3rd gen manual trans characteristics.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AFMurse2014, Jan 12, 2018.
  1. Jan 14, 2018 at 10:15 AM
    #41
    TBV
    TBV Well-Known Member
    Oakland CA
    2017 TRDOR 6MT
    If you need juice off the line, you want a quick clutch engagement in first. No feathering. Feed her lots of hay post grab and she'll take off in a good sprint.
    You can wind out 2nd to about 60 MPH if you really want to burn dinosaurs. Light that 3.5L up!
  2. Jan 18, 2018 at 8:32 PM
    #42
    AFMurse2014
    AFMurse2014 [OP] Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    Went wheeling today, holy underpowered crap. Was in a dry creek bed with some coarse and loose sand/peagravel stuff. If you stopped and tried to go the truck would bog, even when I tried a rev dump (wanted to throw some roost... gotta impress the girl right? ) and it fell on it's face. It couldn't reverse in the sand in 2low or up slight grades or against it's own ruts... had to go 4 low or bump it forward and let the slope and the gear take me back.
    Yet, the thing never got stuck and got us home... love hate with this truck... Took a steep climb, got caught up on the loose and uneven ground so I tried Atrac out (that actually works very well...) and the locker really powered through it (once it engaged)
    There's gotta be an issue why this thing is such a gutless turd off the start? Even when I wound it out and had it going 40-50 on the sand in 2nd and 3rd gears it would just fall on its face even at full throttle :(
  3. Jan 18, 2018 at 8:33 PM
    #43
    AFMurse2014
    Devin
    San Antonio
    I try that, but it feels like it cuts throttle and it will drop to 500, then pick up and go again. 3200+ rpms the trucks ok. anything under that it doesn't pull
  4. Jan 19, 2018 at 12:25 PM
    #44
    DESportTRD
    DESportTRD Well-Known Member
    2017 Blazing Blue Pearl DCSB Sport 4x4, MT
    Did you turn off your traction control so your ECM is not sending signals to your anti-lock brake system. If you don’t turn it off, your ECM signals your anti-lock brake system to apply the brake to the wheel.
    specter208 and TBV like this.
  5. Jan 21, 2018 at 11:10 AM
    #45
    AFMurse2014
    Devin
    San Antonio
    Yes. held the button, both yellow lights on, etc.
  6. Jan 21, 2018 at 12:38 PM
    #46
    Kimchi Taco
    Kimchi Taco Well-Known Member
    ATL
    17 TRD OR 4x4 Manual
    I felt your pain. Never was able to drive smoothly. This all changed after the tune.
    AFMurse2014[OP] likes this.
  7. Jan 21, 2018 at 12:43 PM
    #47
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I don't believe you actually drive around in 2nd at 4mph. My truck growls below 10mph and is close to lugging at 7mph.
  8. Jan 21, 2018 at 1:08 PM
    #48
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    Dunno what to tell ya. I spend almost all of my 'parking' time in 2nd gear since 1st is so jerky without slipping the clutch constantly.
  9. Jan 21, 2018 at 1:08 PM
    #49
    Ez2Tan
    Ez2Tan Well-Known Member
    2017 Quicksand Tacoma OR
    How was the install for the short shifter? The other threads about the degree of difficulty, lack of instructions and quality control irks me about URD.
  10. Jan 21, 2018 at 1:27 PM
    #50
    Shellshock
    Iowa
    I do it. But I’ve got OVTune on my truck.
    Kimchi Taco likes this.
  11. Jan 21, 2018 at 2:07 PM
    #51
    specter208
    California
    Doesn't make sense, considering we have the same tranny and engine. But ok.
  12. Jan 21, 2018 at 2:08 PM
    #52
    specter208
    California
    Oh ok, that is probably why. Can you start in 2nd without slipping too much with that tune?
  13. Jan 21, 2018 at 2:09 PM
    #53
    specter208
    California
    Are you on a stock tune or aftermarket?
  14. Jan 21, 2018 at 3:00 PM
    #54
    Rownan
    Rownan Well-Known Member
    Tim
    Highland, MI
    '17 OR DCSB 6MT *Quicksand*
    I've been thrilled with it since installation. But yeah the actual install is a bit of a pain. Mostly due to the clearance on the front two bolts. I've given a write-up on here before about my trouble with it. I did eventually get everything back together and it has been worth the difficulty imo.
    The install can be massively simplified if you just go into it knowing you'll have to cut or bend back the sheet metal at the top of the trans tunnel. Get some snips and go at it.
    su.b.rat likes this.
  15. Jan 21, 2018 at 3:05 PM
    #55
    su.b.rat
    su.b.rat broken truck
    100% agree with all.
  16. Jan 21, 2018 at 3:17 PM
    #56
    Shellshock
    Iowa
    Yep sure can
    MOC221_ likes this.
  17. Jan 21, 2018 at 3:20 PM
    #57
    su.b.rat
    one of the indispensable things about it. torque where everyone complains "no torque".
    Shellshock[QUOTED] likes this.
  18. Jan 21, 2018 at 5:25 PM
    #58
    AFMurse2014
    Devin
    San Antonio
    I have an early production truck so I fear in the troublesome ecu for ovt
  19. Jan 21, 2018 at 5:27 PM
    #59
    su.b.rat
    the biggest issue i find with the OVT stuff now is that you have to buy the thing at full price to even know which ECU code version you have. for you that's ridiculous. pay $800 or whatever to find out it's the version that's absolutely not worth the price of admission.
    is that what you're referring to?
    tonered, TeecoTaco and MOC221_ like this.
  20. Jan 21, 2018 at 5:47 PM
    #60
    AFMurse2014
    Devin
    San Antonio
    Yes. I'm holding off until I see more resolutions
    TeecoTaco and su.b.rat[QUOTED] like this.
