3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Oct 10, 2019 at 8:33 AM
    #1601
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    I’ve never seen a $30 replacement LED light do remotely close to great, they are typically Chinese toys.
    Another example that talks about how well they replicate a halogen filament and completely leaves out width. Those things are wide, which will give poor focus and projection performance.
    Edit: And when run in a reflector like a foglight, awful glare.
    wideloadwillis and xxTacocaTxx like this.
  2. Oct 10, 2019 at 8:34 AM
    #1602
    Rockoma5
    Rockoma5 Well-Known Member
    St Louis
    2019 TRD Sport Lifted
    Yes. I did them for my low beam and fogs. The beam pattern is excellent, the color is great, and is brighter than stock. The fogs really project both far and wide which make for great highway driving/backroads.
  3. Oct 10, 2019 at 8:44 AM
    #1603
    Rockoma5
    St Louis
    I am just here answering questions and giving real world results. Are they as good as the halogens you recommend...NO. And I am not disagreeing!!!
    However for a cheap LED is it brighter than stock? Yes! Does it project farther? Seems to yes. It definitely does not project less!. I am happy with my purchase and would recommend, as I just did, when someone asks me about them. They have a ton of positive reviews and you tube videos showing other happy customers which is why I tried them and bought them. If you WANT an led then I think worth the few bucks spent.
    If you want the BEST light output then halogen as you recommend is still superior based upon the factory lighting assembly.
    Take Care.
  4. Oct 11, 2019 at 6:39 PM
    #1604
    TACO_ROCKET
    TACO_ROCKET Well-Known Member
    Tyler
    Black 2019 TRD OR DCSB auto w/ premium tech pkg
    I got my Hiks in. Here's my 100% nonscientific review:
    They look great. It seems the foreground light (or whatever the part is called that lights up signs) is completely gone. I can turn the bulb to get it back, but that kills the focus of the main beam. I haven't driven without other traffic on the road, so I can't say for sure, but I think there is enough scattered light to light signs. Just not at 12 miles away like my factory Fusion LEDs did. Install was a breeze. The cutoff looks stock (minus the signage light) so glare is nonexistent. Overall, I'm pleased so far.
  5. Oct 11, 2019 at 6:44 PM
    #1605
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Is this in your Tacoma? Or the Mustang I think it was? Much of that signage light was scatter and not supposed to be there (where signs light up like they are radio active). The LEDs should be installed so the emitters face 3 and 9 o'clock. In projectors, the uplight to light overhead freeway signs is actually reduced. This is because the projector location for this light is directly in front of the bulb, as halogen bulbs light in all directions including forward. LEDs however do not, so some uplight in lost with side-firing LEDs in a projector.
    Inferno__Taco likes this.
  6. Oct 11, 2019 at 6:52 PM
    #1606
    CB3TACO
    CB3TACO Well-Known Member
    Connecticut
    2nd Gen DCLB SOLD 3rd Gen SW DCLB OFFROAD
    That is good news just ordered a set for my headlights and fogs
  7. Oct 11, 2019 at 7:03 PM
    #1607
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    xxTacocaTxx and Inferno__Taco like this.
  8. Oct 12, 2019 at 5:49 AM
    #1608
    Joe671
    Joe671 YouTube Mechanic
    Joe
    Washington State
    2019 Tacoma TRD Off Road
    So is there much uplift with the stock Halogens to where they light up the signs? I've never really noticed. Even though I just drove into work in the dark lol.
  9. Oct 12, 2019 at 7:50 AM
    #1609
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yep, it is there. It isn’t intended to be super bright, as signs are highly reflective and you want to minimize uplight to oncoming drivers. Here is a pic of halogens vs Morimoto XB headlights, notice the raised box above the cut off on the halogen side. That is the uplight.
    Joe671[QUOTED] likes this.
  10. Oct 13, 2019 at 2:20 PM
    #1610
    tmartin110
    tmartin110 Member
    Northern VA
    Can someone help me with an install question? 2019 Off Road
    I purchased the GE +130s. https://www.amazon.com/GE-Megalight-Ultra-Headlight-53110XNU/dp/B06XRS9LBR
    However they are not fitting in two locations. I've installed headlights before so this is not something new.
    One of the three outside tabs on the GE (right) are reverse from the stock (left) bulb. Is this normal? A fix?
    The internal tab on the GE is bigger, is this what users are "trimming"? See yellow
  11. Oct 13, 2019 at 2:26 PM
    #1611
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Did you accidentally take out the hi beam H9. I did that at first not paying attention
  12. Oct 13, 2019 at 2:35 PM
    #1612
    tmartin110
    tmartin110 Member
    Northern VA
    Annnd... I'm an idiot. I will leave this post up for others to learn from stupidity.
    Thanks El Duderino
    They are plug and play.
  13. Oct 13, 2019 at 2:38 PM
    #1613
    El Duderino
    Jeremy
    HI->PNW
    Glad it was just that.
  14. Oct 13, 2019 at 2:51 PM
    #1614
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yep, this. The other bulb pictured is an H9. @tmartin110 you removed the wrong bulb.
    Edit! Slow on the updates apparently! Glad @El Duderino had you covered!
  15. Oct 13, 2019 at 3:15 PM
    #1615
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I will say, I was not initially a huge fan of the GE 130s bc while they were definitely bright, the color temp was slightly too high and washed out for my liking... but I’ve found that the Nokya 2500 yellow bulbs in the OEM fogs + the GEs are a perfect combo for my needs.
    I’d actually love to see some crash testing on those Nokyas. I know they are coated and that reduces output but last night I turned only my fogs on in my neighborhood and that yellow light seemed to carry for ever and the yellow of those lights kind of seems to fill in what I felt was missing with the GEs alone - for my eyes anyhow. I hate any light temp that gets even close to “daylight” white and find it far more distracting than helpful.
    skierd and replica9000 like this.
  16. Oct 13, 2019 at 6:32 PM
    #1616
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The GE Xenons +120 or Philips H9s give a lower color temp and higher output for headlight options (only slightly lower in the case of the Xenons), which you may find more pleasant.
    What would you want to see tested? They will be lower output than stock but more ideal color for poor weather use. I could provide specs on filtration loss and color temperature. If/when I do a run of glare capped H9s for extreme fogs, Nokya does offer a 2500 yellow H9 which would be significantly higher output than the H11 version.
    I agree warmer color temps are better for driving, and yellow for fogs is most ideal. I run the Rigid Selective Yellow LED fogs and have been very impressed by them, I'm looking forward to their new 360 4" round model which specs significantly higher output than the existing D-series I am currently running.
  17. Oct 13, 2019 at 6:56 PM
    #1617
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I'm seeing the gears turning in Crash's head.... "hmmmm, how do I setup one of those hollywood rainmakers so I can have a consistent test environment for rain." :)
  18. Oct 13, 2019 at 7:12 PM
    #1618
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Indoor fog maker. ;)
  19. Oct 13, 2019 at 7:20 PM
    #1619
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    I have the XenCN H9 2300k bulbs in my TRD fogs and they also do a great job at both punching through bad weather and fog as well as being less distracting than white bulbs when run in conjunction with low beams. Yellow compliments the stock halogen color well.
  20. Oct 13, 2019 at 7:29 PM
    #1620
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Aren't you running those in the Subaru fogs?
