3rd Gen Magnuson Supercharger Review & Discussion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OpelGT, Oct 3, 2020.
  1. Oct 8, 2020 at 2:15 PM
    #101
    OpelGT
    OpelGT [OP] hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    How about let’s not turn this thread into a typical TW argument.
    Let’s just agree to disagree right here and keep the turbo discussions elsewhere. Nobody is going to change each other’s minds.
    Here’s a great thread from the 2nd gen superchargers
    https://www.tacomaworld.com/threads/trd-magnuson-4-0-supercharger-tips-tricks-and-mods.518932/
    a lot of this stuff still applies. I removed my secondary charcoal filter, put a clamp on the vacuum bypass hose ends and removed the brass restrictor on the bypass. I’ll see if I can tell any difference (probably not) but I like tuning things:)
    I can see right away the vacuum bypass valve opens instantly now with the metered orifice removed
    japjoe7, 12TRDTacoma and SK808 like this.
  2. Oct 8, 2020 at 2:26 PM
    #102
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    I think I might give those mods a try too!
    Hoping to get my boost gauge hooked up tonight too finally. I think I had a kink in the hose before that was giving me artificially low readings.
    I live at about 4500ft so according to Magnuson i'm losing 2psi purely due to altitude so once I get a wideband i'll start looking at smaller pulleys to recover that boost.
    OpelGT[QUOTED][OP] likes this.
  3. Oct 8, 2020 at 2:30 PM
    #103
    OVTune
    OVTune Well-Known Member
    OVTune
    Please go read our thread and keep this about magnuson.
    Any form of tuning or calibration needed is no issue. If there is a table or code required to do something, we create the table/code/control. This isn't like relying on what Cobb gives you, we are the "Cobb."
    Will our kit have the fit and finish of this SC kit? no.
    will be as easy to install? probably not.
    Everything you are talking about sounds like it comes from some experience with inferior parts. It may not mean much but I'm proud to say that every single critical component of our turbo kit is proudly made in the USA, even the little AN fittings, manifolds, etc. Designed, sourced, casted, CNC'd and created here in America. So quality of components is not a problem.
    Now please lets keep this about magnuson.. I really don't enjoy making any posts in any magnuson threads.
  4. Oct 8, 2020 at 2:45 PM
    #104
    OpelGT
    Texas
    Another bit of info. If you are an idiot and didn’t install a boost fitting prior to putting on the supercharger you can barely access it by unbolting the main wiring harness bracket and fitting a low profile 3/16” Allen key in there. I’ll post photos when I order a boost gauge and 90° fitting.
  5. Oct 8, 2020 at 2:54 PM
    #105
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Are you calling me an idiot??? Cuz that's exactly what I did!! I removed the bolt on the passenger size of the wiring harness and then the stud on the drivers side so I could push it out of the way.
    I had a 3/16" allen already cut down from some other stuff so was able to get that in there. My wife did ask what I was doing laying across the top of the engine when she walked out to the garage the other day...
    Then I used these fittings since they are easier to turn than a fitting with a barbed elbow that sticks out further.
    https://www.amazon.com/gp/product/B074DTL1N4/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    Then threaded a straight connector in to this elbow.
    Also, I used pipe dope on the fittings just to make sure they didn't leak cuz I couldn't get the 90* fully tight while keeping it aimed up.
  6. Oct 8, 2020 at 3:09 PM
    #106
    OpelGT
    Texas
    I’m not laughing at you. I’m laughing with you. Sweet I just put those fittings in my cart. Did you use a strait connector with a barb or did you use a compression strait fitting?
  7. Oct 8, 2020 at 8:00 PM
    #107
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Haha I was hating my life working on that boost port..
    I used a compression fitting with that tiny nylon tubing
  8. Oct 8, 2020 at 8:02 PM
    #108
    OpelGT
    Texas
    Verdict is out on the vacuum bypass restrictor removal.
    Holy crap. I have immediate boost as soon as I put the pedal down. I can feel the power even at like 1500rpms in first now. @Bascoma you we’re complaining about response. Remove the brass metered orifice in your vacuum bypass valve and you’ll have it.
    Reference the 2nd gen Tacoma SC mods link I posted a couple posts up for what it looks like and how to remove.
    the truck feel like what people have been asking for now. Instant power even down low. Best part is if you don’t like it you can put the restrictor jet back in quickly.
  9. Oct 8, 2020 at 8:04 PM
    #109
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Nice! Are you monitoring AFR/boost levels after this mod? (Just to be on the safe side)
    Skydvrr and OpelGT[QUOTED][OP] like this.
