.
    4a needs a harness, 4b doesn't but will require add-a-fuse for drl, no way to turn off drl.
  7. Oct 2, 2022 at 3:12 PM
    #5867
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    You can also do the Hella High performance 2.0 H9s, about $25 for 2 on Amazon. I actually have those in the rig right now. They have a slightly whiter color but are very halogen looking and by no means all that white like an LED/HID. They are a massive improvement over the stock H11s but are the slightest bit less output than the Phillips due to the blue tinted glass. I have no regrets with them and was blown away going from the stock bulbs to the Hellas
  8. Oct 2, 2022 at 3:16 PM
    #5868
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Well snap! Somehow I thought they were in partnership with Diode Dynamics and that these might be different than the SCJ you referenced.
    Oh well, guess I’m back to drooling over OEM LEDs.
  9. Oct 2, 2022 at 4:10 PM
    #5869
    scouterjan
    scouterjan Well-Known Member
    Jan
    22 TRD OR AC in good old white
    Thanks for all great imfo, I will definitely be upgrading the bulbs in my stock OR housings
  10. Oct 2, 2022 at 5:15 PM
    #5870
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    Do you mod the bulb for the buyer? If so, I need 2!
  11. Oct 2, 2022 at 6:51 PM
    #5871
    daveeasa
    David
    PNW
    NorrinRadd likes this.
  12. Oct 3, 2022 at 10:39 PM
    #5872
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    The emitter body looks similar to Beamtech (review post #1885 here). Complete. Absolute. Pathetic. Garbage. A major safety hazard to anyone running those lights making it so they cannot adequately see the roadway in front of them at any safe distance. Those in no way whatsoever remotely replicate a halogen bulb. It isn't worth any slightest bit of your time to troubleshoot, those belong straight in the trash. It is highly unfortunate companies like that continue to exist making peoples vehicles far more dangerous to drive while falsely selling their products as a lighting upgrade.
    No, Form is a Diode Dynamics owned company that is for 'price conscious buyers'. They are relabeled Chinese imports, the same thing that TRS does with their GTR product headlight line. They will be no-where close to OEM performance, and not up to par with Morimoto.
    tektaco84 likes this.
  13. Oct 4, 2022 at 12:12 AM
    #5873
    joncure
    joncure Well-Known Member
    VA
    2021 TRD Sport Access Cab manual
  14. Oct 4, 2022 at 12:18 AM
    #5874
    joncure
    VA
    I definitely 2nd this previous post. Before finding this great thread and crashes research, I fell for the marketing ploy for beamtech LEDs. They didn’t last a week in my halogen lens. Went with the H9 upgrade and have never turned back.
  15. Oct 4, 2022 at 7:58 AM
    #5875
    62CHTS
    62CHTS Well-Known Member
    Gulf Coast, USA
    2019 Cement TRD Sport 6MT
    I agree. I was only troubleshooting to stop the flickering (basically a strobe light) until my H9s arrive....supposed to get them tomorrow. After discovering this thread, the concept of LEDs making you out-drive your lights perfectly described my impression of the low beams. Just pure foreground light. So as I said, I'm almost always using my high beams when I can. I've had my truck for a year, but don't drive too much at night so my lights have been a lower priority. But I'm looking forward to the upgrade!
  16. Oct 4, 2022 at 12:38 PM
    #5876
    avi8or_co
    Hey @crashnburn80 have you tried or tested that new version of the Hikaris yet? I think they’re called the hyperstars.
    I remember the old ones weren’t great but not horrible. Wondered if they’d be any better.
  17. Oct 4, 2022 at 12:53 PM
    #5877
    theluharlifestyle
    theluharlifestyle Well-Known Member
    Parth
    SoCal
    2019 DCSB TRD OR
    I’m curious as well. as led tech gets better I’m keeping an eye on it as a potential upgrade for the stock housing. That is until I get fed up and just upgrade to the new oem led’s lol
  18. Oct 4, 2022 at 5:59 PM
    #5878
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Intentionally no. The design is poor, it is not optically compatible with a halogen bulb. They double stacked the emitters for more output, which also means less focus and more foreground light and not replicating a halogen filament. It is a significant downgrade in design vs the Hikari Ultras.
  19. Oct 4, 2022 at 6:43 PM
    #5879
    RushT
    North Texas
    Bummer. It always annoys me when companies that make high end stuff, also make low end stuff. Some bike manufactures used to be primarily high end, but then started leveraging their brand reputation for greater volume on lower end stuff. Booooo. But I guess I could say the same thing about Land Cruiser vs Yaris. I’m just salty over $1300 for the OEM solution I’m too cheap to execute. Sub $1k seems to be my emotional barrier.
  20. Oct 4, 2022 at 6:54 PM
    #5880
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I’d rather pay more for a very high quality excellent performing part, instead of still paying a lot for something of substantially lower quality and lower performing. But yes, the price isn’t cheap, but can be had much cheaper if selecting the LED option when ordering/buying the vehicle. Obviously that isn’t helpful if you already have the truck now. Best affordable option is to watch the market place for someone “upgrading” their headlights to something else.
