3rd Gen Hood
Discussion in '3rd Gen. Tacomas (2016-2023)' started by justinlj93, Jun 29, 2018.
  1. Jun 29, 2018 at 11:13 AM
    justinlj93
    justinlj93 [OP] Well-Known Member
    Justin
    2017 MGM Tacoma TRD off road 4x4
    Anyone ever notice how thin these hoods are? I can see the center of it bouncing while just driving down the road. Also pretty scary to watch how much it bends going through a car wash when you get to the dryers.
  2. Jun 29, 2018 at 11:14 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Check that the bond hasn't failed between the skin and support. Known problem with the earlier non-skewp hoods.
    justinlj93[OP] likes this.
  3. Jun 29, 2018 at 11:16 AM
    justinlj93
    Justin
    Will do, this is my first taco so didnt really know if this was normal. Are they aluminum?
    tonered likes this.
  4. Jun 29, 2018 at 11:19 AM
    psmura
    psmura Well-Known Member
    Paul
    Syracuse, NY
    2018 TRD OR MT
    No they are not aluminum, damn thing is too heavy anyways.
    I have to take a look at my hood supports as well, but I haven't noticed any flexing yet.
    This is a known problem, some have gotten theirs repaired or replaced by the dealer. Some just fix it themselves. I wouldn't recommend using the dryer at the car wash will likely make the problem worse.
    justinlj93[OP] and tonered like this.
  5. Jun 29, 2018 at 11:19 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I wish, but they are steel. There was a process failure when doing the bonding. You might be able to see if some came free looking under the hood.
  6. Jun 29, 2018 at 11:23 AM
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
  7. Jun 29, 2018 at 11:24 AM
    justinlj93
    Justin
    I wont be anymore, i remember sitting there thinking any moment this paint is going to chip off because of how steep it bent.:D
    psmura[QUOTED] likes this.
  8. Jun 29, 2018 at 11:29 AM
    N2DesignsInc
    Los Angeles, CA
    Post #89, in that thread I linked above is my post with the easy solution without a dealer and better long life results than the dealer using the same OEM gunk...this stuff I suggest is NOT susceptible to weather...
    tonered and justinlj93[OP] like this.
  9. Jun 29, 2018 at 11:42 AM
    psmura
    Paul
    Syracuse, NY
    2018 TRD OR MT
    Seems like a big complaint is worry about the dealer not fixing the hood properly with the sealant. Your truck is a 2017, I would bring it in to them an make them fix it.
    I bought a new truck so I didn't have to worry about repairs.
  10. Jun 29, 2018 at 11:49 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I don't necessarily disagree, but I did fix a several minor issues at home (loose u bolts and door panel, A pillar, cab mount, and leaf spring squeaks). It was easier and faster than driving to the dealer and waiting.