  10. Oct 8, 2020 at 8:09 PM
    #110
    OpelGT
    Texas
    I checked AFRs. The only place it could make an issue is the instant the bypass closes since it’s much quicker. It still went to 11.9AFR pretty quickly. This mod has zero effect on boost psi or AFR after initial opening. It literally just activates the bypass about .1seconds more quickly is all.
    zero change in power or torque, but quicker response to throttle input as the bypass moves instantly when the throttle body opens to WOT
    I do think I will put my bypass back in but I’m going to drill it out to a larger size with my carburetor jet drill bits. I think a little slower on the bypass actuation would do good for the diaphragm longevity and my clutch.
  11. Oct 8, 2020 at 8:21 PM
    #111
    su.b.rat
    su.b.rat broken truck
    stock clutch? if yes how is it doing with the add'l power? notice any slip?
  12. Oct 8, 2020 at 8:29 PM
    #112
    OpelGT
    Texas
    I thought I might have caught a hint of slip today doing some quick shifts, but I haven’t been able to replicate it so it’s possible (likely) it was human error. I will keep everyone informed. I have 40K on this clutch already and lots of daily 6200rpm shifts.
    I just need it to not slip until URD gets clutches back in stock lol.
    su.b.rat[QUOTED] likes this.
  13. Oct 8, 2020 at 8:33 PM
    #113
    su.b.rat
    i started noticing a little slip with the stock one at around 40k actually. that's when i bought the URD just planning ahead.. glad i did. the FI rush cleared their shelves. stage 2 is great btw although there's been a couple install or hardware issues. i had to redo my installation, it's been great since. super solid.
  14. Oct 8, 2020 at 10:01 PM
    #114
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Looks like Magnuson is up to their usual crap even in 2020. Glad to see you guys are learning some things from our side of the fence! :thumbsup:
  15. Oct 8, 2020 at 11:19 PM
    #115
    KanPanic
    KanPanic Rock Stacker
    State of Jefferson
    2018 OR
    Can you estimate at what RPM you pull full boost with and without the restrictor?
  16. Oct 9, 2020 at 4:54 AM
    #116
    OpelGT
    Texas
    Idk probably around 3k for both. This restrictor won’t change the rpm just how quickly it reacts to your foot.
    KanPanic[QUOTED] likes this.
  17. Oct 9, 2020 at 5:14 AM
    #117
    Bascoma
    Bascoma I smell dog poop.....
    Jake
    Deep Creek VA
    S/C 2017 OR MT
    Magnuson Supercharger TRD Bilstein 6112/5610 w/ Head Strong 3 leaf AAL URD Mark 2 Y Pipe OV Tuned (pre Magnuson install) TRD Intake TRD Exhaust TRD Skid Plate TRD Shift Knob Leer 100XR Subaru Kicker Tweeters Toyota Bed Mat Kicker CS Door Speakers Kicker H8S Hideaway Sub Toyota All Weather Floor Liners Caliraised LED Bumper Light Bar De Badged Tint Console Organizer CMC with BAMF Plates 17” SCS Ray 10’s 285/70r17 Ridge Grapplers Faux PRO Grille Hondo Radio Knobs Accumulator Delete Mod URD Short Throw Shifter JLT Oil Separator MESO Ultimate Turn Signals MESO Map Lights MESO V2 Dual Color Dome Light RC Seat Covers Stoptech Slotted Rotors Sport Pads and Stainless Brake Hoses
    Magnuson sent me a different tune yesterday (I had V5 and now V7) and I’ve been playing with it. I am getting much better throttle response and it is driving much more like 2.0 now.
  18. Oct 9, 2020 at 5:30 AM
    #118
    OpelGT
    Texas
    Awesome! I currently have V6 on mine. I might see if they will send me V7 too.
  19. Oct 9, 2020 at 5:35 AM
    #119
    Bascoma
    Jake
    Deep Creek VA
    S/C 2017 OR MT
    Their customer service has impressed me. From the ordering process, to getting me my first tune fast and on a Sunday night, to now addressing my feedback and concerns over the phone and sending me an updated tune.
  20. Oct 9, 2020 at 6:19 AM
    #120
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Looks like I have V7 already - for the 04B04 ECU with auto trans. I was hoping for a second there was already an improvement out!
    @OpelGT was the restrictor fitting at the bypass end of the hose or the end where it connects to the SC?
    Skydvrr likes this.
