3rd Gen Magnetic Gray Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Eric NJ, Oct 6, 2015.
  1. Feb 12, 2018 at 11:59 PM
    #5681
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    I don’t have all of those answers, I just know that a lot of 3rd gens get the vibe after lift. @SuperBad, can you offer some expertise? The ECGS bushing is a relatively easy/cheap replacement, I know that.
    It’s recommended to use coils for lift, not shocks. When you adjust the shock settings, you’re preloading the springs. It’s probably the needle bearing and there is lots of research on that within TW.
    SteelerJim[QUOTED] likes this.
  2. Feb 13, 2018 at 7:23 AM
    #5682
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    If you remove the lift it should go back to normal with no vibes. Vibes are usually caused by the shotty needle bearing or cv axle angle. Both are typically fairly easy fixes.
  3. Feb 13, 2018 at 7:49 AM
    #5683
    CherokeeCajun
    CherokeeCajun Well-Known Member
    KJ
    Oklahoma City
    2017 - MGM - Sport - 4x4
  4. Feb 13, 2018 at 10:26 AM
    #5684
    SteelerJim
    SteelerJim Well-Known Member
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    ARE Overland Topper, WeatherTech Mudflaps
    What brand and style are your running boards? I've been looking for some that don't stick down so far and those seem perfect.
  5. Feb 13, 2018 at 11:26 AM
    #5685
    2k4Taco
    2k4Taco IG: Swannybruh
    Swanny
    Fleming Island, Fl
    16 DC TRD Offroad 4x4
    Icon 2.5s / 2.0's / //Dakar HD Pack//CBI T3 Front/ ATH HC Rear//SPC UCAs/ Camburg LCAs// MR312s w/ 34in Yoko GeoLndrs
    Heres old girl with a little lift, bumper and tires.
    Soul Surfer likes this.
  6. Feb 13, 2018 at 11:54 AM
    #5686
    not0ny
    not0ny Well-Known Member
    2017 MGM TRD SPORT DCSB 4X4
    Bilstein 6112/5160 JBA UCA
    gunny1005 likes this.
  7. Feb 13, 2018 at 2:52 PM
    #5687
    scBryan7
    scBryan7 Well-Known Member
    Santa Cruz, CA
    2019 Cement Tacoma TRD OFF ROAD V6 4X4 ACLB
    SHELTON PAINTING
    I'm new. Figured I'd throw these up here... '17 SR5 2.7L 2WD. All I've done to it is plasti-dip all the chrome, threw a magnaflow muffler in there, and installed ladder racks and weatherguard toolbox )I paint houses for a living). Want to switch out rims and tires next... probably all terrains. Any ideas?
    Oh I popped off the SR5 emblem and dipped the Tacoma ones black which you can only see in one of the pics, the sunset one...
  8. Feb 13, 2018 at 3:21 PM
    #5688
    Moed
    Moed Well-Known Member
    Moe
    NY
    2019 DCSB TRD Sport
    Crap, it's already in the mail. After reading your next post I think I will wait. Keep us posted on the vibration issue.
  9. Feb 13, 2018 at 3:22 PM
    #5689
    odinsbro15
    odinsbro15 Well-Known Member
    Eric
    LOS ANGELES CA
    2016 Gray Tacoma trd offroad DCSB
    ROUGH COUNTRY FRONT 2 INCH LEVEL KIT, TINT, DIPPED RIMS, DITCH LIGHTS, CUSTOMER REAR FACING LIGHT, INTERIOR MATS
    i need a scooped hood BAD!!!
  10. Feb 13, 2018 at 3:39 PM
    #5690
    SteelerJim
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    There's another guy that posted a little after me that is having the same issue and he did the 5100s. After reading what a couple folks have responded to my post about the vibration/buzz in the steering wheel, I think it would have been caused by ANY lift. They all point to the needle bearing issue. And they go on to say it is an easy fix with the ECGS bushing. So I may have acted too quick on taking out my spacer lift in the front. It's your call at this point so you may go ahead and install it and see how it goes. Like I said in my original post, the spacer was only $59 so if yours rides fine with it or vibrates like mine does, no big deal. Let me know how your install goes and the ride quality afterwards. Take care!
  11. Feb 14, 2018 at 11:20 AM
    #5691
    micwillia
    micwillia Nonstop Tinkerer
    Cental Masshole
    Turd gen Inferno Taco TuRD OR DCSB 6MT, '96 Mustang V6 Vert 5MT
    Cubby Covers, TRD Pro Exhaust, BAK RevolverX2, Pro Skid, Speaker Upgrade, OBA/W, CB, 255/85R16
    Hey guys has any of you DIYers out there found an easily found spray paint that is a close match to MGM?
  12. Feb 14, 2018 at 11:44 AM
    #5692
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Marie at @HeadStrong Off-Road is the patron saint of TW.
  13. Feb 14, 2018 at 12:55 PM
    #5693
    SteelerJim
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    When you say it is not recommended to use shocks to lift... Who says that? I ask because the good folks at Headstrong sold me the 5100s I have ordered and did not at all try to steer me away from that setup. I told them my lift goals and they said that would work fine. Headstrong even offers a spacer kit to lift the front. So when you say that it's not recommended, who is not recommending it? Not being sarcastic just wondering why so many companies make the shocks/coilovers that lift by compressing(squeezing) the spring a little bit. I'm well aware that it will make the ride a little firmer the higher the setting(the more lift), but ALL lifts, outside of a top placed spacer will change the ride softness/harshness. My truck rides just fine with the Rough Country 1" spacer mounted on top of the stock coilover assembly. It gained 2" front lift with it. Didn't notice anything at all different outside of just riding higher. I made the post about removing it before I researched what was causing my vibration in the steering wheel. Others on here told me it was more than likely the needle bearing and that it is caused by lifting your front end. It was not caused by the WAY I lifted it. Just from lifting in general, is how I interpret what they said.
  14. Feb 14, 2018 at 2:31 PM
    #5694
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    looks sick. come spring im painting my 2nd gen skid when i do the liftdownloadfile-8.jpg
    ARCOVT16 likes this.
  15. Feb 14, 2018 at 2:38 PM
    #5695
    sorgon82
    Ont. Canada
    i agree. dont think you "NEED" 285's
    i plan to keep my 275 n run close to 3"lift
  16. Feb 14, 2018 at 2:48 PM
    #5696
    sorgon82
    Ont. Canada
    here you go bud, different truck but long bed with cap, no lift but larger 275 tires and 1.75 wheel spacersdownloadfile-9.jpg
  17. Feb 14, 2018 at 3:35 PM
    #5697
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The Pro Grille looks so good on MGM
    Soul Surfer[QUOTED] likes this.
  18. Feb 14, 2018 at 4:36 PM
    #5698
    shakerhood
    Southern Ohio
    Dupli-Color Perfect Match has MGM in a Spray, matches really good.
    mtip and Bertw192 like this.
  19. Feb 14, 2018 at 4:38 PM
    #5699
    dwill913
    dwill913 Active Member
    Dustin
    17 Off Road DC MT
    Bone Stock
    Nice setup. I like the toolbox and rack. Any issues getting them to work together? Is the box on top of the base of the front rack?
  20. Feb 14, 2018 at 5:02 PM
    #5700
    scBryan7
    Santa Cruz, CA
    SHELTON PAINTING
    Yeah it sits on the base of the front rack via Trac Rac's (manufacturer of the racks) mounting hardware.
    dwill913[QUOTED] likes this.
