3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Aug 2, 2019 at 6:48 AM
    #1361
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    A few biased reviews by gullible fanbois doesnt carry much weight.
    xxTacocaTxx and Deucer01 like this.
  2. Aug 2, 2019 at 6:51 AM
    #1362
    Garab
    I recommend meso's kit for interior lights.
    xxTacocaTxx likes this.
  3. Aug 3, 2019 at 9:39 PM
    #1363
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    replica9000 and Garab like this.
  4. Aug 6, 2019 at 11:00 AM
    #1364
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    @crashnburn80 first of all thank you for the copious amount of information provided. I read through every single page of the thread and ended up installing the GE Megalight +130 but may switch over to the GE Xenon +120 down the road for the low beams.
    At the risk of getting off topic maybe you can help me shed some light on bulb selection (pun intended). Aside from the H9 rework option are the two H11 GE options the best for that type of halogen bulb across the board, or is it the best specific to the application in the 3rd Gen Tacoma projector housings? The reason why I ask is because I am enjoying the output and function in my truck and would like to do the same for my wife's 2017 GMC Yukon. Looks like the Low Beams are H11, High Beams are 9005, and Fog Lights are PSX26W. Appreciate the input in advance!
  5. Aug 6, 2019 at 1:00 PM
    #1365
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    There may be a performance difference between the projectors themselves in your Yukon vs your Tacoma, but the bulbs should perform the same regardless of the housing it is in.
    For your Yukon, I’d get GE +130 H11’s, 9011 HIR bulbs for the high beams, and a good LED replacement fog housing.
    crashnburn80[OP] likes this.
  6. Aug 6, 2019 at 1:25 PM
    #1366
    jawkneee
    jawkneee Well-Known Member
    2019 Cement TRD Sport
    just installed a set of XENONPRO HID 6k.
    debating if i wanna do the xenonpro LED for the fogs to match.
    any recommendations?
  7. Aug 6, 2019 at 5:01 PM
    #1367
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yes, the bulbs will offer similar performance gains. Projectors seem to offer better gains for the high efficiency bulbs than reflectors. I would suggest the GE Xenon +120s as the best performing H11 in the low beam. For your high beam, modify a 9011 HIR by trimming an external plastic tab to fit the 9005 socket. Output will be bumped from ~1700 lumens to about 2500 lumens while consuming the same power.
    Here is a how to on trimming the tab: https://store.candlepower.com/mohirbuba.html
    9011s: https://store.candlepower.com/hirlighting.html
    CrisisFish and 6MTPro[QUOTED] like this.
  8. Aug 6, 2019 at 5:05 PM
    #1368
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome to the forum!
    LEDs in the fog reflectors will just throw scatter and glare and not perform well. You should change the fog assembly to an LED unit, if that is what you are looking for. Most all the options are covered here:
    https://www.tacomaworld.com/threads/the-led-sae-j583-fog-pod-fog-light-review.554813/
    You might consider the Toyota LED fogs as they are the least expensive, about the same price as the XD LEDs, around 6000k in color and will perform significantly better without glare issues.
    xxTacocaTxx and dnguy77 like this.
  9. Aug 6, 2019 at 9:14 PM
    #1369
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  10. Aug 6, 2019 at 9:20 PM
    #1370
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Awe.... I miss mine.
  11. Aug 6, 2019 at 10:07 PM
    #1371
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
  12. Aug 6, 2019 at 10:28 PM
    #1372
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Not all LED headlights have this issue, but it will be interesting to see how the new ones stack up. You know I'm going to try and get some. :)
    wideloadwillis likes this.
  13. Aug 6, 2019 at 10:29 PM
    #1373
    El Duderino
    Jeremy
    HI->PNW
    I knew that before I posted lol. I’ll wait for the official crash test
  14. Aug 7, 2019 at 12:12 AM
    #1374
    spider*2008
    spider*2008 Member
    Derek
  15. Aug 7, 2019 at 5:20 AM
    #1375
    WilderTaco
    WilderTaco Active Member
    Iowa
    2019 TRD OR DCLB Cement
    Looking at the GE +130 bulbs on Amazon they offer a 4-year extended care plan for $5.
    • Covers failures due to power surge and other mechanical and electrical breakdowns.
    Wouldn't a burnt out bulb fit this definition? I ordered em with the plan. I'll check the terms and see if it covers bulbs.
  16. Aug 7, 2019 at 5:58 AM
    #1376
    Racefan15
    Racefan15 Well-Known Member
    Wow, there goes 3 hrs of sleep. What an amazing write up. Now so tired, I just want an answer.... Have decided on the GE Xenon +120. Do I get 2 pair (low beams and high beams) and if so, what is the correct sizes? Thanks a lot....
  17. Aug 7, 2019 at 6:58 AM
    #1377
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Just low beam for the GE Xenons. Stock uses Philips H9s, which are already the best bulb for the application.
  18. Aug 7, 2019 at 8:20 AM
    #1378
    6MTPro
    HI -> CA
    That's great input thank you! Currently have the Philips Crystal Vision Ultra H11 and from what I've learned in this feed the blue coating is compromising the performance.
  19. Aug 7, 2019 at 8:47 AM
    #1379
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    That is correct. Coatings to make the light output whiter rob performance. The Xenons use a Xenon gas fill which produces a whiter light than stock, but not as white as a coated bulb.
  20. Aug 7, 2019 at 1:17 PM
    #1380
    6MTPro
    HI -> CA
    It's kind of interesting for the Yukon the lower SLE/SLT trims get halogen low beams and the top Denali trim has HID's standard. Totally understand economies of scale and when they are cranking out 245k+ Tacomas a year the name of the game is speed and streamlined production processes. But since there are already 5 different headlight assemblies with slight variations from the among the various trims (albeit mostly aesthetic), why didn't/doesn't Toyota take it just a bit further and have certain higher end trims i.e. Limited and Pros as a standard option or OR/Sport with premium packages have a different/more advanced lighting configuration and setup? I get it's that people buy them regardless and Toyota often leans more towards keep in simple, stupid mantra. Just thinking out-loud.
