3rd Gen Manual Transmission Drain and Fill Plug Gaskets
Discussion in 'Technical Chat' started by Gdeyarmond, Mar 13, 2024.
  1. Mar 13, 2024 at 9:32 PM
    Gdeyarmond
    Gdeyarmond [OP] Well-Known Member
    San Dimas, CA
    2020 TRD OR 4x4 6MT
    Bilstein 6112/5160
    Good god....this is driving me crazy.
    What is the Toyota part number for the drain and fill plug gaskets for the manual transmission on a 2020 V6 6-speed manual TRD OR 4x4 (I'm sure most of that specific info doesn't matter....)?
    I'm going to lose my damn mind if I keep looking.
    Thank you.
  2. Mar 13, 2024 at 9:40 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    90430-A0003, but you really don’t need them. I’ve changed the fluid probably 4 or so times while reusing them.
    STEELeR43, Gdeyarmond[OP] and Dm93 like this.
  3. Mar 14, 2024 at 3:05 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I haven’t replaced one, or had one leak in thirty years.
    Gdeyarmond[OP] likes this.
  4. Mar 14, 2024 at 5:31 PM
    Gdeyarmond
    San Dimas, CA
    2020 TRD OR 4x4 6MT
    Bilstein 6112/5160
    I'm going for it. Keeping the original washer....wish me luck.
  5. Mar 14, 2024 at 6:29 PM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    The same washers are also used on the drain/fill plugs on the transfer case. You can get an aftermarket kit on Amazon that covers the diffs, MT, and transfer case.
    You'll also see a sticker on the fill plug telling you to check the manual before filling the MT since Toyota has used a different oil in the past for some MTs.
    STEELeR43 likes this.
