3rd gen LED turn signal problem
Discussion in 'Lighting' started by travisw87, Feb 10, 2017.
  1. Feb 10, 2017 at 4:04 PM
    travisw87
    travisw87 [OP] Well-Known Member
    Travis
    McKinney, TX
    The Sandy Taco
    Hopes and dreams
    I installed LED lights all around about a week ago including signals. Turn Signal speed would be normal unless any headlights were on. I ordered LED resistors from diode dynamics and have installed them at each signal bulb. The issue I am having now is that the signal speed is normal when headlights are on. Now when my headlights are off, when i signal, it will blink once and stop. I have tried googling this but only come up with hyperflash issues. Has anyone ran into this? Any ideas??
    Thanks!
  2. Feb 10, 2017 at 8:06 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Remove the rear tail light resistors, leaving only the fronts installed. Try again
  3. Feb 10, 2017 at 9:22 PM
    travisw87
    Travis
    McKinney, TX
    The Sandy Taco
    Hopes and dreams
    Actually installed the front ones first and tested to see if I still got hyperflash with the headlights on, which I still did. Did not want to install any on the rear if I didn't have to. :(
  4. Feb 11, 2017 at 10:12 AM
    1WhiteTruck
    1WhiteTruck Well-Known Member
    FL
    2017 4WD Sport
    Which wire's on the taillights did you tap?
  5. Feb 11, 2017 at 10:20 AM
    MESO
    State of Jefferson
    Weird. Install 1 set of lights/resistors at a time to diagnose the issue-start with the fronts.
    Are you tapping the load resistor on the correct wires?
    I had the same issue..rear turn signal would blink once then off completely.
    I already had Resistors up front and ended up not even using the rear resistors..was causing an overload..so I left them disconnected. Works perfect.
