3rd Gen leaky 3rd brake light
Discussion in 'Georgia' started by TacoGoblin, Oct 30, 2019.
  1. Oct 30, 2019 at 1:19 PM
    TacoGoblin
    TacoGoblin [OP] Active Member
    Powder Springs, GA
    2017 TRD off road 4x4
    Hey guys,
    After doing some research, I found its pretty common for some 3rd gen models to leak water into the cabin from the 3rd break light. Mine being one of these.
    Just curious to see if anyone in the area has also had this issue and how you went about getting it repaired? I'd prefer to take it to a Toyota dealer that has resolved this issue before.
    Thanks in advance!!
    *pic for attention lol
  2. Oct 30, 2019 at 1:26 PM
    DUCKSURF
    DUCKSURF Well-Known Member
    JOE
    Wayne PA
    2017 TACOMA DC SUPER WHITE
    I took my 2017 in for the leaky 3rd brake light and they said it was a known problem and fixed under warranty.
    TacoGoblin[OP] likes this.
  3. Oct 30, 2019 at 1:32 PM
    TacoTaco24
    TacoTaco24 Wet behind the ears.
    Patrick
    Flowery Branch, GA
    2017 MGM DCSB
    Lucky for me it has yet to happen! Fingers crossed it stays that way. :fingerscrossed:
  4. Oct 30, 2019 at 1:52 PM
    PacotheTaco17
    PacotheTaco17 Shake 'n Bake
    Caleb
    GA
    2017 TRD S 4X4 DCSB MGM
    I thought I was exempt as my 2017 didn't leak for the longest time. Of course once it did start leaking (65k miles) I was out of any form of warranty. Just bought the updated part and swapped it out myself.
  5. Oct 30, 2019 at 4:58 PM
    TacoGoblin
    Powder Springs, GA
    So you just bought the 3rd brake light assembly replacement and that stopped the leak?
  6. Oct 30, 2019 at 5:04 PM
    PacotheTaco17
    Caleb
    GA
    Correct. The issue was just with the shape & seal of the light against the cab from what I understand. The replacement was a bit of a pain but I have not experienced any leaks since. It's also worth noting that I only noticed the leak during a hell of a rain storm, no telling if it was leaking a smaller amount during car washes or lighter rain prior to that event.
  7. Oct 31, 2019 at 7:41 AM
    TacoGoblin
    Powder Springs, GA
    Update:
    Took the truck into Cobb County Toyota this morning. Service adviser said he had seen it before and they usually have someone come in about once a month with this issue. Truck is a 2017 with about 26k miles so is still under basic warranty. Will update again when I get the truck back!
    PacotheTaco17 likes this.
  8. Jan 20, 2020 at 8:07 AM
    Chrisdavenport2013
    Chrisdavenport2013 Well-Known Member
    2016 Quicksand Tacoma
    My 2016 just started leaking. Got in it after a night of rain and the roof was wet and the rear passenger seat was wet. Must have let a decent amount of water in. Trying to decide if I should just buy a new assembly and do it myself. 51k miles on the truck but I bought it new, idk if there’s any warranty on it or not.
  9. Jan 20, 2020 at 8:10 AM
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    OP has disappeared into the sprawl around Town Center and hasn't returned. Why didn't we send a search party?
    HashTaco and TacoGoblin[OP] like this.
  10. Jan 20, 2020 at 8:10 AM
    sorevilo
    sorevilo Well-Known Member
    How do you pull these lights out, I don't see any screws, is it just clips that hold it in place?
  11. Jan 20, 2020 at 8:16 AM
    THE_KiRRAx
    THE_KiRRAx Well-Known Member
    Tampa, Florida
    2016 BBP Tacoma SR5 DCSB
    IIRC they're screwed in from the back side. You need to drop the headliner to get to the assembly to remove it.
  12. Jan 20, 2020 at 8:36 AM
    Chrisdavenport2013
    that sounds very involved
    sorevilo likes this.
  13. Jan 20, 2020 at 9:29 AM
    Chrisdavenport2013
    Dealership just quoted me $400 to replace the bad gasket.
  14. Jan 20, 2020 at 9:30 AM
    Chrisdavenport2013
    After reading a few other threads I’m now very worried about mold. Going to check it out during lunch.
  15. Jan 20, 2020 at 2:08 PM
    THE_KiRRAx
    Tampa, Florida
    It is. I thought it required removal of the upper portions on all 6 pillars, the box in front of rear view mirror, and few other things. Not saying it's hard, just quite a few parts, just need time and patience.
    I also think that's why MESO designed his brake light replacement to be able to be removed from outside (after the initial installation of hardware). Future ease.
  16. Jan 20, 2020 at 5:29 PM
    Chrisdavenport2013
    Dealership quoted me $400 to replace. I know it’d be way cheaper to do myself but I’m scared to mess with all the airbags in the pillars. Just gonna let them do it......
  17. Jan 30, 2020 at 11:33 AM
    TacoGoblin
    Powder Springs, GA
    Looks like i forgot to provide a final update..Sorry guys!! Cobb Toyota replaced the entire 3rd brake light assembly no charge and haven't had any issue since! Less of a headache than I thought. Good luck to all of you having the same issue!
  18. Jan 31, 2020 at 8:48 PM
    Chrisdavenport2013
    I ended up paying $450 for the dealership to fix it.
  19. Jan 31, 2020 at 8:48 PM
    Chrisdavenport2013
    And now have a stained headliner
  20. Jan 31, 2020 at 9:01 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Should be able to handle that with some carpet cleaner spray.
