3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. May 8, 2019 at 11:58 AM
    #1101
    MunchTIME
    MunchTIME Well-Known Member
    SD, CA
  2. May 8, 2019 at 12:35 PM
    #1102
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Practically speaking, no. Keep in mind that the capsule must be precision aligned so the HID arc takes place in the exact same spot as the halogen filament for it to work correctly. If you misaligned the capsule the output will not project correctly. The level of precision needed is a bit more than a DIYer is going to achieve even if you were able to disassemble and rebase the bulb yourself. Xenon Depot does stock the rebased Philips H11 HID bulbs again, so you can purchase replacements, however they are sold in pairs. They did change the base when the bulb was brought back under TRS, they now use the XD HID H11 base instead of the halogen H11 base that was used when I reviewed the products.
    In the color temp drop down on this page, there is the Philips 4300k option:
    https://www.xenondepot.com/H11-HID-Kit-Bulb-p/xt-h11-rb.htm
  3. May 8, 2019 at 1:41 PM
    #1103
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    I’m just over here, waiting on a set of retros.
  4. May 8, 2019 at 11:27 PM
    #1104
    Kauai_Tacoma
    Kauai_Tacoma Well-Known Member
    2016 Tacoma sport
  5. May 9, 2019 at 8:40 AM
    #1105
    savage24x
    savage24x Well-Known Member
    2019 TRD Sport 4x4 V6 Cavalry Blue
    I've got G5-R's with CBI bulbs pulled out of my old 2000 tundra ready to go in my 2019 tacoma... but i also have brand new H9's sitting in the package... probably gonna wait until I pay it off to put the G5-R's in!
    Also have H11 Nokya Stage 1 Hyper Yellow's ready to go for the fogs.
  6. May 9, 2019 at 8:41 AM
    #1106
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    Famous last words.
  7. May 9, 2019 at 8:43 AM
    #1107
    savage24x
    I pick up the truck tomorrow... whatever happens after that is out of my control! Alas... I do hate permaseal.
  8. May 10, 2019 at 6:39 PM
    #1108
    docsails
    docsails Well-Known Member
    Garry
    2018 Tacoma 4x4 Off Road
    Pro grill, TRD intake, Flowmaster dual exhaust, some LED updates
    Crash.
    When do you think there will be an LED bulb we can drop into our (Gen III) projectors that you feel will work satisfactorily?
    A) Sometime this year?
    B) Next year?
    C) The distant future?
    D) Or just wait for the price on 2020 Tacoma LED headlight assemblies?
    Except my old Thunderbird I mess around in occasionally, all my other vehicles my wife and I drive are HID or LED and the lighting at night is stunningly better than my Taco.
  9. May 10, 2019 at 7:29 PM
    #1109
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    SAE is drafting regulation standards now to legalize drop in LEDs that can meet the strict performance testing standards. Once these standards are set it will give reputable LED companies an objective to work toward and then the products will be able to carry a SAE compliant stamp. It will then just be up to the companies to R&D to meet the standards. Then you will be able to distinguish the ‘good’ LEDs from the no-so-good. However this will of course open up rampant falsified stamped Chinese products, as many already exist today, so navigating those waters will still have challenges for the consumer. But you’ll know products from high quality reputable brands like Osram and Philips that carry the SAE stamp will be decent.
    That said, I don’t see it being as good as a halogen upgrade. The reason your HIDs and LEDs are so much better on the other vehicles is they were in optics specifically designed for that light source. The current favored design of the bi-directional blade LED does not provide uniform light, since well it isn’t a uniform light source. And the housing is designed for omni-directional uniform light. So while they may be able to shrink the LEDs small enough to get better focus within compliance standards I don’t see the beam pattern being as full/saturated or projecting as well as with a halogen upgrade.
    Replacing the housings with one designed for the LED light source is definitely a better way to go for LEDs. Either the OEM Toyota or the Morimoto LED headlight assemblies. While people expect the OEM units to be crazy expensive, Toyota’s LED fogs by Valeo are reasonably cheap at $110 for the pair, though their previous fogs were made in North America, the LED fogs are now made in China. They are about the cheapest decent SAE LED fog on the market for a Tacoma and higher output than the more expensive Morimotos. So it will be interesting to see what they do for the headlights.
