3rd Gen, Lift, 33's, CMC, Lessons Learned
Discussion in 'Suspension' started by Radio TRD, Jun 10, 2019.
  1. Jun 10, 2019 at 12:04 AM
    Radio TRD
    Radio TRD [OP] Member
    2017 Black TRD Sport
    I recently lifted my 2017 Tacoma and gained much of the info I needed from this site. After running into problems, I just wanted to share some of my lessons learned.
    First thing I would like to address is the Cab Mount Chop (CMC). If your planning on 33’s or bigger and are asking “do I need a CMC”? The answer is yes in almost all cases. In fact, this should be your first mod before you install the first part of your lift (IMHO). A big thanks to @Texoma for hooking mine up!! If you want things done right the first time, he is the man!
    If you want your finished truck to drive properly, plan on Upper Control Arms (UCA). It is my opinion that the stock Tacoma has barely enough caster to accommodate the stock height with stock tire sizes. As soon as you lift at all, you start to loose caster and if your adding bigger tires, (33>) you going to need it. In fact, if you want the truck to track comfortably with 33s or bigger, you need at least 3deg positive caster and up to 4 if you can get it. This will generally not happen with stock UCAs at 2” or more lift. Anything less will give you varying degrees of wandering and bump steer. This may also present as a steering vibration as the front wheels attempt to track on uneven pavement.
    Trust but verify!! I did most of this work myself but allowed a trusted friend (who owns a well-known shop) to install my UCAs and align the truck. After experiencing severe steering issues, I took the truck home and pulled out the UCA’s. I found the uniballs were so tight that they could not be moved without extreme persuasion. This was causing no return in the steering after a turn. I also found that his mechanic used no grease of any kind in the pivot bushings. I removed the zerk fittings and they were totally dry. I was told that my alignment numbers were causing the problem and “when you lift trucks they all drive like crap”. A little dry lubrication (Tri-Flow) in the uniballs, some PTFE grease in the pivots, and everything works like it should. After a proper alignment with the caster set at 3.1 on each side, the truck tracks better than the day I bought it and the steering returns to center as it should. No, they all don’t have to drive like crap.
    Spend the money and get a good balance for your new wheels and tires. This will save you a lot of headache later. My “friends” mechanic did mine and they were completely off.
    Proper wheel backspace and offset will help avoid UCA and other clearance issues. Wheel spacers will only create other potential complications/hazards. Fortunately I got this right the first time.
    Tire pressure is subjective. 35 psi is a good starting point and adjust as needed.
    I am not claiming to be an expert here and I am sure that opinions will vary. I am just sharing my experience for those that may be looking for the information.
  2. Jun 10, 2019 at 12:07 AM
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    This should be mandatory viewing for all new members
    good write up
  3. Jun 10, 2019 at 12:25 AM
    Radio TRD
    My friend helped me out a lot by getting me some good prices on parts and I appreciate it. His mechanics caused me a lot of headaches though.
    In the end @Texoma set me straight. :bowdown:
    Beretta4x4 and Texoma like this.
  4. Jun 10, 2019 at 12:48 AM
    bs63366
    bs63366 Well-Known Member
    San Angelo
    2014 Tacoma TRD Off Road DCSB
    ARE Z-series shell, ImMrYo mirror lift, always on fog-lights.
    Good write-up and glad that you were able to get it all sorted, working properly and looking good :thumbsup:
    Beretta4x4 and Radio TRD[OP] like this.
  5. Jun 10, 2019 at 1:13 AM
    Bdubz
    Bdubz Member
    2017 blazing blue TRD 4x4 off-road
    Excellent write up. I had buddies tell me all kinds of avenues to lift my truck, and many "Trust me"'s thrown in there, especially the friends who want me to do giant spacer lifts....After trial and tribulation with lifting my 4Runner, I decided to build a plan and parts before embarking on my lifting journey. These days I mostly disperse camp with the wife and travel on fire roads etc in the mountains for camping, however we do desert camp in the winter, so we see a lot of washboard and sand roads/arroyos. That being said, I don't plan on doing very technical 4x4 over landing driving just medium duty stuff. When I was younger I had the nerves for double black diamond trails growing up in Colorado, and conquered most of them, but I don't like nearly sliding off cliffs while trying to maneuver on 3 wheels anymore over boulders. I have had a wonderful life so far and have "Conquered" what I wanted in life, and more than most, but I now want to "enjoy" my excursions without the "Conquering" aspect involved. Below is my medium duty daily driver lift plan. I need more clearance! And a pinch more of articulation......Feel free to reply with advice!
