3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. May 30, 2019 at 5:18 AM
    #1181
    gurneyeagle
    gurneyeagle Well-Known Member
    Saint Augustine, FL/Houston, TX
    2008 Tacoma SR5, 2018 Audi TT RS, 2018 Tacoma TRD Off Road (Cement), 2019 MDX
    Shhhhh…………………..that's MESO's next project!
  2. May 30, 2019 at 7:19 AM
    #1182
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    Carbon fiber deer whistle hood skewp insert. :D
    crashnburn80[OP] likes this.
  3. May 30, 2019 at 7:21 AM
    #1183
    speedyralph
    speedyralph Member
    2019 SR5 Double Cab
    30" front light bar, LED int w/ reverse, Tonneau soft cover, Predator knockoff bars
    Like I said, my truck's low beams were H11's from factory so putting the Philips H11's was as simple as plug & play. The high beams are the problem here because they are H9 from factory. I was able to plug the H11 onto the pig tail but was unsuccessful clocking them into the housing socket.
  4. May 30, 2019 at 7:25 AM
    #1184
    speedyralph
    speedyralph Member
    2019 SR5 Double Cab
  5. May 30, 2019 at 9:27 AM
    #1185
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Yep!
    You guys got it covered, but correct, the reflector is precision designed for an LED light source rather than trying to make an LED mimic a halogen for use in reflector specifically designed for a halogen light source. There are some great LED reflector lights such as the offering from KC like the KC G4 fog, where all the reflector optics are specifically designed for the LED source.
    You don't want to put an H11 in the high beam! An H11 is ~1300 lumens and H9 is 2100 lumens. Some performance H11s can outperform some H9s in the low beam because they are more focused and the low beam concentrates the focus into a hot spot, so a lower output source with better focus can outperform a higher output source with less focus. In the high beam the pattern is distributed for maximum area coverage and distance projection, you need the raw power of the H9. Putting an H11 in there will be a downgrade.
    xxTacocaTxx and Boghog1[QUOTED] like this.
  6. May 30, 2019 at 9:34 AM
    #1186
    ANTupLIFE
    ANTupLIFE Well-Known Member
    Anthony
    Chester, VA
    '16 TRD Sport 4x4 DCLB SW
    Place H9's instead of H11's in your low beams by cutting the small tab. They have no glare cap and will project much more full. You can leave your highs as is, as that's the best option overall. If you wish to keep H11's for low beam, then use GE +130. I feel you have this all backward.
    ERod27 likes this.
  7. May 31, 2019 at 5:07 AM
    #1187
    speedyralph
    speedyralph Member
    2019 SR5 Double Cab
    I don't think you guys are realizing that my LOW beam came with a H11 NOT H9 and my HIGH'S came with a H9 from factory.
    NOT THE OTHER WAY AROUND.
    The objective was to upgrade to a bright white color bulb for both my lows and highs so I went to the philips site https://www.automotivebulbfinder.com/philips/ and bought the CrystalVision Ultra which is a 4300k.
    I bought the H11 as recommended for my lows and those went in with no problem (plug/socket) bc I stated above (low beams came with H11's from factory) and I also bought H11's for my highs bc I thought I could modify them to fit but I realized that the issue wasn't trying to fit them to the plug the issue is trying to clock them into socket.
  8. May 31, 2019 at 5:11 AM
    #1188
    gurneyeagle
    No, everyone who has been on the thread and read it from the beginning understands that H11's come in the lows and H9's come in the highs. What crash has determined after much testing and money out of his own pocket is that H9's work better in the lows. Putting H11's in the highs is counter-productive for anything other than aesthetics and will cause performance to suffer.
  9. May 31, 2019 at 4:30 PM
    #1189
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You need to run an H9 in the high beam. If you really want a whiter color bulb, understanding it will be lower output than a clear bulb, use something like a PIAA Xtreme White H9, or a Sylvania Silverstar H9 both of which will be plug and play.
  10. May 31, 2019 at 7:05 PM
    #1190
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  11. Jun 3, 2019 at 5:11 PM
    #1191
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I'm cross posting this from the 2nd Gen headlight thread because I think it is interesting enough to share in both the 2nd Gen and 3rd Gen threads.
    For a really interesting headlight comparison! 3rd Gen owners seem to often mention the headlights are not that great. Larger reflectors are more efficient and performant than smaller ones and ultimately a projector still has an internal reflector, as far as reflectors go the 2nd Gen reflectors are pretty massive. Now that I have run both Gens through the same series of standardized tests, I have directly comparable data.
    Here is the 3rd Gen data, which you guys are familiar with. I have the 3rd Gen in 2 charts due to the LEDs and HIDs being involved in the first one. The HIDs used in this first chart are Xenon Depot house brand bulbs, and their rebased H11 HID Philips bulbs.