    After I finish some other projects I may kick the tires on a few drop in LEDs from highly reputable manufactures to try and find what is the best projecting LED, but it won’t project as well as all the other alternatives on the market because the housing wasn’t designed for it.
  10. May 10, 2019 at 8:59 PM
    #1110
    vookie91
    vookie91 Well-Known Member
    Bay Area, CA
    2017 TRD OR DCSB 4X4
    Thank you!
    crashnburn80[OP] likes this.
  11. May 11, 2019 at 7:22 AM
    #1111
    speedyralph
    speedyralph Member
    2019 SR5 Double Cab
    30" front light bar, LED int w/ reverse, Tonneau soft cover, Predator knockoff bars
    Wow! I read the first page and my brian fried! I would love to have more time to reread and analyze which direction to go with but I run a trucking business and I have two todlers and wife that occupy 109% of my time. Please my fellow Taco owners don't be mad if I'm just trying to get a quick answer-link to which low/high beam w/fog bulbs I should get to upgrade my cheap 2019 SR5 Double Cab halogen headlight truck? I don't really want an overkill of beam that annoys drivers infront of me. Thank you guys and CRASH you da man bro!
  12. May 11, 2019 at 7:44 AM
    #1112
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    Put these in your low beams: https://www.amazon.com/dp/B003YMPN3A
  13. May 11, 2019 at 8:03 AM
    #1113
    speedyralph
    speedyralph Member
    2019 SR5 Double Cab
  14. May 11, 2019 at 8:34 AM
    #1114
    Deucer01
    North Georgia
    Those are it. I have the same in my high beams. To install the H9 bulbs in the low beams you will need to trim a tab in the bulb socket. I used a micro cutter I got from Walmart but there's a link for one on Amazon at the bottom of the page.
    https://www.tacomaworld.com/threads...ector-headlights.589465/page-52#post-20382156
    You'll have to stick with H11s in the fogs because they have glare caps and the fogs don't have shields. I believe the GEs are the best currently. I didn't change my fog bulbs because I have some KCs on order. :D
    speedyralph[QUOTED] likes this.
  15. May 11, 2019 at 9:38 AM
    #1115
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Check out post #2 in the this thread for headlight and fog recommendations:
    Alternatively replacing the stock fogs with units designed for LED is covered here. The KC G4’s mentioned above are what I would recommend as the best all round fog available at this time.
    https://www.tacomaworld.com/threads/the-led-sae-j583-fog-pod-fog-light-review.554813/
  16. May 11, 2019 at 10:48 AM
    #1116
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    Alternatively, I recommend the GE H11 +130s in the low beam.
    GE Megalight Ultra H11 +130% Light Car Headlight Bulbs (Twin) 53110XNU https://www.amazon.com/dp/B06XRS9LBR/ref=cm_sw_r_cp_api_i_SOW1Cb2AJSKGP
    It’s going to be a couple months before it gets dark enough to compare outputs again (summer in Alaska!) but having used both I feel like the H11 project light more effectively and has a better spread than the H9’s.
    Either bulb, the H9 or the GE H11’s, are a significant improvement over the stock bulb.
  17. May 11, 2019 at 5:31 PM
    #1117
    speedyralph
    speedyralph Member
    2019 SR5 Double Cab
    Thanks for the advice again! Hey which KC's fit the oem socket? G4 right?
  18. May 11, 2019 at 6:26 PM
    #1118
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    KC G4 500 for clear or KC G4 501 for amber are the Tacoma plug and play models for the OEM spot. There is a universal KC G4 as well for for mounting to aftermarket bumpers.
  19. May 11, 2019 at 7:32 PM
    #1119
    SubieRuby
    SubieRuby Well-Known Member
    kevin
    Northern VT
    19 Tacoma TRD Offroad
    I put jdm astar led bulbs on my 3rd Gen and they are amazing! Perfect output and beam. Got them on Amazon
  20. May 11, 2019 at 7:35 PM
    #1120
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Unless they changed the laws of physics that’s not possible. Glad you’re happy though. Can’t say the same for outcoming drivers.
