3rd Gen Magnuson Supercharger Review & Discussion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OpelGT, Oct 3, 2020.
  1. Mar 17, 2021 at 6:51 PM
    #361
    sorevilo
    sorevilo Well-Known Member
    By the time I get mine hopefully v8 will be out or 9
    GoldenBrew and Jproz like this.
  2. Mar 23, 2021 at 2:24 PM
    #362
    blackmist27
    blackmist27 Well-Known Member
    17 Tacoma TRD Pro
    Leer shell 100XR
    my order is in... now the waiting game begins.
    Also is there an online DIY for removing the restrictor?
  3. Mar 23, 2021 at 2:37 PM
    #363
    OpelGT
    OpelGT [OP] hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    Congrats!
    It’s a 3 step process.
    1. Remove hose off of the bypass
    2. Grab brass restrictor with needle nose pliers and pull it out gently with a twisting motion
    3. Put hose back on.
  4. Mar 23, 2021 at 2:38 PM
    #364
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Congrats! This truck should be fun on forced induction. What is the predicted wait time?
  5. Mar 23, 2021 at 2:40 PM
    #365
    blackmist27
    17 Tacoma TRD Pro
    Leer shell 100XR
    Thanks!
    they told me 3-4 weeks. which isnt bad. I expect 5 weeks.
  6. Mar 23, 2021 at 2:56 PM
    #366
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    Any of you monitoring your Coolant Temp since SC install? I use a ScanGage II to keep an eye on Coolant Temp along Transmission pan and converter temp. Transmission temps have been fine but I have not towed yet - waiting on camper to arrive. Coolant Temps seem to move around a lot. I think the stock thermostat opens between 185 and 196. My operating temps are within this range but I noticed when coasting at low speed the temps range will jump to 202 and 204. ??? could it be the LTR blocking the OEM radiator and causing temps to run hotter? Over-flow is within spec for cold and hot and I've checked the radiator once it cools down and it is topped up. ??? Just curious what others are experiencing.
  7. Mar 23, 2021 at 3:06 PM
    #367
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Non SC here and fwiw, those temps are super routine for me. Even with the upgraded cooling fan.
    sorevilo and GoldenBrew[QUOTED] like this.
  8. Mar 27, 2021 at 8:10 AM
    #368
    WalkinTaco
    WalkinTaco Well-Known Member
    2018 TRD OR M/T
    Please let us know what you think after you drive it for a week or two. I think we'd all really like to hear some additional feedback from others who go SC. Having moved to CA recently, the SC being CARB approved/exempt is tempting.
  9. Mar 27, 2021 at 8:35 AM
    #369
    blackmist27
    17 Tacoma TRD Pro
    Leer shell 100XR
    I plan on making a video on it for sure... I want to share all my experiences with what is good and bad to help others make good decisions too. stay tuned ;)
    WalkinTaco[QUOTED] likes this.
  10. Mar 27, 2021 at 9:18 AM
    #370
    o313
    o313 Well-Known Member
    N
    2018 DCLB AT SC
    I received mine Thursday and I've already got the tune file so two days of good weather and I'm off to the races!
  11. Mar 27, 2021 at 10:14 AM
    #371
    OlympicTaco
    OlympicTaco Wrench Therapy
    ‘20 Pro
    Just some more anecdotal evidence from a PM conversation between another member and I...
    At low power settings it’s hardly noticeable since the bypass valve is doing its job. Noise from the blower is nonexistent until you lean into the throttle and the revs are above 3000 rpm. The gear whine is much quieter than the supercharger I had in my 2006 Tacoma, but just like that kit it’s silent if you’re not in the throttle and the bypass is open.
    More power is available even at low rpm. 6th gear on the highway (my 4.88s help here too so YMMV) is actually useful now and the truck will accelerate nicely without dropping down a gear. If it does shift, 5th has plenty of oompf to tackle hills and passing (65-80mph) without drama. If you press on the pedal and force a downshift to 4th gear, the subtle whine from the blower is right there and the truck is smartly accelerating regardless of incline.
    I reset my AT and LV when I flashed the ECU so I think it’s still learning. Only complaint so far is that a couple full throttle runs resulted in some hesitant/hard shifting at redline. This might be the Magnuson tune. I suspect it’s a redline throttle reduction that cuts power and confuses the transmission shifting a bit. I don’t race this truck so weird shifting at wide open throttle is not really a concern of mine. A slow roll into the throttle brings predictable and smooth shifting and plenty of power that’s significant when compared to when it was stock.