    1. I bought B8 5100's (2.75" adjustable height) front shocks and 5100's for the rear with 1" lift
    2. I have a bad ass Tig Welder and will be doing my CMC myself
    3. Bought a set of OME medium duty springs for the rear ( 240# Tepui RTT, camp kitchen and gear in back) ( possibly switching to SloopImports aluminum cab shell with aluminum clamshell tent instead)
    4. Will be ordering a set of BFG KM3's 285/75/17 ( love my 265/75/16 KM3's I have now )
    5. Will be ordering a set of Method wheels with offset (don't know offset yet, still researching the style)
    6. Possibly buying a set of bump stops
    7. Will be changing gears to 5:29 possibly?
    8. Bed stiffeners
    Radio TRD[OP] likes this.
  6. Jun 10, 2019 at 5:36 PM
    Radio TRD
    I didn't see UCAs on your list. My opinion is do them at the same time and enjoy the more comfortable steering that the added caster will give you.
  7. Jun 10, 2019 at 5:55 PM
    Cheftaco
    Cheftaco New Member
    New York
    2016 trd super white off road access cab
    Ads 2.5 coil overs front and rear 255/85-16 Decked drawers Leitner roof rack
    Great write up, would you mind sharing your selected parts for the build out. I’m thinking fox 2.0, total chaos UCAs and aal leaf for the rear with a fox rear upgrade in the future. I will still
    Need to do the body chop? I would like to run 285/75/16.
  8. Jun 10, 2019 at 10:05 PM
    Radio TRD
    This is the set up I have. Of course there are many other ways to go but (IMHO) CMC and UCA's are a must.
    My parts list:
    Cab mount chop (just get it done)
    Fox 2.0 coil-overs in front
    Fox 2.0 shocks in the back
    1 inch lift blocks in the rear but will probably change out to a Deavers leaf pack in the future.
    Icon tubular UCA's with unibal. (Might change out to Icon Delta Joints in the future)
    17” Method NV 305’s with 0 offset
    Nitto Ridge Grapplers 285/70/17
    My alignment:
    Camber .2(L) .5(R)
    Caster +3.1 (L/R)
    Toe .05(L/R)
    Sharp Tacoma likes this.
  9. Jun 11, 2019 at 8:12 AM
    Diverjesse
    Diverjesse Member
    Jesse
    New Orleans, LA
    2018 White Tacoma TRD Off-Road 4x4 DCSB
    I’ve been working out of town for the past 5 months. I’ve also been ordering parts for my truck this whole time!
    Build list so far...
    1. Accutune kings 2.5 extended travel front and rear.
    2. Archive garage Ubolt flip kit
    3. RXT leaf pack
    4. Total chaos CMC
    5. Low range off road front diff drop kit.
    6. ICON tubular UCAs with delta joints
    7. Rough country speedo correction module
    8. I have a set of level 8 17x9 -12mm wrapped in 285/75 R17 Nitto terra grapplers that I’ll put on.
    I’m going home in a few days and I’m gonna install it all.
    I want to get method NV bronze rims -12mm offset but I’m having trouble finding them
  10. Jun 11, 2019 at 4:10 PM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    100% on point. I did my truck in the same order and avoided all the head aches others enter. A good peice of mind is to do the ECGS bushing, when installing the lift. Truck looks great.
    Did in this order
    CMC
    Cam tab gussets and regreasing cams and bolts.
    ECGS bushing
    OME HD Lift w/ Dakar
    285 on -10mm
    Alignment specs
    Toe 0
    Caster 3.5
    Camber 0
    Thrust Stock
  11. Jun 11, 2019 at 4:14 PM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
  12. Jun 11, 2019 at 5:11 PM
    Radio TRD
    That should be a thread. List who does CMCs/welding in the different areas of the country and contact info. That would make it easy for everyone to get started. What do you think?
    Beretta4x4 likes this.
  13. Jun 11, 2019 at 6:55 PM
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    I did the spindle lift to achieve a 4 inch lift. No CMC was required with 33's. The fender flares had to be trimmed at the bottom. After 70,000 on the lift it still drives great! I went with Fox shocks and the Dakar Leaf Pack. I will need new Nitto Trail Grapplers in October as they have 70,000 on them now. By the time they get replaced it will be close to 80,000 miles. I realize 3rd generation might be a little different.
  14. Jun 14, 2019 at 3:51 PM
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    @Radio TRD what'd you end up getting for that suspension and what'd it run ya?
  15. Jun 14, 2019 at 7:55 PM
    Radio TRD
    I listed the parts in the post above. I can't remember off the top of my head exactly how much I paid but close to $3800 for everything including wheels and tires.
  16. Jun 14, 2019 at 10:20 PM
    grubburg
    2019 TRD OR MT
    @Radio TRD well it looks badass, so well done
  17. Jun 15, 2019 at 1:13 PM
    Radio TRD
    Thanks bro!!!:thumbsup:
  18. Sep 19, 2019 at 4:21 PM
    Hemlocktherm78
    Hemlocktherm78 Well-Known Member
    Fairly newbie here. Are there pics of before and after CMC mods?
