3rd Gen Magnuson Supercharger Review & Discussion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OpelGT, Oct 3, 2020.
  1. Mar 29, 2021 at 1:23 PM
    #381
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Something I learned along time ago... never have major work done before you have to leave town.... if something is going to go wrong, its going to happen pretty soon after.
    Best of luck getting it all sorted out and hope your boosting trouble free soon.
    auskip07 and blackmist27 like this.
  2. Mar 29, 2021 at 2:52 PM
    #382
    blackmist27
    blackmist27 Well-Known Member
    17 Tacoma TRD Pro
    Leer shell 100XR
    Murphy's law... when you are getting something done... shit is going to go down.
    Sorry you had a bad experience but it could have been worse. imagine if they didnt replace your charger! Thank goodness for warranties.
  3. Mar 29, 2021 at 7:21 PM
    #383
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    If possible, can you attempt to find out exactly which bearing is bad? Might be helpful for future issues on other charger units.
    Skydvrr, GoldenBrew and Grossomotto like this.
  4. Mar 29, 2021 at 7:46 PM
    #384
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    If they find it is the snout I'd say they dropped it. That SC unit is damn heavy and if you are not watching what you are doing it can get away from you fast.
    auskip07 and sorevilo like this.
  5. Apr 1, 2021 at 7:04 AM
    #385
    Ak-47
    Ak-47 Member
    Chode
    Austin TX
    2016 Quicksand Tacoma TRD Off-Road
    2" lift + 1" leveling kit + 35" tires + very tiny benis
    This may be a newb question but why does a TVS1900 make 440HP at crank on a pentastar 3.6 but on a 2GR-FKS it makes 370HP (both numbers reported by magnuson)? What mechanical difference in the engine allows for this, I would just assume that the pentastar is more boost friendly somehow
  6. Apr 1, 2021 at 7:17 AM
    #386
    OpelGT
    OpelGT [OP] hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    Engines are very different. It could be ECU issues, design strength of pistons, rods, crank, cooling capacity etc. Design power capacity of the the trans, rear end, clutch, driveshaft, the list goes on and on.
    the compression ratio of the taco is 11.8:1 vs the jeeps 11.3:1 too.
    My race cars have the same engine from the same car, but 1 year apart. One of my cars can handle ~150HP max and maybe 2 psi of boost. The other one can handle twice that because of a slight design change. Adding power the right way is tough. Lots of variables.
    Ak-47[QUOTED] likes this.
  7. Apr 1, 2021 at 8:39 AM
    #387
    o313
    o313 Well-Known Member
    N
    2018 DCLB AT SC
    It makes over 500HP on the Tundra!
    Seriously though I think the biggest hurdle has been unlocking the ECU which is done (Thanks Matt@OVTune) and now it seems fueling is the biggest hurdle (Seems to be ~400HP limited) but by the grace of jesus Matt has a fuel pump controller that should be able to get people over that and on to the next problem.
    Skydvrr and oldirtywalker like this.
  8. Apr 1, 2021 at 6:41 PM
    #388
    GoldenBrew
    Golden, Colorado
    I asked that very question of a Dodge/Jeep Service department. They kind of hinted that yes it will make that power but in the long run it is a Jeep and just as reliable as a Jeep. I did not need to read between the lines any further. Hint taken.
    auskip07 likes this.
  9. Apr 2, 2021 at 4:57 AM
    #389
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    sounds like they know their product well
  10. Apr 18, 2021 at 10:49 AM
    #390
    OpelGT
    Texas
    Any update on this? Mine just started making the same noise after about 8 months of driving it:(
    Marbles in a can noise in the SC snout. I tested with the belt removed and there is no noise. comes back when I put the belt back on.
  11. Apr 18, 2021 at 12:34 PM
    #391
    o313
    N
    2018 DCLB AT SC
    Oh man, sub'd
  12. Apr 18, 2021 at 12:52 PM
    #392
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Damn, I was seriously debating. Now I wait.
    Skydvrr likes this.
  13. Apr 18, 2021 at 1:57 PM
    #393
    Jowett
    Brian
    North Adams, MA
    I'll touch base with Magnuson and see if they will share the source of failures.
    Skydvrr and auskip07 like this.
  14. Apr 18, 2021 at 2:39 PM
    #394
    420taco
    420taco Well-Known Member
    Justin
    PA
    Sure it’s actually a problem? The blower for the 2nd gens always made a similar noise at idle.
  15. Apr 18, 2021 at 2:49 PM
    #395
    NotSoQuicksand
    NotSoQuicksand Well-Known Member
    2019 TRD Sport x4
    I'm curious as well if it's normal, I've noticed when the truck is cold, in drive, foot on brake a rattle noise. I set the E-brake and chocked the rear wheels popped the hood and took a peek, it looked like the drive belt for the blower was vibrating making the noise, hence no noise while the belt would be off...
    It's not a loud as the one in the video thou..
  16. Apr 18, 2021 at 3:00 PM
    #396
    auskip07
    Skip
    Atlanta, Ga
    if it didnt make the noise when new and its making it now then i would think its not normal.
    Abject4x4 and Skydvrr like this.
  17. Apr 18, 2021 at 3:09 PM
    #397
    NotSoQuicksand
    2019 TRD Sport x4
    Unless the belt has stretched
  18. Apr 18, 2021 at 3:11 PM
    #398
    auskip07
    Skip
    Atlanta, Ga
    too little tension wont kill bearings. too much will.
    Skydvrr likes this.
  19. Apr 18, 2021 at 3:26 PM
    #399
    NotSoQuicksand
    2019 TRD Sport x4
    What I noticed was not enough tension due to the truck/blower being cold, about 1 inch down the belt after the snout pulley you could see about a .3-.5" deflection in the belt causing a snapping noise almost metallic but deff from the belt and not the snout bearing.. just my thoughts
    It was enough to make me look into this
    https://www.gates.com/us/en/search.p.8552-000000-000002.v.8552-096891.html
  20. Apr 18, 2021 at 3:36 PM
    #400
    420taco
    Justin
    PA
    It’s the unloaded rotors making the noise; although yes, it does sound excessive in the video.
