3rd gen manual trans characteristics.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AFMurse2014, Jan 12, 2018.
  1. Sep 23, 2018 at 5:49 AM
    #181
    eMKay
    eMKay Well-Known Member
    Michael
    Buffalo, NY
    2019 Cavalry Blue DCOR 6MT
    Pro Grill, roof rack, HID headlights, yellow fogs, LED high beams, trailer brake controller
    I do that too, in my wife’s car (‘18 Forester). It’s the first 6sp car we have owned. I asked her if she drives it that way on the highway, and she said “I don’t remember, I never get the chance to go fast enough on the highway”. I forgot her commute is rush hour both ways, lol. Then I felt sorry for her.
    I can’t wait to get my manual Tacoma.
    pinochle and tonered like this.
  2. Oct 17, 2018 at 2:19 PM
    #182
    Mr. G
    Mr. G Riding the road with my baby, Lyen.
    Washington
    2018 TRD Sport 4x4 MT
    None
    Hi guys! I have a 2018 DBLCB TRD Sport 4x4 MT. What's everybody's typical rpm for 60mph?
  3. Oct 17, 2018 at 3:03 PM
    #183
    24-7
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    Mine does just fine. Its no S2000 or 350z but it works just fine. Up hill, down hills, towing, off road no problems.
  4. Oct 17, 2018 at 3:13 PM
    #184
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I'm doing about 2000rpm @60mph.
  5. Oct 17, 2018 at 3:17 PM
    #185
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Welcome...
    Depends on tire size. For example, the following tire would be spinning much faster than my stock tire
    Multiduc, tonered and shakerhood like this.
  6. Oct 17, 2018 at 5:58 PM
    #186
    Mr. G
    Washington
    None
    Gotcha. I used to have an AT 2017 and 60mph was around 1500rpm. Just wanted to make sure that 2k rpm for 60 mph is normal. thank you!
    NickleCityTaco and TeecoTaco like this.
  7. Oct 17, 2018 at 6:15 PM
    #187
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The Manual has 4.30 rear gears so it will rev slightly higher.
    mtip, Mr. G[QUOTED] and TeecoTaco like this.
  8. Oct 18, 2018 at 7:20 AM
    #188
    Mr. G
    Washington
    None
    gotcha. I have to read the manual still. Thank you!
    shakerhood[QUOTED] likes this.
  9. Oct 18, 2018 at 7:21 AM
    #189
    Mr. G
    Washington
    None
    sounds ablut right. thanks bro!
    specter208[QUOTED] likes this.
  10. Oct 18, 2018 at 10:40 AM
    #190
    Rogues Gambit
    Rogues Gambit Well-Known Member
    Colts Neck, NJ
    '07 A4, Planning on ordering soon
    Drove a Manual, and I loved it, reminded me of driving my Audi, though it was around town with a top speed around 60 by the dealer (rt35)
    I'm 5'9, only issue I had was getting use to the rear drums
    shakerhood likes this.
  11. Oct 18, 2018 at 10:54 AM
    #191
    shakerhood
    Southern Ohio
    The brakes function fine, the Tacoma stops shorter than the Colorado with rear discs.
    Junkhead, hiPSI, phsycle and 4 others like this.
  12. Oct 18, 2018 at 1:59 PM
    #192
    Rogues Gambit
    Colts Neck, NJ
    Oh, I believe that, just the first time I've noticed them really since I never drove anything with drums before (not counting the test drive with the 2nd gen, which I'm not sure how I didn't notice)
  13. Oct 18, 2018 at 2:08 PM
    #193
    su.b.rat
    su.b.rat broken truck
    i used to daily a '70 A body before rebuilding it from scratch. that thing had 4 drums, old and crusty. every time you'd hit the brake on an even slightly damp road for sure at least one corner would lock up even on light pressure. and i lived in Seattle where the roads are never dry, so it was a total nightmare.
    that's the deal with drums. they grab like nobody's business, but modulation and anything less than off & on is difficult for drums. they are strong in my Tacoma but the modulation required with my driving style is braking like i'm in a dump truck. if drums don't get enough pressure they don't engage. enough pressure and they over grab. still as far as drums go these are the most predictable i've driven. where's @stevotivo12 when i need to feel bad about my drum brakes? i'll take his brakes if he ever gets sick of them. ;)
  14. Oct 18, 2018 at 3:40 PM
    #194
    specter208
    California
    Some tips for you:
    1) the truck lurching in 1st is normal and harmless. What happens is that there is still a little bit of torque in the input shaft still spinning when you shift to 1st quickly after clutching. You can test by switching to neutral, clutch out them clutch in and shift to 1st quickly.
