3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Oct 30, 2023 at 2:19 PM
    #6481
    RetGoalie
    RetGoalie Well-Known Member
    Tom
    2023 DCSB Sport
    As a police officer for over 32 years I can tell you unless a vehicle coming at me is blinding me with some sort of auxiliary light , no one I know or knew would ever make a stop or “ investigate “ the various light setups on vehicles we see.
  2. Nov 2, 2023 at 5:28 AM
    #6482
    nl_tacoma
    nl_tacoma Well-Known Member
    Newfoundland
    2018 Tacoma TRD Sport DCLB
    Did the H11 to H9 swap yesterday using the H9 Philips standard halogen bulb that the OP and many others recommend. Huge improvement over the OEM H11 bulb. I normally drive with my fog lights on in the night for better light but didn't have to after the swap. Highly recommend this relatively cheap upgrade.
    Inserting the H9 bulb into the low beam was easy enough. No bulb tab modification needed. Just insert the larger tab on an angle first and it goes in easy enough. I also swapped out the plug's green insert for the H9 yellow insert because I had them on hand. That step probably wasn't necessary.
  3. Nov 2, 2023 at 12:03 PM
    #6483
    nl_tacoma
    Newfoundland
    My bad. I should have given @daveeasa an honorable mention and thanks for the tips on how to insert the bulb and remove the green insert. Saw a thread somewhere on here where he explains the steps with pictures.
    The amount of info in this thread is awesome. OP @crashnburn80 - you did good here. Thanks.
  4. Nov 3, 2023 at 4:09 AM
    #6484
    jetspeed
    jetspeed Well-Known Member
    MD
    19 TRD Sport DCSB 4x4 Manual Taco
    Looking to replace both my headlight AND fog lights with a simple bulb swap that will balance the light from both lights. That is, something that makes headlight and fogs appear to be the same intensity and color. Stock looking, no ultra whites/blue tint etc. Maybe something more "whiter" than stock. Plug-and-play options please?? Thanks!!
  5. Nov 3, 2023 at 1:37 PM
    #6485
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    Running fogs in weather conditions that don't require it is going to make it seem brighter and more lit in the foreground but distance wise where the H9 has a leg up on the H11 its not going to help you. If anything it's probably going to pull your focus to right in front of your hood.
  6. Nov 3, 2023 at 4:35 PM
    #6486
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    In my area, the police used to. I've been pulled over for using a secondary set of driving lights on dark back roads (GM headlamps weren't great). They also used to get people for turn signals not being amber, headlights being too blue (back when the "HID look" halogen bulbs were all the rage).
    Now, the police don't care anymore. Blinding LED bars, high beams on well-lit city streets, no lights at all, it's all ok now.
    atc250r and musicisevil like this.
  7. Nov 4, 2023 at 10:01 AM
    #6487
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I will admit; in my younger years, I thought of them as borderline harassing us poor teenagers and our cars with stupid shit added. Now that I am a little older; I wish we could go back,,, as today is complete lawlessness.
    Barsoom, atc250r, musicisevil and 2 others like this.
  8. Nov 4, 2023 at 11:15 AM
    #6488
    DuffyBank
    DuffyBank Well-Known Member
    Phillips H9 bulb swap for your headlights
    scouterjan, atc250r, grogorat and 5 others like this.
  9. Nov 6, 2023 at 5:22 PM
    #6489
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    If you are looking for matching bulbs to use in both the low beam and the fogs, first choice would be Tungsram Platinums but those are hard to come by at the moment. Second choice would be the Osram Night Breaker +200. That said, the Philips H9 swap is best for the headlights and you should only use the fogs when needed so a perfect match shouldn't be necessary.
  10. Nov 6, 2023 at 7:01 PM
    #6490
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    Precisely. Can't count the number of times I've seen people driving with their fog lights on in clear conditions. All that does is brighten the road near the truck and actually reduce your ability to see things further away.
  11. Nov 7, 2023 at 4:20 AM
    #6491
    RetGoalie
    Tom
    2023 DCSB Sport
    I have to disagree , since I installed my DD elite fog lights I’ve noticed increased visibility. Now the fogs are amber, not sure that matters. I leave for work at 5 am and we have no street lights where I am. I’ve played around with fogs off and fogs on, I definitely feel visibility has improved on my Sport with the factory halogen headlights. I will eventually try the bulb upgrade but I’m very satisfied with present set up
  12. Nov 7, 2023 at 5:01 AM
    #6492
    nl_tacoma
    Newfoundland
    You have a point. Although, normal night conditions in my area almost always includes a fog of some sort - from a light fog to a pea soup thickness. On clear nights I wouldn't run the fog lights.
    musicisevil likes this.
  13. Nov 9, 2023 at 11:59 PM
    #6493
    DuffyBank
    New pair of Philips h9 German made, $12 Canadian each at Lordco
  14. Nov 16, 2023 at 1:17 PM
    #6494
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    @crashnburn80 apologies if I glossed over the answer, but is there a clear winner in the performance/output battle between the OEM halogen headlight with H9 bulb mod vs OEM LED headlight?
    TIA
    edit: I feel like I recall it being stated that the true output was similar and that the main performance difference was surface heat production.
  15. Nov 16, 2023 at 1:25 PM
    #6495
    6MTPro
    HI -> CA
    OEM is going to our perform the H9, a halogen can only do so much but the OEM LEDs are 90X+ the cost too so you have to think about that on ROI outside of which one looks better.
  16. Nov 16, 2023 at 1:38 PM
    #6496
    backcountryj
    Jonathan
    GA
    For sure on the ROI. And yea, I do think the LEDs ‘look’ better…just couldn’t recall if there was a clear landslide style outperformance by the LED, or more of a slightly outperform scenario.
  17. Nov 16, 2023 at 3:30 PM
    #6497
    Aws123
    Aws123 Well-Known Member
    Adam
    Colorado
    2019 tacoma trd off road
  18. Nov 16, 2023 at 5:27 PM
    #6498
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  19. Nov 17, 2023 at 7:15 AM
    #6499
    BC Hunter
    My understanding is that Toyota is going all-LED on the new Tacos. It will be interesting to see how they perform in a Canadian winter. On my recent run through a snowstorm on the "Highway thru Hell" the radar got blocked about 5-10 minutes into the snow, but the headlights were fine throughout and were bare (albeit a bit dirty ) when we got to Vancouver. The snow was still on the radar unit right into the city and I had to scrape it off at the first fuel stop.
    Anyone on the thread who has a 3rd gen with LEDs have a comment on how they perform in snow?
    scouterjan and Canadian Caber like this.
  20. Nov 17, 2023 at 10:28 AM
    #6500
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    In the very specific conditions where snow adheres to the radar, it adheres to the headlights and stays there the same way.
    I almost never encounter these exact conditions from falling snow, it’s always driving in traffic and the wet stuff kicked up by the vehicle in front of me that obscures radar and lights.
    I would have a set of LED pods in driving light configuration if I had to take long trips without street lights regularly
