3rd Gen JBL Subwoofer Upgrade
Discussion in 'Audio & Video' started by badfish_55, Oct 8, 2018.
  1. Jul 31, 2021 at 3:17 PM
    #41
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Very big difference
  2. Jul 31, 2021 at 3:26 PM
    #42
    quip11
    quip11 Member
    Thanks @destin_meeks. What’s the difference besides price? Ease of installation? Simplicity? What do you prefer if it was yours?
    My goal is to replace all speakers including the jbl sub, adding an amp to run them all.
  3. Aug 1, 2021 at 6:23 AM
    #43
    destin_meeks
    Destin
    Tuscaloosa, AL
    For the JBL system, just ignore the lc7i
    you want either the AmpPro or the Rockford DSR1
    These two talk to the digital signal the radio is sending to the JBL amp, decode it, and create full-signal pre-outs to allow you to hook up your new amp. They also have harnesses that allow you to wire your amp to the existing speaker wiring so no need to cut/splice
    badfish_55[OP] likes this.
  4. Aug 1, 2021 at 11:53 AM
    #44
    quip11
    quip11 Member
    Wow, I was unaware of the Rockford DSR1 until you mentioned it @destin_meeks. I've researched both, and only main difference I can see is the DSR1 have options to configure it from your tablet or smart phone, which I like. Is there anything I missed? Do you prefer one or the other?
  5. Aug 1, 2021 at 11:57 AM
    #45
    destin_meeks
    Destin
    Tuscaloosa, AL
    The DSR1 is also an entry level DSP, where as the AmpPro is not. It just creates flat signals
  6. Aug 1, 2021 at 12:04 PM
    #46
    quip11
    quip11 Member
    DSR1 is entry level DSP because it only creates flat signals?
  7. Aug 1, 2021 at 12:06 PM
    #47
    quip11
    quip11 Member
    Does AmpPro give all full range signals?
  8. Aug 1, 2021 at 12:21 PM
    #48
    destin_meeks
    Destin
    Tuscaloosa, AL
    A DSP allows you to adjust the EQ for each speaker, time alignment, etc. it’s an entry level DSP because it’s all relatively limited in the controls and adjustments that can be made
    The amppro creates a flat full range signal (no EQ, time alignment, extra signals like door chimes or anything
  9. Aug 1, 2021 at 3:36 PM
    #49
    quip11
    quip11 Member
    thanks for your reply, much appreciated. amp pro it is
  10. Oct 19, 2021 at 9:40 AM
    #50
    Jpt99
    Jpt99 New Member
    2017 Tacoma Off Road
    2017 with JBL. I have a D.4.800. What’s the best way to integrate this bad boy? Couldn’t I just tap post jbl and use summing feature?
  11. Jan 3, 2024 at 9:15 PM
    #51
    RealHappyPappy
    RealHappyPappy Member
    2022 4x4 TRD Off-Road - Lunar Rock
    TRD lift with heritage grille OTT mild/medium Nitro Gear stub axle bushing
  12. Jan 4, 2024 at 5:22 PM
    #52
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    nope. the radio 'talks' to the oem amp with a coaxial audio signal. you could attempt to use an LOC on the factory sub wiring to feed into the new amp, but you'll still be left with all the factory audio processing that's been specifically implemented for the factory gear, which might not work great on other gear.
