3rd Gen loose traction on wet roads
Discussion in 'New Members' started by vaca2016, Nov 21, 2024.
  1. Nov 21, 2024 at 1:23 PM
    vaca2016
    vaca2016 [OP] New Member
    william
    2016 Limited
    Our 2016 looses some traction on wet roads in the back, has good tires, 16 inch vs the 18 inch it was built with. Have not put in weight in the back like most suggest, and tire pressure is a little over 30, not high.
  2. Nov 21, 2024 at 1:39 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  3. Nov 21, 2024 at 2:10 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    A couple of things come to mind immediately. Is this your first truck? I ask because trucks don't act like cars, your weight is more front biased. This will affect rear traction, especially with an empty bed. Double cab/short beds are a little better weight balance, but not by much.
    Next, "a little over 30" sounds too low to me. Not knowing what you're running for tires makes this a bit difficult to call, but I'd think pressure should be in the 35-38 PSI range, maybe 40. If your tire pressure is too low, besides causing too much heat in the carcass, your tread may not be contacting the pavement fully, causing too little traction.
    SecureIT2021 likes this.
  4. Nov 21, 2024 at 2:31 PM
    wazepd
    wazepd Waze Map Editor
    NJ / NY
    2022 Tacoma TRD Off Road
    Commercial Pilot
    lower psi gives more tire contact, more psi means stiffer wheel and less contact
    3rd gen Door jams say 30 psi cold for stock tires
    easy on the throttle to accelerate on slick roads
  5. Nov 21, 2024 at 3:15 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Too low of pressure can cause your tire to lift the center of the tread...the opposite of too high.
  6. Nov 22, 2024 at 12:26 AM
    SecureIT2021
    SecureIT2021 Well-Known Member
    06 Tundra SR5 LTD CC 4.7 V8 AT 2WD
    Welcome :hattip:I've got 16" Hankook tires with stock wheels, I keep 35 psi all around and I adhere to a cadence of maintaining tire pressure, rotating the tires and keeping it properly aligned. To that end, traction hasn't been an issue for me.
  7. Nov 22, 2024 at 1:21 AM
    mike s
    mike s Well-Known Member
    South Carolina
    2019 TRD OR
    I think the brand of tire makes a difference in wet traction, Michelin is better than Goodyear which is better than Cooper in my experience
  8. Nov 22, 2024 at 8:22 PM
    vaca2016
    william
    2016 Limited
    Thanks for all the good info! Not my first truck, have a 2002 Ford F150 crew cab, it is more stable in wet weather. Tire pressure is about 34 cold. Tires are probably not the best but sure are good off road on the 5 acres of clay we have here in Northern CA. Tires are the usual light truck m+s. I have thought of adding some weight to the front of the bed as it is pretty close to the tires. When we are seeing a little tire spinning especially around corners, the car has just the driver, and possibly one passenger in the front, basically no extra weight on the back tires. If this is just another common thing to this year (2016) Tacoma, like the stiff ride, low head room, funky auto trans etc. then so be it.
    One thing for you guys, I bought the truck 2 years ago, soon discovered it would hardly run or not run after a rain of about 6 hours or more. Spent a lot of money on stuff like fuel pumps and elec control module before I decided to have the windshield replaced for $400. Bingo, that was it, water was getting under the dash, a very bad place to have water in todays vehicles!!