    If it were the clutch dragging You will know very easily from the grinding or notchy shifts. Or you'll find 1st gear not indexing properly and grinding your synchros that way. You will even feel the shifter resist to come out of gear easily. I had this issue on my 3rd gen from an overtorqued pressure plate from the factory. Fixed under warranty
    2a) Not too sure what you mean by chunky 2-3 shifts. If you mean notchy/grinding then you can try this:
    When you are ready to shift make sure you clutch in and then shift to the next gear quickly. Don't let your RPMs fall more than 2-300rpms. Your synchros will have to spin less to match the input/output shaft for the next gear. Don't power shift, just quickly and with finesse make then next gear shift.
    Also make sure you are pressing the clutch pedal atleast 3/4 quarters to be sure you are getting proper disengagement of the cluth to be safe.
    2b) if you are referring to your engine kind of surging/lugging then try to get higher RPMs and/or don't press too hard on the accelerator. If you increase pedal pressure gradually you can avoid the surging. Also this engine needs higher RPMs to make power. I like to shift at atleast 2500rpms to accelerate smoothly and in a relaxed manner.
    3) this is an important step for smooth shifting. This engine like many other modern engines has rev hang. You'll notice your RPMs falling very slowly when you clutch in too quickly to make your shift. This will cause you to lose speed/momentum while waiting for the RPMs to fall, and you'll get a rough shift if you engage the clutch too soon at the wrong rpm. To avoid this you have to wait 1-2 seconds before clutching to make your next shift. Also if you are doing 1st > 2nd gear you also have to rev to atleast 2500rpms to avoid rev hang in 1st gear.
    You can test this in these ways:
    If in 1st gear accelerate and clutch in at 2000rpms= you'll get rev hang no matter what
    Next in 1st gear accelerate to 2500rpms or higher and wait 1-2 seconds then clutch in= your revs will drop faster
    If in any other gear you can avoid rev hang at any rpm by just waiting 1-2 seconds. You can physically hear the engine cut fuel after waiting a brief period after you take your foot of the accelerator.
    Junkhead likes this.
  15. Oct 18, 2018 at 3:49 PM
    #195
    Rogues Gambit
    Colts Neck, NJ
    Well now that I've got some perspective on it, that'll help once I drive it again
    Thanks St. Germain
    shakerhood and su.b.rat[QUOTED] like this.
  16. Jan 20, 2019 at 8:13 AM
    #196
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    I used to shift this way too but I figured the clutch might not be fully disengaging and causing more wear. It really did shift nicely that way though.
    Malibu7tss[QUOTED] likes this.
  17. Jan 20, 2019 at 9:33 AM
    #197
    specter208
    California
    I highly recommend that you DO NOT press half way on the clutch. If I remember correctly a while back my shifter would not come out of 1st gear with my foot all the way to the floor on the clutch pedal. I yanked on the shifter and heard it grind. Plus the hydraulic accumulator slows down the action of the clutch engaging/disengaging so it's possible your clutch may still be dragging if you only press half way.
  18. Jan 20, 2019 at 9:36 AM
    #198
    JayTee
    JayTee Well-Known Member
    Lynn Ranch CA
    With mine its a matter of getting good with rev matching between shifts.
    And this lil puppy likes higher rpms than im used to.
    But when you get it right, its like butter!
    SilverBulletII likes this.
  19. Jan 20, 2019 at 10:27 AM
    #199
    jersey jim
    jersey jim Well-Known Member
    Jim
    2018 Cement DCSB TRD Sport 4x4 6MT
    Other than needing to carefully ease the shifter into second for the first 1500 or so miles to avoid a crunchy feeling and needing to be careful for the first 2 or 3000 miles shifting into 5th and 6th to avoid a clunk I have not had a lot of issues. Yes, the rev hang and engine/throttle characteristics required learning the quirks of the vehicle to be smooth, but at 6k miles it feels as good as any manual I've owned. It will idle along in 1st or 2nd gear in traffic, I have no issue accelerating smoothly from those speeds. I get no clunk shifting into 5th or 6th. I don't get bucking unless I'm clumsy with the throttle and clutch. Maybe I got lucky? Maybe I've just adjusted my driving style to the vehicle? I don't know, but mine drives fine for me.
    For anybody with less than 2500 miles give it some time to break in and get to used to the quirks of the vehicle, I think you'll be a lot happier at that point.
  20. Feb 13, 2019 at 8:15 PM
    #200
    TriniPhantom
    TriniPhantom Well-Known Member
    Bay Area, California
    2018 Tacoma TRD Off Road DCSB
    Prinsu roof rack, Budbuilt Sliders, Avid Bumper Guard, MESO Ultimate Turn Signals, Door sill decals, Raptor Lights, Tailgate inserts, Mudflaps, Tri-fold Tonneau, DC Motorsports Muffler Tip, TVD Vinyl Decals, Many Interior Mods.
    When I'm coasting, that is, released the accelerator, but still in a gear I get a whining noise, but when I press the clutch it stops. When I release it it comes back. Is this just normal transmission whine?
