3rd gen JBL audio sub install?
Discussion in 'Audio & Video' started by JTeezy, Feb 24, 2018.
  1. Feb 24, 2018 at 10:24 AM
    JTeezy
    JTeezy [OP] Member
    '17 TRD Sport
    Hey all, found a lot of good info on how to install a sub on a non-jbl setup.
    I just got a 2017 double cab tacoma, with the JBL sound system.
    I have one of those box/amp combo all in one unit
    I cant find any info on how to connect the factory headunit up to this.
  2. Feb 24, 2018 at 10:48 AM
    Falconsfan
    Falconsfan Well-Known Member
    2017 sr dcsb v6 4x4 black
    Doesn't the jbl come with a factory sub? Anyways you would either need a line out converter to convert hi level speaker wires to low level inputs for the amp, unless that sub has high level inputs, u will have to search or someone else may know the wires but just tap the wires to one of the rear door speakers. Of course you still have to run power and ground wires, but I assume u can handle that.
  3. Feb 27, 2018 at 8:34 AM
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    I'm in the same boat... I have an 18 with JBL and want to replace the factory sub with a Kicker Hideaway or similar and place it under the passenger seat to get back that storage space behind the rear seats.
    I had a Kicker Hideaway in my 13 WRX hatch and it was great for 25mo until the sub died all of the sudden, but I'd still get another.
  4. Mar 4, 2018 at 1:41 PM
    kaiandersom
    kaiandersom Active Member
    Kai
    Utah
    2018 Cement TRD Off-Road
    The JBL in my 2011 Camry gives way more kick than the JBL in my 2018 Tacoma, what gives? I am also looking for a better sub solution but everything I find is for non-JBL...
