3rd gen + ICON 2.5 Coils - front end clunk over speedbumps
Discussion in 'Suspension' started by 0210, Sep 20, 2016.
  1. Sep 24, 2016 at 2:32 PM
    0210
    0210 [OP] Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Here's a vid showing the driver's side shaft, and then the passenger's side shaft for comparison:
  2. Sep 24, 2016 at 2:45 PM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Since your shock is leaking the dividing piston isn't were it should be in the reservoir so as you go over bumps the piston hits the end of the can and cause a clunk. That's my bet where the noise is coming from.
    CharlieCafe and 0210[OP] like this.
  3. Sep 27, 2016 at 2:49 PM
    0210
    Vancouver, BC
    Very newbie question:
    If it comes down to removing the coilover and shipping it off to ICON, can someone sanity-check the following approach?
    - loosen lug nuts
    - jack truck up
    - set on stands
    - remove wheel
    - loosen & remove bottom shock mount bolt (19mm)
    - loosen & remove three upper shock mount bolts (14mm)
    - take shock out
    - put wheel back on and hand-tighten lug nuts
    Reverse the process when the rebuilt shock arrives.
    Sounds simple enough, but am I missing anything? Anything to be aware of?
  4. Sep 27, 2016 at 5:58 PM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    You'll have to also either. Disconnect the tie rod. Or upper ball
    Joint or lower control and to finagle the coilover out
    Arcticelf and 0210[OP] like this.
  5. Sep 27, 2016 at 6:21 PM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    I'd disconnect the upper ball joint and sway bar from the spindle. Otherwise, yes that will work. But the truck will be sitting on the bump stops until you get the shocks back.
    0210[OP] likes this.
  6. Sep 27, 2016 at 6:30 PM
    eppy
    eppy Well-Known Member
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Homer M3 thin lip Satoshi, BAMF Light Bar, BAMF Batwing Tie Downs, Coupe Custom Battery Hold Down, Mattgecko Bed light kit, nj636 hub/wheel bearing set-up,Shorty Antenna, JL Audio & Boston set-up, 4x4 switch light MOD, Icon 2.5 coil overs and rear shocks, All Pro flip kit, Wheelers AAL, OcTaco SS brake lines, Light Racing UCA's and custom 6 speed Ellis Precision Shift knob. Coupe modified short shifter, AISN clutch pack, URD TOB kit, and Sachs flywheel. Mobtown's rocking tailgate skin!
    Man hate to say it but i'm starting to be a little suspect of Icon myself. Sent my 2.5 coil overs back to be rebuilt and they replaced the Pistons and seals and didn't address the thread locking nut that was rusted in place, after I requested it. Received them back and called them and they informed they couldn't even find me in their system. After providing my info, they did say to send them back, but I said screw it because It would have taken another week or so to get them back. Now it hasn't even been been a year and 350 bills later you guessed it, clunking back and found they are leaking. So what now, drop another 1500 bones? I'm Seriously considering another vendor, just not sure what options are best because my rear shocks our ICON also!!! Frustrating for sure
  7. Sep 28, 2016 at 5:55 PM
    0210
    Vancouver, BC
    Tried to get this rebuilt at an Icon-suggeted shop 3hrs away, but the folks at Icon could never reach the shop (despite them picking up on the first ring every time I called - on the phone number Icon gave me), so two days were wasted in endless calls to Icon for status updates. Took the coilover off today and shipped it to Icon. Now it's a waiting game with no vehicle to get around in. Frustrating to say the least.
  8. Sep 28, 2016 at 6:06 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    I was going to say your shocks are topping out. Like the OME 885 issue. Then thought LCA alignment cam bolts or sway bar link or brackets. Now that you know you have a leak I'd say the topping out caused the leak, I don't think the leak started the symptoms
  9. Sep 28, 2016 at 6:15 PM
    0210
    Vancouver, BC
    If they were topping out I'd have known about it way, way before the leak started. I was feeling a change in front-end comfort (getting rougher) for a few weeks prior to the start of clunking. The other side is perfectly fine, too. It all started with the leak.
  10. Sep 28, 2016 at 6:31 PM
    eppy
    Rob
    Maryland
    05 V6 TRD OFFROAD
    www.iconvehicledynamics.com, if you guys are listening "Customer Service Is Everything" and the sub par service you're providing is getting old quick!!! :evil:
  11. Oct 11, 2016 at 6:30 PM
    0210
    Vancouver, BC
    Finally got the coilover back (two weeks downtime). Installed, no more clunking. Glad this nightmare is over.
    deeezy likes this.
  12. Oct 11, 2016 at 7:43 PM
    eppy
    Rob
    Maryland
    05 V6 TRD OFFROAD
    That's Good to hear man and glad they finally squared you away and hope they hold up for ya! As far as I'm concerned though, I'm really considering purchasing the Fox shocks because they stand behind their product 100%. Really sucks too, because I love everything else about ICON.
  13. Oct 11, 2016 at 7:59 PM
    0210
    Vancouver, BC
    I'm really hoping these shocks last a reasonable length of time between rebuilds. I've read about people going 5+ years without issues. Really, really hoping I just got very unlucky and it won't happen again. Rebuild kits are cheap, so after the 1 year warranty ends I'll be keeping a few of those around just in case. Any future rebuilds (out of warranty) will be done locally.
    FOX sounds like a very good option. Let us know how they work out for you!
  14. Oct 11, 2016 at 8:02 PM
    eppy
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Will do
  15. Oct 12, 2016 at 6:56 PM
    #35
    0210
    Vancouver, BC
    I now have a horrible squeak from the front suspension - driver's side, where the new coilover is. It happens at all speeds, over seemingly minor road imperfections (but not on larger ones like pot holes). Happens when stopped and turning wheels, too. Squeaks even when parked and I push down on the truck with my hand. Loud enough to turn heads on the street.
    I just re-torqued every bolt I touched. Still squeaking. Anyone have an idea of what to check next?
  16. Oct 12, 2016 at 7:02 PM
    #36
    0210
    Vancouver, BC
  17. Oct 12, 2016 at 7:13 PM
    #37
    0210
    Vancouver, BC
    Maybe the spacers in the lower shock mount need to be greased? I don't think (?) they were greased originally, but that's all I can think of.
  18. Oct 12, 2016 at 8:15 PM
    #38
    0210
    Vancouver, BC
    Drove around for a bit after re-torquing and the squeak went away - guess things "settled".
  19. Oct 13, 2016 at 2:54 PM
    #39
    0210
    Vancouver, BC
    Celebrated too soon. Squeak is back.
    Here is me pushing down on my sliders and the resulting noise:
    There is also a cyclical nocking noise when driving, and resulting "thump" felt in the pedals, dead pedal, and steering wheel. Seems to be correlated to speed, but not to road imperfections (at least the bigger ones that I can spot/see).
  20. Oct 13, 2016 at 3:08 PM
    #40
    0210
    Vancouver, BC
    Chatted w/ ICON - they say to put some miles on the truck. Apparently this happens once in a blue moon (my luck just keeps on going) and ~200miles or so should sort it out. They say it's the seal making the noise? I forgot to mention the nocking when talking to them...