  12. Mar 29, 2021 at 11:17 AM
    #372
    o313
    N
    2018 DCLB AT SC
    Got mine on friday (March 26th) and its V7.
  13. Mar 29, 2021 at 11:28 AM
    #373
    ibryant20
    ibryant20 Member
    Ian
    2019 Tacoma TRD Pro
    WORST EXPERIENCE EVER!!! HORRIBLE CUSTOMER SERVICE!!!
    I'll try to summarize this without writing a novel.
    - bought my supercharger from a certified dealer
    - had it shipped to another certified dealer. scheduled my time to drop the truck off to have it installed
    - was told 2 to 2.5 days. I was an hour away from my trailer so I got a hotel room for 3 days.
    - Magnuson apparently outsources the tuning to OVTune, who recently outsourced to another person somewhere on the other side of the planet
    - My dealer sent off my info for the tune the morning I dropped it off
    - They finished the install by the next day
    - Magnuson and OVTuen were not getting back with us and it took them 6 days to get the Tune files over.
    - 2 weeks after the install I hear a knocking sound coming from the supercharger
    - I have to get it towed back to the dealer
    - they and Magnuson find that it is defective (from the factory)
    - Magnuson tells me that because I purchased from 1 certified dealer and had it installed at another certified dealer I had to coordinate the warranty replacement myself
    - I am told they cannot ship me out a new one even though it was defective from the factory
    - I just found out today that it is going to take at least another week before they can ship out a new one (they got it on Thursday, today is Monday)
    - I am stranded with no vehicle, was suposed to have left town on Sunday to go to another state.
    - Magnesuon just says "well unfortunately we can do anything" on the phone.
    - you sold me a bad $6,500 super charger and you want to play games!!
    - Both dealers have been super supportive and great, Magnusonon the other hand has left me stranded now for another time and this one is over a holiday weekend.
    just had to get my frustrations out.
    For reference why I bought from one dealer and had another installed is that I live full time in my travel trailer and I move from state to state every 1-2 months. I had reservations to be in Nevada but had an opportunity to buy the last supercharger in stock in AZ and have it shipped so when I got to Nevada it was ready to install. Bad decision on my end I guess.
    I will say the 2 weeks I drove it before it broke were great. I can't wait to get it back.
    MGMSangTaco likes this.
  14. Mar 29, 2021 at 12:43 PM
    #374
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Did you have to get a hotel or did they let you stay in your house in the shop?
  15. Mar 29, 2021 at 12:46 PM
    #375
    GoldenBrew
    Golden, Colorado
    Sorry to hear about your experience - it sure sounds like shit in that vid - almost like valves. Bummer. I know many have a certified dealer do the installation for obvious reasons. I simply don't trust them - unless I am watching over their shoulder - which they won't allow - hence they won't work on my vehicle. Hope they get it corrected for you soon.
  16. Mar 29, 2021 at 12:53 PM
    #376
    ibryant20
    ibryant20 Member
    Ian
    2019 Tacoma TRD Pro
    I had to get a hotel for 3 nights when they installed it but then I said I am not staying another 4 nights so they had someone from their shop drive me back to my trailer. For the fix, they brought a flatbed out here to pick it up. I am in Pahrump, NV and the truck is in Vegas just over an hour away.
  17. Mar 29, 2021 at 12:54 PM
    #377
    ibryant20
    ibryant20 Member
    Ian
    2019 Tacoma TRD Pro
    thanks man,
    I believe it was a bad bearing.
    the guys that did the install did a great job, they said it was defective from the factory. that's why I am so pissed at Magnuson for not dropping everything and getting a new one ASAP since it was their fault.
  18. Mar 29, 2021 at 12:59 PM
    #378
    GoldenBrew
    Golden, Colorado
    If the installer thought it was bad from the get-go he should have stopped then and taken care of it (called you and Magnuson) before installation. That is wrong - hope the installer does not try to buck you for the parts and labor. Again I am sorry to hear about your experience.
    o313 likes this.
  19. Mar 29, 2021 at 1:01 PM
    #379
    ibryant20
    ibryant20 Member
    Ian
    2019 Tacoma TRD Pro
    In their defense they did not know if was defective during the install. That rattle/knock started 2 weeks after It was complete.
    I am being told I won't have to pay for any parts/labor
  20. Mar 29, 2021 at 1:07 PM
    #380
    GoldenBrew
    Golden, Colorado
    good to know they are taking care of it the right way. Hope it all works out as quickly and positive as possible.
