3rd Gen Magnetic Gray Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Eric NJ, Oct 6, 2015.
  1. Dec 21, 2017 at 5:09 PM
    #5201
    Minimedic
    Minimedic Well-Known Member
    Tacoma DCLB OR MGM
    Got the lift, wheels and tires finally installed
    OME 888
    Bilstein 5100 @ 0
    Headstrong AAL
    Total Chaos UCA
    Icon Speed Six
    Nitto TG 295/70/17!
  2. Dec 21, 2017 at 5:22 PM
    #5202
    modifiedtaco
    modifiedtaco Well-Known Member
    Alex
    2016 Magnetic Gray Tacoma Limited
    Tuff Country 3 inch spacer kit with aal Tuff Counrty 1/4" spacer on LF (for taco lean) Bilstein 5160 rear shocks Bilstein 5100 adj front struts (removed tuff country front spacers) set to 0 lift OME 886 coil springs Front sway bar relocation bracket N-Fab Rock Rails 17x9 -12 Fuel Beast wheels Toyo AT2 285/70/17 tires Led light conversion on all interior lights Morimoto 35w HID kit 5500k OE all weather floor mats OE Tonneau cover OE Door Sill Protectors Bed Mat De badged all factory emblems matte black vinyl tailgate letter and Tacoma emblem on door silver vinyl insert on glove box and door sill protectors OME Carrier Bearing Drop Insain Fab cab mount chop plates Weathtech Rain guards
    any rubbing? I have a similar set up and have been contemplating 295's. What are your wheel specs? I have 5100 fronts with 886 coils and 5160's and AAL on rear also Ive done a cab mount chop. The reason I'm note sure is because I haven't replaced my uca's yet and not sure if I add them how much closer the tires will come to fender or cab mount
  3. Dec 21, 2017 at 5:23 PM
    #5203
    modifiedtaco
    Alex
    @Minimedic any pics straight forward that show how far the tires still out past fenders would be appreciated.
  4. Dec 21, 2017 at 5:30 PM
    #5204
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    .. Missing a Badass Slider on your great looking Tac. :thumbsup:
  5. Dec 21, 2017 at 6:58 PM
    #5205
    Minimedic
    Tacoma DCLB OR MGM
    My wheels are 17x8.5 0 offset. There’s a a little bit of rubbing but only in reverse turning to left and with compression but that’ll go away once I flatten the pinch weld. I would think that you’d definitely need to swap UCAs to correct caster. Which it’ll help bring wheel forward I believe.
  6. Dec 21, 2017 at 7:00 PM
    #5206
    Minimedic
    Tacoma DCLB OR MGM
    This is the best pic I have so far. I can take a better one tomorrow. It’s dark here now.
    arnette64, Mrshawz and TACO 12B like this.
  7. Dec 21, 2017 at 7:01 PM
    #5207
    Minimedic
    Tacoma DCLB OR MGM
    Thanks man. That’s the plan. Thinking of getting a set of BAMF sliders @ 10 degrees. So hopefully they can be improvised step also.
  8. Dec 21, 2017 at 7:07 PM
    #5208
    Kabogski
    Bote
    Los Angeles
    ...:bowdown: thats one of the good ones... nice!
    Pics once installed!
  9. Dec 21, 2017 at 7:15 PM
    #5209
    modifiedtaco
    Alex
    I currently have 17x9 -12.. but will be mounting tires on a set of 17x9.5 -18 wheels. as far as caster goes the only way to push tire forward is if you use light racing uca because you can max camber and caster positive using lower control arm cam bolts then correct your high camber by adjusting the ball joint on light racing arms.. all other aftermarket ucas pull the top of tire towards the rear to gain caster.. I test fit a 295/70/17 on my -12 offset wheels and cleared without compression before cab mount chop but since my ucas that I will replace my stock ones with wont be light racing arms I'm not sure I guess Ill find out soon enough
  10. Dec 21, 2017 at 7:21 PM
    #5210
    Stefan_Ray
    Stefan_Ray Tacoma TRD Life
    Stefan
    Concord,North Carolina
    2021 TRD Pro
    Cooper STT Pro’s
    I saw that thread as well. I’ve taken pictures of mine and looked at all angles and I don’t get results like yours above.
