3rd Gen Manual Transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mel2020, Dec 20, 2023.
  1. Dec 22, 2023 at 12:04 PM
    #61
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    A data point is a data point. Chime in as you like. OP was looking for reliability information and you provided! :thumbsup:
  2. Dec 22, 2023 at 4:10 PM
    #62
    mjbrown210
    mjbrown210 Member
    Alabama
    2017 2.7l SR 4x4 (M/T)
    One thing I'll say is that when it's cold, the clutch sucks to shift. Apparently that issue is because of the accumulator, which there's plenty of writeups on here on getting rid of that
  3. Dec 22, 2023 at 4:11 PM
    #63
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Cold performance is same before and after accumulator. The clutch is slow to come back up in the cold, that is for sure.
    Junkhead and Speedfreak like this.
  4. Dec 22, 2023 at 4:48 PM
    #64
    BillyE
    BillyE Well-Known Member
    Use low viscosity brake fluid.
  5. Dec 22, 2023 at 5:05 PM
    #65
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    What ratio did you go with on the re-gear?
    What are your thoughts on the outcome?
    What will the RC60F get you? (Is this the latest Hilux version?)
    I would have kept the 2lo mod... because of the removal effort and well, 2wd low.
    I am curious on the re-gear... but I do not think the benefit is worth the price. (at least now...)
    These are like $3k, right?
    I've heard about this - I can say that I've not experienced any cold issues with the clutch during Tahoe winters - I have noticed no impact at all...
    But my cold has been likely no lower than 20F.
  6. Dec 22, 2023 at 5:12 PM
    #66
    BLtheP
    Plano, TX
    5.29. I have 255/75R17 (32.1”) and I love it. It’s not for everyone, I’m around 2850 at 70. Highway mpg is 17-18 at 70-75, which for me was about same as stock. It is noisier than stock, but harmless noise. The transmission makes a slight whistle when spinning this fast. It’s harmless, 21K miles later nothing has changed.
    RC60F would get me a lower 1-2-3-R and a taller 5-6, so lower rpm highway cruising and even more torque in the 4 lower gears. Same 4th as now and 5th and 6th less torque but lower rpm.
    I could have kept 2WD low but I never had a use for it, and since it technically adds a potential fail point, I decided to just remove it. I never had any problems, but I did see 2 people who did have problems (probably needed to replace the relay). That is obviously a super low failure rate and I wouldn’t ever tell others to avoid it, its a good mod, I just didn’t feel I needed it enough to justify keeping it. So off it went.
    1st will be very low when I’m done. I’ll probably start in 2nd more often, but we’ll see. Lower 3rd will be nice and so will reverse. Bringing down the rpm in 6th is cool too though I’m also happy with where it’s at. High 2000s rpm at 70-75 has plenty of power for medium hills.
    Regear was around $3K. I did Revolution gears and mini kits, OEM seals, bearings, locker connector. Torco 85W-140.
  7. Dec 22, 2023 at 5:15 PM
    #67
    TacoTuesday1
    SD CA
    deleting accumulator is a common mod. Old cars do not have them.
    not sure why it’s even there. The system is hydraulic, not mechanical 1980’s.
    brake fluid quality varies. Some are low viscosity.
    I run regular but might try Pentosin DOT4 LV.
    Junkhead likes this.
  8. Dec 22, 2023 at 5:30 PM
    #68
    BLtheP
    Plano, TX
    I’ve only had my truck since May 2022, so one winter so far. I did the accumulator delete in June 2022, and I think I used Wagner 5.1 but I don’t really remember. That may have contributed. I noticed slow pedal anywhere from around 30° down to the lowest I saw which was I believe 10°.
    Haven’t noticed anything yet this year but we’ve only been down to 35° so far and I also did swap to the FJ metal pedal this year. Also, during the pedal swap, I used more brake fluid and I don’t remember what I used there but I think it was Dot 3. So…the reason it hasn’t been slow yet could be temps not cold enough yet, the new pedal, differences in fluids, or some combo of the 3. Time will tell.
