3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. May 14, 2019 at 11:27 AM
    #1141
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    Thank you sir. Appreciate your assistance. I think I got it. Very simple. Can just go in fron wheel well it through engine bay. Thanks again
    Deucer01[QUOTED] likes this.
  2. May 14, 2019 at 11:32 AM
    #1142
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    In my experience going in through the wheel well is not the best technique, at least for the KC Gravitys I installed. Just open the hood and reach in from the top. When you install the light, use masking tape to hold the screw onto the stubby philips. Pay attention because the light mounting tabs are different lengths on opposite sides on the driver and passenger lights, make sure you are installing the left on the left and right on right.
    The KC instructions were atrocious but they were threatening to update them a few months ago.
    Boghog1 likes this.
  3. May 14, 2019 at 4:05 PM
    #1143
    r1200gs4ok
    O. K.
    Irvine, Ca
    thank you very much.....i did find a video of ORM and KCs....depending on what i get will determine the install process
  4. May 14, 2019 at 4:10 PM
    #1144
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    I was looking at this option as well with covering the fogs
    NMTrailRider[QUOTED] likes this.
  5. May 15, 2019 at 4:10 PM
    #1145
    speedyralph
    speedyralph Member
    2019 SR5 Double Cab
    30" front light bar, LED int w/ reverse, Tonneau soft cover, Predator knockoff bars
    I think what I'm understanding here is that I could use Philips H9's for both low/high beams and H11's for my fogs, right? Oh, and I may need the plug adapters.
    Tacosrus likes this.
  6. May 15, 2019 at 4:14 PM
    #1146
    LegendaryAcura88
    LegendaryAcura88 Well-Known Member
    2017 Tacoma SR5 V6 DCSB
    Yes on all counts. To the best of my knowledge there isn't an H11 to H9 adapter. People are buying the H11 extension and trimming it to fit an H9 bulb in order to not alter the factory wiring at all. I just "modified" the H11 extension and it took maybe 30 seconds per extension with a box cutter
  7. May 15, 2019 at 4:23 PM
    #1147
    speedyralph
    speedyralph Member
    2019 SR5 Double Cab
    Well as per post #1144-1145 he used the adaptor to plug in his H9's on his low beams without shaving anything. I wonder if this adaptor is also needed for the high beams, lol?
    Let me rephrase: h9's for both low/high bean and h11's for fogs and possibly need to use adaptors for both low/high beams.
  8. May 15, 2019 at 4:26 PM
    #1148
    LegendaryAcura88
    1144 states they cut the notch. And no adapter is needed for the hi beams, they're already H9's
    speedyralph likes this.
  9. May 15, 2019 at 4:41 PM
    #1149
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
    2018 Blazing Blue Pearl SR5 DCSB
    Correct. H9s are already the Highs. Cut a notch in the extension and it's plug and play with an H9 in the lows.
  10. May 15, 2019 at 4:47 PM
    #1150
    docsails
    docsails Well-Known Member
    Garry
    2018 Tacoma 4x4 Off Road
    Pro grill, TRD intake, Flowmaster dual exhaust, some LED updates
    Just ordered the KC G4 500 led fogs (clear-no amber) from Summit Racing as per crashnburn80 recommendations. This lighting businesses starting to be pricey!
    Summit racing seems to be the only place that has the KC G4 500 fogs with clear, non-Amber LEDs. They (the clear fogs) seem to be back ordered on Amazon and everywhere else.
    BTW, I have a set of 2 week old Toyota OEM LED fogs PT413-42191 (Black) for sale if anybody's interested. Also, a set of the original Toyota fog lamps. PM me.
    Little by little my night vision is improving...
    crashnburn80[OP] likes this.
  11. May 15, 2019 at 5:07 PM
    #1151
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
  12. May 17, 2019 at 9:42 AM
    #1152
    Chzytaco
    Chzytaco Active Member
    Serg
    2017 Super White TRD OR 4x4
    KC HiLites G4 Fogs
  13. May 19, 2019 at 6:36 PM
    #1153
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    A lot of information in just the first post! I'm looking to compare something to my HIDs, just to see if I like the cutoff/throw of a standard halogen better. If I'm understanding this right, the $8 Phillips H9 bulb is the most recommended bulb for stock wattage? And they're 'better' than the GE +130? And only thing needed to make the H9 fit is to cut the tabs off inside the bulb base, like I did to fit my H9 fog lights...?
  14. May 19, 2019 at 6:48 PM
    #1154
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Correct. However they will not put out more light than your HIDs, but they are far brighter than stock. Whether you like them more is up to you.
    Note that H9s in the fogs will produce excessive glare with no glare cap on the bulb, the OEM fogs do a poor job of glare control in general. So if you are running non-capped H9s in the fogs, you should avoid using them with oncoming traffic.
  15. May 19, 2019 at 6:52 PM
    #1155
    Technique
    Alex
    Utah
    Right. I just feel like sometimes I can't see that far with my HIDs because the cutoff is so sharp and if I angle them up more, I'll be blinding oncoming traffic so thats why I wanna try halogens out again. As for my fogs, yeah I don't drive with them on in traffic, especially since I've made the switch to some Baja Designs amber fogs.
  16. May 19, 2019 at 7:01 PM
    #1156
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Common problem where the contrast is too extreme at the cut off that you cannot see beyond it as you are actually hindered by too much light affecting your night vision. Give the Philips H9s a try.
    Yeah, the Baja ones are no good for oncoming traffic. Gotta get some selective yellow Rigids or Bajas new SAE fogs due out in June (white only in June).
  17. May 19, 2019 at 7:04 PM
    #1157
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
    I'm holding off on the KCs , wanting to see the New Bajas.
  18. May 19, 2019 at 7:04 PM
    #1158
    Technique
    Alex
    Utah
    Got em ordered! Can't hurt to try them for $16! I'm eager to see how the SAE ones will work (whole new kit or just a lens I can put on mine now)
  19. May 22, 2019 at 8:50 AM
    #1159
    Technique
    Alex
    Utah
    Quick update. I got the Philips H9's installed yesterday and I really don't mind them coming from my HIDs. Granted I like the color temp. of my HIDs a lot better, but the light output isn't terribly worse, in my opinion. I still feel the bad cutoff affect but I think that's just how the headlights are. The one thing that may keep me on the halogens is not having the HID shake...but we'll see.
    Here's a pic comparing the light on my garage door, if anybody is interested. XD 5000K HIDs on the right.
    skierd and crashnburn80[OP] like this.
  20. May 22, 2019 at 8:57 AM
    #1160
    IPNPULZ
    going to be fun!
    so the HID's are somewhat a blue tint i take it or is it just because of the distance creating that effect?
