3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Mar 17, 2019 at 12:16 PM
    #701
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    But what about the house? It could get new lights too. :)
    https://www.tacomaworld.com/threads...lighting-using-leds-hirs-and-halogens.574930/
  2. Mar 18, 2019 at 5:46 AM
    #702
    subspd
    subspd King of used Toyota trucks
    Cumming, GA
    06' 4Runner Limited 4x4 V6
    Lift, lights, light saber..
  3. Mar 18, 2019 at 6:16 AM
    #703
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    r1200gs4ok likes this.
  4. Mar 18, 2019 at 7:52 AM
    #704
    arnette64
    arnette64 Well-Known Member
    Amos, QC (Canada)
    2016 Inferno TRD Sport Double Cab 4X4
    '16 Inferno TRD sport DC
    He's right :D
  5. Mar 19, 2019 at 7:57 PM
    #705
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    For you 2nd gen guys, Amazon has the Philips +30 H4's for $4.99 per bulb. (Last I checked)
    crashnburn80[OP] likes this.
  6. Mar 19, 2019 at 8:15 PM
    #706
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    NMTrailRider[QUOTED] likes this.
  7. Mar 19, 2019 at 8:19 PM
    #707
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    I just read through that LED conversion thread and all I can say is wow just wow
  8. Mar 19, 2019 at 8:31 PM
    #708
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    All engineering and science facts on automotive lighting are ignored there, references to literally the most respected industry leading lighting expert's articles are treated with complete disregard. It is a dark place.
  9. Mar 19, 2019 at 8:50 PM
    #709
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    I have Morimoto XB 4300k HID’s with fastbright 35 watt AC ballasts in my low beams. They are adjusted to the correct height (my truck is lifted), have a great cutoff (never been flashed).
    Everyone who has ever rode with me at night says that I have the brightest headlights they have ever seen. Spent about $150 2 years ago and haven’t had a problem yet. They should last about 10 times as long as halogens.
    I work night shift in the hospital, so I do a lot of night driving.
    Rockoma5 likes this.
  10. Mar 19, 2019 at 9:08 PM
    #710
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Note that aftermarket HIDs are typically around 2000 hour bulb life, stock halogens are 1000 hours, so you are really at 2x the bulb life not 10x. However that is assuming the HIDs are driven with a true OEM grade 35w ballast. As demonstrated in the thread, in the case of the XD ballasts, they were actually 42-43w, which means that HID bulb life will take a hit from being over-driven, potentially dropping their life down to 1.5x of stock halogens. Of course once you go performance halogen and sacrifice life for higher output, it is a whole different story.
  11. Mar 19, 2019 at 9:42 PM
    #711
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Damn @crashnburn80, you are a walking-light encyclopedia! Thanks for all you do, and thanks for sharing your knowledge!
  12. Mar 19, 2019 at 10:46 PM
    #712
    Sirpopeington
    Sirpopeington Well-Known Member
    17' TRD Off-road 4x4
    Just for clarification. If running the h9’s in the h11 low beams is there a conversion harness or do I just need to trim the tab off of the Hellas? It’s been a while since I’ve dug through this thread and don’t recall.
  13. Mar 19, 2019 at 11:03 PM
    #713
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    Yes you can just trim the tab off the bulb itself. I chose to make the conversion harness because I drive a lot at night and winter in Alaska and I wanted the ability to switch back and forth between both types at 40 below if one blew while driving. Also it made more sense to me to modify a harness once then a bulb every time I changed it considering these aren’t long life bulbs.
  14. Mar 19, 2019 at 11:22 PM
    #714
    NMTrailRider
    New Mexico
    Overdriving the bulbs and "bounce" are a couple of the things that steered me away from the HID's. That and the fact that "someone" is sticking an HID bulb on on an H11 base. And it's not Philips or GE. An H11 HID isn't really a real thing.
    I've also read countless posts of people going HID and then back to halogen for one reason or another. Seems to be a mixed bag.
    El Duderino and crashnburn80[OP] like this.
  15. Mar 19, 2019 at 11:26 PM
    #715
    Sirpopeington
    In your experience, can the tab be easily trimmed off or do I need to dremmel it down? I’m wondering if my kershaw will do the trick.
  16. Mar 19, 2019 at 11:29 PM
    #716
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You can do it with a small knife, no specialty tools needed. See example of trimming below. Left is stock, right the upper internal tab is trimmed.
  17. Mar 20, 2019 at 4:42 AM
    #717
    johnnyroid
    johnnyroid Well-Known Member
    Vine Grove (Fort Knox) Kentucky
    2017 Black Tacoma Sport TRD
    I see what you did there (dark place). All kidding aside, it's actually quite a shame. Not a**kissing, but I spent two days scouring your posts about lighting technology, after I just KNEW I was going to get bitching LED headlights. After reading through your exhaustive research (many many thanks for your work), most of which I didn't really understand (just an old retired soldier, far from an engineer), I was convinced to allow myself to follow what smart people who obviously know what they are talking about. I actually went with the H9 for both HB and LB, and did the GE +130 for the fogs. Happy as a clam. Your work and research are greatly appreciated, and I'm pretty sure there are many others appreciate you doing all that work too.
  18. Mar 20, 2019 at 6:55 AM
    #718
    xxTacocaTxx
    xxTacocaTxx Well Unknown Member
    Best Slope CO
    2017 TRD OR DCLB 4x4 OMGWTFLOLBBQ
    RCI skid plates Mobtown sliders Lots of patches and MESO stuff
    I'd counter that it's really bright. So bright and full of glare that everyone is blinded.
  19. Mar 20, 2019 at 9:09 AM
    #719
    Sirpopeington
    Ever since this thread, I’ve not only noticed all the innaprropriate leds in wrong housings on the freeway but I rant to my gf about them. She doesn’t give two shits...
    Rodarbal, Junkhead, darkfader and 6 others like this.
  20. Mar 20, 2019 at 9:58 AM
    #720
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
    Just like anything else in life, the devil's in the details - if you're willing to know them, that is.
