3rd Gen Long Bed Manual Off Road Transmission Availability
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eddi0, Mar 10, 2025.
  1. Mar 10, 2025 at 11:38 AM
    eddi0
    eddi0 [OP] Member
    Tacoma newb here, trying to locate a 2018/2019 Long Bed, Manual Trans, Off Road and am starting to wonder if they even exist? Tons of double cabs but not access cabs.
    Is this a unicorn combo?
    Thanks!
  2. Mar 10, 2025 at 11:49 AM
    05w/FWC
    05w/FWC Active Member
    22 DCSB OR MT S/C W/ FWC
    Long bed does not exist in a manual when you have the double cab, access only or short bed.
  3. Mar 10, 2025 at 11:54 AM
    eddi0
    eddi0 [OP] Member
    Right so I'm technically looking for an access cab, manual, off road edition. Was that combo not popular or are owners of that combo just not selling?
  4. Mar 10, 2025 at 11:58 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Access cab manuals are only available in the TRD Sport in the US. Canada had the TRD OR access cab manual.
    RustyGreen and Gen3TacomaOBX like this.
  5. Mar 10, 2025 at 12:17 PM
    eddi0
    eddi0 [OP] Member
    Thanks. That explains why I can't find that combo in the US, bummer. Not sure if I can stomach an auto transmission :/
  6. Mar 10, 2025 at 12:29 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The ACLB Sport is very capable. I have had wheels off the ground and still had forward progress. The only difference that I have noticed is that ORs get more help at a lower RPM. The vacuum boosted system needs some revs to engage.
    Without mods, the OR locker only engages in 4Lo and from a full stop. So, there is that unfortunate limitation.
    I've seen stuck ORs and stuck Sports. No driveline stuff was getting us going.
    That said, if we had the option here, I would have gotten an ACLB OR MT. The LB was more important to me. Filled it hauling and it is where I sleep.
    RustyGreen likes this.
  7. Mar 10, 2025 at 12:33 PM
    eddi0
    eddi0 [OP] Member
    Appreciate the details.
    I'm not a huge fan of the looks of the 2nd gen which I've seen with that combo, so may go 2003/2004 but hard to find in decent shape.
    Car industries are slowly forcing us to auto transmissions which is a shame.
    Hardscrabble likes this.
  8. Mar 10, 2025 at 12:40 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Not sure I understand the resistance here...
    Buy a Sport, then toss an ARB locker in the rear (maybe one in the front too, while you're at it). Like said, you'll have a much greater control over that locker as well (you can use it in 4x4-HI or 2WD even, and it won't automatically disengage when you go over 30 MPH or however fast it is). You probably can get a Sport for cheaper than the Off Road (had it existed) too, That savings will help pay for the ARB.
    I originally wanted an Off Road myself, but looking back, I've actually been thinking that having been forced into a Sport with it's much simpler vacuum-assist braking system was actually a good thing (although I do wish I could get rid of the hill-hold assist thing on inclines that the OR & Pro don't have).
  9. Mar 10, 2025 at 12:40 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Assuming you are referring to the difference between TRAC and A-TRAC, I have to strongly disagree. I think there is very big difference between the two.
    I do however think you might be right that the vacuum booster could suffer more at low rpm.
    Keep in mind that A-TRAC can be disabled in order to use TRAC instead and this implies there are firmware differences between the two as well. I think of TRAC as on-road traction control and A-TRAC as off-road traction control.
    I also don’t consider the 4lo locker restriction to be an issue. If I’m in a situation where I want the locker, I’m already in 4lo as it’s near impossible to get over an obstacle in 4hi with a 6MT. Also, the locker provides only a slight advantage over A-TRAC and is very situational.
  10. Mar 10, 2025 at 12:43 PM
    Inyo_man
    Inyo_man Don't piss down my back and tell me it's raining.
    U.S.A.
    2023 Tacoma TRD, off-road, access cab
    I was under the impression that the access cab only came in a long bed...
    Cheers
  11. Mar 10, 2025 at 12:47 PM
    eddi0
    eddi0 [OP] Member
    I'm a bit of a stock purist hence the desire for OE rear lockers. In any case, thanks for the idea!!