    17tacotrdor and TacoTuesday105 like this.
  11. Dec 21, 2017 at 7:41 PM
    #5211
    2k4Taco
    2k4Taco IG: Swannybruh
    Swanny
    Fleming Island, Fl
    16 DC TRD Offroad 4x4
    Icon 2.5s / 2.0's / //Dakar HD Pack//CBI T3 Front/ ATH HC Rear//SPC UCAs/ Camburg LCAs// MR312s w/ 34in Yoko GeoLndrs
    He is also in direct sunlight. My paint is the same.. though not as bad as the door....
  12. Dec 21, 2017 at 7:42 PM
    #5212
    Stefan_Ray
    Stefan
    2021 TRD Pro
    Cooper STT Pro’s
    I’ll take pics of mine tomorrow in the sun and see what happens.
    omg_miiiike and 2k4Taco[QUOTED] like this.
  13. Dec 21, 2017 at 8:13 PM
    #5213
    omg_miiiike
    omg_miiiike Well-Known Member
    Maryland
    2017 Tacoma TRD Off Road | DCSB
    Damn, yours looks good.. Wish mine was all one color LOL
    Stefan_Ray[QUOTED] likes this.
  14. Dec 21, 2017 at 10:15 PM
    #5214
    bacon_st
    bacon_st Well-Known Member
    San Diego
    16' Taco TRD sport
    Sorry for the slow response guys, thank-you for the complements.
    Yes, After the tires were put on, there was major rubbing both front and back.
    I took my truck to a local truck shop, and got CMC done and they also cut some portions of
    the inner fender well to avoid all the rubs, and gave back primed and painted black for $120, plates included.
    I picked my ray's to be matte gray color because I wanted it to contrast against the MGM.
    If I had chosen ray's in gun metal, then it would've been too much dark gray.
    Those wheels sat in my garage for over a yr and a half, I only bought new tires after I wore the factory ones off.
    The 285's are also wider, and w/o any spacers, all 4 tires stick out of the fenders about an inch and looks bad ass.
    Here's the difference b/w stock and 285's.
  15. Dec 21, 2017 at 10:40 PM
    #5215
    Stefan_Ray
    Stefan
    2021 TRD Pro
    Cooper STT Pro’s
    Time for a lift!
  16. Dec 21, 2017 at 11:27 PM
    #5216
    steveox
    steveox Well-Known Member
    steve
    2021 TRD Off-road DCLB.
    Rci rack on the bed, warrior rack over the cab. Sorry for the delayed response.
    sologeek[QUOTED] likes this.
  17. Dec 22, 2017 at 11:30 AM
    #5217
    rino
    rino Member
    Rin
    Asbury, NJ
    '17 TRD Off Road
  18. Dec 22, 2017 at 4:54 PM
    #5218
    Stefan_Ray
    Stefan
    2021 TRD Pro
    Cooper STT Pro’s
    @omg_miiiike @2k4Taco
    I couldn’t find any differences in mine.....
    Paint and color is even all the way around.
  19. Dec 22, 2017 at 5:03 PM
    #5219
    2k4Taco
    Swanny
    Fleming Island, Fl
    I'll take some pics of mine tomorrow. I've got some defects on my front fenders..
  20. Dec 22, 2017 at 5:16 PM
    #5220
    Stefan_Ray
    Stefan
    2021 TRD Pro
    Cooper STT Pro’s
    When I bought my truck I got all the stuff in the finance office. Car care package, tire and paint protection....
    Do you get that stuff? If so, Toyota will have to fix it for free. I like the paint protection because if anything happens, swirls, chips, discolorment or anything is 100% warrantied.