    More 3rd Gen halogen data:
    Compared to the 2nd Gen halogen data:
    Some interesting points:
    • Stock 2nd Gen headlights are about 56% higher lux than stock 3rd Gen headlights.
    • A stock wattage Philips +150 bulb in 2nd Gen comes in at higher lux than the XD HIDs in 3rd Gen headlights.
    • Osram Hypers put out nearly as much lux as the Philips HIDs... at 13.8v. The higher wattage bulbs measurements do not have added voltage to account for running a standalone harness which boosts output. And if you are running an AGM with a voltage booster, as covered here, results will be even higher. Meaning that the original Ultimate Headlight Upgrade with the voltage booster is actually higher in lux output than HIDs in a 3rd Gen halogen projector. Correctly using HIDs in a proper HID projector would produce better results than HIDs in a halogen projector. But still fun comparison data nonetheless.
    For headlight output photos of my setup that I have shared in this thread, they have been the Osram 85/80w Hyper, and the and the Osram 85/80w All Season (Hyper).
    xxTacocaTxx, ERod27 and skierd like this.
  12. Jun 5, 2019 at 2:38 PM
    #1192
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Who wants to be the first to attempt to retrofit 2nd gen reflectors into 3rd gen headlamps?
  13. Jun 5, 2019 at 3:33 PM
    #1193
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    LOL! The 2nd Gens seem to always want projectors like 3rd Gen!
    Boghog1 likes this.
  14. Jun 7, 2019 at 2:46 AM
    #1194
    RedsWhiteTaco
    RedsWhiteTaco Well-Known Member
    Portland
    2020 Tacoma Off-Road
    Soooooo I have a 2019 Pro and I don't like the LED fogs with the Halo Heads... can you just tell me to leave them alone or copy me a link on what to buy haha thanks!
  15. Jun 7, 2019 at 9:36 AM
    #1195
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Sell the Pro fogs and replace them with higher output fogs in a far more usable color temperature, you'll likely even come out ahead after the sale of your Pro setup.
    https://www.4wheelparts.com/p/rigid...mpliant-fog-light-pods-504814/_/R-FLWB-504814
    You can see how the Pro fogs compare here:
    https://www.tacomaworld.com/threads/the-led-sae-j583-fog-pod-fog-light-review.554813/
    And the Rigid selective yellow prototype comparison here.
    ghostlywolf81 and xxTacocaTxx like this.
  16. Jun 7, 2019 at 9:49 AM
    #1196
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    In the original post I talked about the importance of what I called the "LED cross section" and how making light sources smaller it is critical to beam focus, and focus is essentially what drives distance projection efficiency, which is what most LEDs lack. Here is a video from Diode Dynamics talking about the same concept:
    https://www.youtube.com/watch?v=WGmoDtdNqIk
    The cross section of their LEDs covered in the video is by far the smallest I have seen, and it is really refreshing to see science based content to promote a lighting product rather than glare photos or raw lumen claims. I've reached out to Diode Dynamics and will be testing their LEDs soon to compare them to halogen focus and projection in the 3rd Gen headlight. It will be interesting to see what the data says. :)
  17. Jun 7, 2019 at 10:43 AM
    #1197
    replica9000
    2019 T4R ORP
    But he doesn't mention you're still not getting a full 360° of light since he's showing off a blade style LED "bulb". LED tech seems to be improving fast though, so maybe soon.
    I'd like to see more options like the OEM Tundra LED headlamps.
  18. Jun 7, 2019 at 11:05 AM
    #1198
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yes, you are correct, it will still have that flaw inherent in the blade style design. Thinner cross section helps reduce the negative effect, however it obviously will not shine light above the bulb. Below won’t matter since the light is cut off by the projector glare shield.
    2020 Tacoma’s will have LED headlights like the Tundra. I’ll have to get my hands on some when they are released, having optics designed specifically for LEDs will provide better results.
  19. Jun 9, 2019 at 1:19 PM
    #1199
    Cwopinger
    Cwopinger Random guy who shows up in your threads
    Blevin
    Florida
    2019 Quicksand Tacoma OR DCLB
    ARE MX, mud flaps, radio knobs, floor mats
    Yesterday I finally got around to putting my Phillips H9 bulbs in for upgraded low beams. I also bought extra bulbs for the high beams while I was at it. When I pulled the factory high beams out, I was pleasantly surprised to find German Phillips H9s already there. The extras went in my spare parts kit for replacements. 2019 Off Road purchased in March FWIW.
    NC Rick likes this.
  20. Jun 10, 2019 at 4:39 PM
    #1200
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    Which HID kit is recommended for low beams? I've tried H9s and LEDs but neither were too impressive.