    All that said, when it was slow, it was only that way for about 2 minutes. Surrounding heat warms up the clutch line pretty dang quick.
  9. Dec 22, 2023 at 5:36 PM
    #69
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    The last manual transmission I had was a 1993 Isuzu Rodeo…
    The question OP asked was how long the 3G manual transmission lasts before maintenance is required…durability of the transmission.
    It all depends on how owner treats/utilizes the clutch.
    Treat the tranny like crap and it will probably need work before expected.
    All this other info & dialogue is interesting though…
  10. Dec 22, 2023 at 6:35 PM
    #70
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    I’ve started giving the clutch a couple pumps before setting off in the cold. It’s helped.
  11. Dec 22, 2023 at 9:16 PM
    #71
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have that same transmission jack, that thing sure is handy!
    tonered[QUOTED] likes this.
  12. Dec 22, 2023 at 10:09 PM
    #72
    Ziggy16
    Ziggy16 Active Member
    22 off road
    Mines stock. No issues. It’s not the smoothest I have ever driven but nothing wrong. I just think instead of all these Mods maybe just get used to it . I see on forums a lot of people complain about them. I like mine and its quirks
    Junkhead and Canadian Caber like this.
  13. Dec 23, 2023 at 5:58 AM
    #73
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It did a great job.
    shakerhood[QUOTED] likes this.
  14. Dec 23, 2023 at 7:20 AM
    #74
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Well that was a totally worthless 4 pages.
  15. Dec 23, 2023 at 7:46 AM
    #75
    Thegrassisalwaysgreener
    Thegrassisalwaysgreener Well-Known Member
    Manitoba
    ADM is free dude. Take it out and Dremel a channel in it. Pretty simple mod that made a big difference on my truck, but I'm a heavy duty mechanic and I like to tinker with stuff. I wasn't interested in getting used to the clutch slipping. 20230821_131946.jpg
  16. Dec 23, 2023 at 10:47 AM
    #76
    AZ_FireTaco
    AZ_FireTaco Active Member
    2018 Inferno O/R 4x manual
    2018, at 50k miles. Trouble free. 2low mod is great, and I have the Core shifter. Wouldn't have it any other way.
  17. Dec 23, 2023 at 10:48 AM
    #77
    Manitoba
    The core shifter is my favorite mod. Absolutely love it.
  18. Dec 23, 2023 at 10:56 AM
    #78
    BLtheP
    Plano, TX
    Is it not notchy? Every short throw I’ve ever used has been notchy, which is exactly why I didn’t get one for this truck. That and the noise complaints. I would be interested to try one. I did try a friend’s B&M and I was not a fan, but I think some of the screws in it are loose, causing it to not feel or shift right.
  19. Dec 23, 2023 at 11:05 AM
    #79
    Manitoba
    It's notchy in the best way possible, it's very tight no play at all. Notchy is a good thing, I never accidentally put it in reverse anymore. I didn't install the stock bolts that mount the shaft to the stub I got longer ones with locknuts. I really don't get the noise complaints it barely makes any noise. My opinion on that is the guys complaining about noise shouldn't have it.
    One of my favorite things about it is how much it repositions the shifter towards the driver. When I'm in 6th now it's in a similar position to 4th with the stock shifter. The stock shifter is floppy garbage.
  20. Dec 23, 2023 at 12:09 PM
    #80
    AZ_FireTaco
    Is it notchy, compared to stock? Sure. There is no ambiguity as to what gear you have. I prefer the rifle bolt feel, which I get may not be for all. As the shifter is directly attached to the trans there is gear whine which comes through, the divorced shifter in my 07 mustang was quieter but was just as precise. Longer bolts and some insulating material reduces the sound transmitted, I didn't go that route. I really like it and consider it a good upgrade moving the shifter towards the driver and making the throws shorter (I do have to slow down my shifting when in low, it will make the shift - but with some clunks as it moves faster than the synchros can do their thing).
