3rd gen manual transmission drain and fill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mallcrawler20, May 12, 2025.
  1. May 12, 2025 at 9:10 AM
    Mallcrawler20
    Mallcrawler20 [OP] Well-Known Member
    Trd off-road 4x4 Manual
    Question just to confirm on the manual transmission u don’t need to do the temperature check for fluid level ? Just drain and fill ? Did some research here and all I see is just draining and filling . On the auto requires some temperature check for levels.
  2. May 12, 2025 at 9:36 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Nope, just drain and refill. Make sure to pull the fill plug first too.
  3. May 12, 2025 at 9:56 AM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    What previous post wrote, but make sure it is GL-4 grade gear oil for manual transmission. GL-5 will melt brass syncros.
    shakerhood, MOC221_, OZ TRD and 2 others like this.
  4. May 12, 2025 at 10:13 AM
    Clearwater Bill
    Billy
    Largo Florida
  5. May 12, 2025 at 11:30 AM
    yotadust
    yotadust Well-Known Member
    how many miles on ole girl??
  6. May 12, 2025 at 12:21 PM
    InThePlains
    InThePlains Well-Known Member
    24mm sockets and crush washers.
  7. May 12, 2025 at 12:22 PM
    Clearwater Bill
    Billy
    Largo Florida
    6 point, not 12.
  8. May 12, 2025 at 1:18 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Correct, MT doesn't heat up the gear oil to the point of affecting volume from thermal expansion. Change MT oil the same way as differential oil - when cold.
    shakerhood likes this.
  9. May 12, 2025 at 2:44 PM
    Mallcrawler20
    63k never done a flush on it so figure it’s about time .
    yotadust[QUOTED] likes this.
  10. May 12, 2025 at 10:17 PM
    HelloFelix
    HelloFelix Well-Known Member
    Felix
    Las Vegas
    2017 MGM 4x4 OR Tacoma
    Toy_Runner, MOC221_ and shakerhood like this.
  11. May 13, 2025 at 3:32 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
  12. May 13, 2025 at 10:54 AM
    Mallcrawler20
  13. May 13, 2025 at 12:30 PM
    Clearwater Bill
    Billy
    Largo Florida
    All I can say is in my street class SCCA 96 Miata (which all early miatas had truck transmissions) I went from factory fill to Royal Purple to Redline to Ford. And stopped there. I raced technical courses with lots of shifting, up and down. Smooth mattered. Snick snick like soft butta.
    You'll also note my post has a few likes, so someone else had found the magic too.
  14. May 13, 2025 at 1:34 PM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    When I had the MT I thought it smoothed it out quite a bit vs stock fluid. I bought on RockAuto and is wasn't any more expensive than other GL-4 oils...
  15. May 13, 2025 at 5:57 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Far superior to the factory fill.
    My transmission felt clunky, crunchy, was often difficult to get into first gear and I was conscious of the synchromesh "working", it wouldn't grind but you could feel it in the stick.
    I changed to the Motorcraft fluid at 30K, the first trip around the block was an amazing change, now at 80K it still shifts nice and slick.
    Motorcraft data sheet:
    https://fcsdchemicalsandlubricants.com/products/transmission-fluid/productdetails?id=1
    Rock Auto had the best price.
    https://www.rockauto.com/en/parts/motorcraft,XTM5QS,transmission+fluid,13630
  16. May 13, 2025 at 6:29 PM
    RunnerBlue4
    RunnerBlue4 Active Member
    Mark
    My 2017 TRD Sport manual with 48,000 miles shift pretty smooth. But, I'm tempted to switch out the transmission fluid with Motorcraft just based on the age.
    DTaco18 likes this.
  17. May 14, 2025 at 5:18 AM
    Alakablamo
    Alakablamo Member
    2023 TRD OR Manual
    I've got the Amsoil 75w90 GL-4 in both Tacomas now, but might have to try the Motorcraft next time. I just change it every 30k along with the differentials and transfer case.
    Transmission: AMSOIL 75W-90 Manual Transmission & Transaxle Gear Lube (GL-4)
    Differentials: AMSOIL Severe Gear 75w-140
    Transfer Case: Redline MT-LV (GL-4)
  18. May 15, 2025 at 2:20 AM
    DavidSmothers
    DavidSmothers Well-Known Member
    David
    Olive Branch MS
    2021 Tacoma TRD SPORT
    Which Redline were you running?
  19. May 15, 2025 at 3:40 AM
    Clearwater Bill
    Billy
    Largo Florida
    MT90.
    It was good. Ford was better. IMHO of course. It completely solved any 2-1 downshift resistance
