3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Sep 20, 2019 at 9:31 AM
    #1441
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    I decided to do some tab trimming and toss the Phillips H9’s back in the truck since were getting darkness again. Why? I’ve posted before that I felt that the GE +130 bulbs were superior because I perceive that they gave crisp clean projection compared to the H9’s more “fuzzy” lights despite the H9’s measured higher output and on paper having the same filament orientation.
    With the top tab trimmed, the h9’s lock fully in place just like the stock h11 bulbs. With the tabs trimmed now those bulbs lock fully in place whereas before they were canted about 15°. I’m excited to see if it makes a difference as I suspect it will. Since I had the Dremel out anyway I also trimmed the connector tab so I didn’t have to use the wiring adapters. If they work out the way I suspect they will I’ll just order a second set of H9’s for $14 and have them trimmed and ready to go in the glove box. The GE’s will go in my wife’s CRV.
  2. Sep 20, 2019 at 10:36 AM
    #1442
    replica9000
    replica9000 Death to AI!
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    This may be a silly question, but even though halogen bulbs emit light 360°, does the orientation of the base have any standard placement?
    Seems like many of the LED drop-ins claim performance is best when the LEDs are oriented in the 3 & 9 positions.
  3. Sep 20, 2019 at 12:53 PM
    #1443
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Yes, they should be at 3 & 9 to illuminate the housing properly for uniform light output, which is why it should be built into the design of the product and not something that is freehand adjustable like some manufactures like to promote. Note that in a low beam projector, anything below the 3 & 9 o’clock plane will be blocked by the projectors internal light shield, so that you will get significantly reduced output.
    Inferno__Taco likes this.
  4. Sep 20, 2019 at 1:18 PM
    #1444
    replica9000
    2019 T4R ORP
    Ok, but if you install these in any vehicle, will the LEDs always be in the proper position? I thought many were adjustable to accommodate a wide variety of housings.
  5. Sep 20, 2019 at 2:02 PM
    #1445
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yes, they will always be in the proper position. The halogen tab alignment is standardized and a properly designed LED will utilize the same standardized halogen tabs in the LED body (like a halogen bulb), thus making the orientation always correct. Optics are high precision, it is not something that should be free-hand adjusted. The 'adjustable' lights is just another example of garbage feed to you by LED companies that lack optics expertise.
  6. Sep 21, 2019 at 12:43 AM
    #1446
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    No rain out tonight. The above post covering Sylvania LEDs has been updated with distance projection test results. I've also copied the post to post #3 in the thread covering additional LED testing since the original post.
  7. Sep 22, 2019 at 10:02 AM
    #1447
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    You still have to trim the metal tab, correct?
  8. Sep 22, 2019 at 10:11 AM
    #1448
    NMTrailRider
    New Mexico
    I'm going to do the H11 to H9 mod today. Is there a big difference in the heat produced between the two bulbs?
  9. Sep 22, 2019 at 10:20 AM
    #1449
    skierd
    David
    Fairbanks, AK
    Ideally yes. They’ll fit but not lot all the way in place.
    Not enough to matter or melt anything.
    NMTrailRider[QUOTED] likes this.
  10. Sep 22, 2019 at 11:20 AM
    #1450
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Metal tab trimming is not required with the Philips bulbs. They are a tighter fit, but they will fit without modification.
    Your looking at about an 30% increase in wattage, as the Philips bulbs actually run at the legal max of 74w, which is part of the reason why they perform so well. It is hotter as mentioned but not enough for concern.
  11. Sep 22, 2019 at 11:23 AM
    #1451
    NMTrailRider
    New Mexico
    Thanks guys! So, even with extended run times, heat shouldn't be an issue? I make frequent night time (low beam) trips where I'd be running them for about 6 hours at a stretch.
  12. Sep 22, 2019 at 11:27 AM
    #1452
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Wont be a problem. Keep in mind they are the exact same bulbs the stock high beams use.
  13. Sep 22, 2019 at 3:54 PM
    #1453
    NMTrailRider
    New Mexico
  14. Sep 22, 2019 at 4:00 PM
    #1454
    VoodooPro
    VoodooPro Well-Known Member
    2019 Voodoo blue TRD Pro
    OV 93 tune, TRD pro intake, LED headlights, LED interior lights, tuffskinz interior overlays "RCF", tailgate inlay, Illuminated kickplates, blue interior compartment inlays. Painted voodoo blue interior trim, nitto ridge grapplers, bara 1 inch spacers, redline pro hood struts, trd oil and radiator caps.
    I run the 12000 LM hakari ultras. They dont project as far, but the beam is exactly the same shape and pattern with no scatter. But it's a much better color for actually seeing shit like deer.
    Rockoma5 likes this.
  15. Sep 22, 2019 at 9:13 PM
    #1455
    2L8IWON
    2L8IWON Well-Known Member
    Va Bch, Va
    2019 VB TRD PRO
    Kids highback booster
    Thanks TON for the in-depth research and performance testing!
    You may have covered this already, but which LED bulbs would get your money right now?
    Better yet, what bulb (halogen, LED) best match the color and brightness of the Pros rigid fogs?
  16. Sep 22, 2019 at 9:24 PM
    #1456
    NMTrailRider
    New Mexico
    ^^ be nice to the new guy, fellas.
  17. Sep 22, 2019 at 9:28 PM
    #1457
    2L8IWON
    Va Bch, Va
    2019 VB TRD PRO
    you takin about me? If so, and your have an answer to the question I am asking, please point me in that direction.
  18. Sep 22, 2019 at 9:29 PM
    #1458
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    H11 Hikari ultra with Philips LEDs is the best performing drop in unit I’ve tested in a 3rd Gen projector. The specs are way over inflated and lie, and they are easily beat by performance halogen products, but if you had to have a replacement LED, that is what I would recommend. Swapping to a full replacement LED assembly like the Morimoto headlights will perform significantly better.
  19. Sep 22, 2019 at 9:31 PM
    #1459
    2L8IWON
    Va Bch, Va
    2019 VB TRD PRO
    Thanks bud. What is the best light to patch the color and temp of the Pros Rigid fogs?
    And do you have a Paypal people can donate to in order to help offset some of your expenses?
    NMTrailRider likes this.
  20. Sep 22, 2019 at 10:00 PM
    #1460
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The Rigid Pro fogs measure about 5900k at their peak intensity. The OEM version has color transition from cool at the top of the beam to warmer at the bottom, so they don’t have a single color temp like the aftermarket Rigid’s or most other LED fogs. You can find a ton of fog info in my LED fog thread:
    https://www.tacomaworld.com/threads/the-led-sae-j583-fog-pod-fog-light-review.554813/
    The Hikaris are about 6600k, so they are a little cooler in temp, but I wouldn’t let that prevent you from not using them if set on drop in LEDs as I would favor performance over color. Alternatively Diode Dynamics is pretty close at near 5700k, but they do not perform as well as the Hikaris in the 3rd Gen projector.
    E0BC2F7F-D2CA-46C1-A75F-9E88D34BC13F.jpg F12AD755-08C9-4348-BB11-2EBB19894780.jpg
