3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Jan 31, 2019 at 10:40 AM
    #121
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
    2018 Blazing Blue Pearl SR5 DCSB
  2. Jan 31, 2019 at 10:42 AM
    #122
    TiHo
    TiHo Well-Known Member
    2018 TRD Sport
    What do these allow you to do? Are they just an extension of your existing wiring? Just curious and trying to follow along.
  3. Jan 31, 2019 at 10:44 AM
    #123
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
    I'll mod these instead of the bulbs. Plug and Play afterwards
  4. Jan 31, 2019 at 10:50 AM
    #124
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Instead of trimming the tab on the inside of an H9 bulb like below (trimmed left, stock right)
    You add a small wire harness extension and trim the harness as shown in post #78 below:
    https://www.tacomaworld.com/threads...de-not-led-or-hid.475064/page-4#post-18845649
    So rather than trimming the bulbs every time there is a bulb change, with the trimmed harness you only have to do it once and now you have a plug and play solution going forward.
  5. Jan 31, 2019 at 11:07 AM
    #125
    TiHo
    2018 TRD Sport
    I ordered the GE +130's instead of going the H9 route but if the bulb life is significantly longer with the H9's I might switch to those after these burn out.
    crashnburn80[OP] likes this.
  6. Jan 31, 2019 at 11:18 AM
    #126
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
    Just ordered 4 H9 Hella Bulbs.
    With the extensions comes to 55 Bucks Total. Jazzed.
    crashnburn80[OP] and El Duderino like this.
  7. Jan 31, 2019 at 11:37 AM
    #127
    TNInferno
    TNInferno Well-Known Member
    Tennessee
    2017 Inferno TRD OR DC
    @crashnburn80
    I have ordered 4 of the GE Ultra +130 bulbs for the lows and fogs. However, I am now wondering if there is something like these in amber for the fogs that will produce better light output? I can not remember reading anything concerning amber lights.
  8. Jan 31, 2019 at 12:51 PM
    #128
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Already on it. Hows this for color?
    You can see a teaser of what I am working on putting together in my fog thread post #378 here. This is using a 2300k (measured at 2500k) interference coated bulb from Xencn. These are offered in an H11 +80 which would be plug and play for the fogs, though I have not tried the H11 version.
    Interference coated bulbs are more efficient than color coated (absorption) ones, but all filters reduce output. Fortunately halogen light does not produce much blue short wave light, so filtering the output to remove the blue short wave light to have the beam become more yellow/amber doesn't have anywhere near the negative effect as putting a blue filter on a bulb to filter out the yellow output, which is the majority of the light output. Lunex has their interference filtered Plasma Golds +80s at 2900k and Nokya offers standard interference filtered 2900k All Weather bulbs. I'm experimenting with Xencn because they use a more aggressive filter for lower color temp while also claiming to use an increased performance bulb. So far the results look promising but I am waiting on more product to arrive. I currently run an All Season interference bulbs in my headlights. You can see a comparison for how this works in my headlight post #1520 here.
    Geeterman and r1200gs4ok like this.
  9. Jan 31, 2019 at 2:09 PM
    #129
    TNInferno
    Tennessee
    Thank you
    I had previously read that post but had forgotten the information about the all-weather bulbs.
  10. Jan 31, 2019 at 2:26 PM
    #130
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Just for clarification, note that picture is not the All Weather bulb, that is an Xencn 2300k bulb which is much more yellow/amber.
  11. Jan 31, 2019 at 2:37 PM
    #131
    TNInferno
    Tennessee
    Thanks
    Where do you purchase these (Xencn 2300k H11 bulb) from - do not see them on Amazon.
  12. Jan 31, 2019 at 4:25 PM
    #132
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    They don’t distribute to North America. You can sometimes find them on eBay, but Aliexpress is cheaper.
    XENCN H11 2300K Golden Eyes Super Yellow Halogen E1 DOT Fog Lamp
    https://s.click.aliexpress.com/e/c1idYs6M
    I don’t typically buy any Chinese products for my truck if I can avoid it. The quality just usually isn’t there. For example I replaced my Chinese Hella fog relay with a Bosch European one. I’ve so far tested a couple bulbs from Xencn, and their build precision seems decent, better than some much more expensive bulbs I’ve seen. Just looking at their packaging quality is way better than most. I have no data though on bulb life or brand quality (other than it is an Osram company) outside of the very limited bulbs I’ve tried though.
    r1200gs4ok likes this.
  13. Jan 31, 2019 at 7:38 PM
    #133
    DohoTaco
    DohoTaco Well-Known Member
    3rd gen tacoma
    why did you tag me in this
  14. Jan 31, 2019 at 8:06 PM
    #134
    steezymac
    steezymac Well-Known Member
    Front Range, CO
    2016 Black Tacoma TRD Off-Road
    neat info about light modZ
  15. Jan 31, 2019 at 9:11 PM
    #135
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    would you use Xenon Hella H9 or the GEs for the fogs......or better still use the Xenon Hella H9 for lows and GEs for fog........damn, so many options
  16. Jan 31, 2019 at 11:38 PM
    #136
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The H9s do not have a glare cap for open reflector use like in the fogs. In the projector headlights the internal light shield protects against glare from the missing glare cap. For a plug and play solution you will want to use an H11 in the fogs.
    r1200gs4ok[QUOTED] likes this.
  17. Feb 1, 2019 at 5:36 AM
    #137
    Castle 4
    Castle 4 Well-Known Member
    Dan
    Richmond, VA
    2018 TRD Sport DCSB
    Bilstein 6112 / 5160, Icon RXT Stage 3, JBA UCAs, SmartCap Evo Sport, Falken Wildpeaks 275/70R17s; TRD Pro wheels
    @crashnburn80, I work a lot with interior/exterior lighting in theatrical, historic, and commercial applications, and your analysis (and the science behind it) is spot on! The science behind lighting and lighting technology can be mind boggling, and you definitely know your shit. This forum is lucky to have you and your technical expertise!
  18. Feb 1, 2019 at 7:45 AM
    #138
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    Link please!
  19. Feb 1, 2019 at 7:56 AM
    #139
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Thanks! For some reason I just find the science of lighting fascinating and really interesting to study. Here is my most recent book purchase. One of the PhD authors was head of Hellas R&D.
    Check out post #108 with the comparison info and the link:
    https://www.tacomaworld.com/threads...jector-headlights.589465/page-6#post-19740142
  20. Feb 1, 2019 at 8:18 AM
    #140
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
