3rd Gen Manual Transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mel2020, Dec 20, 2023.
  1. Feb 3, 2024 at 1:55 PM
    #101
    HighIronHooligan
    HighIronHooligan TW Misfit
    Paul
    Tucson, AZ
    2022 MGM OR DCSB MT
    Why exactly?
  2. Feb 3, 2024 at 2:05 PM
    #102
    AZ_FireTaco
    AZ_FireTaco Active Member
    2018 Inferno O/R 4x manual
    Can't comment on B&M but the Core Shifter is fantastic. I went with Core as it is a complete replacement moving the pivot rather than a spacer. Does it bring noise into the cabin....yes. the stock shifter is two sticks bonded with a rubber bushing, noise and gear whine come through. My two cents. Cheers.
    Edit... I don't recall the B&M being available when I purchased the Core. The B&M looks very similar to the Core, in contrast to UDR which was a spacer for the stock shifter.
  3. Feb 3, 2024 at 2:33 PM
    #103
    Thegrassisalwaysgreener
    Thegrassisalwaysgreener Well-Known Member
    Manitoba
    The b&m looks like it still uses a rubber isolated shaft which alone made me pass on it. Also doesn't change the position of the shifter to be closer to the driver like the core does and thats a really nice feature.
    Go read the core shifter thread. I would never be able to go back to stock, the extra noise the core shifter makes is a wash. I don't even notice it. Buy a core shifter and thank me later, its the single best mod ive made to any of my vehicles.
  4. Feb 3, 2024 at 3:16 PM
    #104
    HighIronHooligan
    Paul
    Tucson, AZ
    2022 MGM OR DCSB MT
    After doing my homework on both, I ended up with the B&M... and I'm happy with the quality and performance of it. Huge improvement over the stock shifter. IMHO, as tight as it feels in the cab I didn't want the shifter any closer, and I didn't really want to invite noise into the cab via the shifter either. To each their own. It's nice that both are solid options to someone looking for an upgrade.
  5. Feb 3, 2024 at 3:24 PM
    #105
    Manitoba
    Can't really go wrong with either. I honestly wasnt sure about moving the shifter closer but now that I've had it for a while it's a very good position. The noise thing like I said is massively overblown by people. It's barely anything.
  6. Feb 3, 2024 at 3:45 PM
    #106
    HighIronHooligan
    Paul
    Tucson, AZ
    2022 MGM OR DCSB MT
    Well now, that's not quite the same as telling somebody to skip the B&M, is it? The takeaway for all the guys and gals of TW possibly following along is that the Core shifter is not the be all and end all for a legitimate shifter upgrade.
    moon22 likes this.
  7. Feb 3, 2024 at 3:47 PM
    #107
    Manitoba
    I would skip the b&m and I did lol. My point is either is better then stock. It's not my job to convince people what to do just sharing my opinion.
  8. Feb 3, 2024 at 3:54 PM
    #108
    HighIronHooligan
    Paul
    Tucson, AZ
    2022 MGM OR DCSB MT
    My point is that confirmation bias is alive and well on TW.
    doublethebass and moon22 like this.
  9. Feb 3, 2024 at 4:04 PM
    #109
    Manitoba
    You like b&m, I like core. Nothing wrong with that :drunk:
  10. Feb 3, 2024 at 4:50 PM
    #110
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    Curious about the motivation to change the shifter. I've thought it's completely fine, gates are clearly defined, etc. What doesn't everyone like about it? The long throws?
  11. Feb 3, 2024 at 5:13 PM
    #111
    Manitoba
    Much shorter throws, zero play in the shifter. It just tightens it up overall. I believe if you tried one with a short throw shifter you would understand why people change them. Also next to impossible to accidentally pop it in reverse in a high stress situation.
    It's certainly not mandatory but it improves things alot. Then again some people say they don't like them, I can't imagine why myself.
  12. Feb 3, 2024 at 5:23 PM
    #112
    Cetacean Sensation
    PNW
    Do people often put it in reverse on accident?
    All my BMWs have reverse in the same place with the same kind of lock out and nobody on those forums talks about panic hitting reverse. Can’t say it’s something I’ve ever done, either.
    I can already shift faster than the motor can drop revs, why would I want to shorten the throws? Not trying to be an ass, just genuinely asking.
  13. Feb 3, 2024 at 5:43 PM
    #113
    Manitoba
    I have thrown mine into reverse by accident a couple of times, one being after I was sideswiped and my adrenaline was pumping trying to get out of traffic. Like I said it's not a completely necessary mod, To me it just makes the whole driving experience more enjoyable.
    I just wanted to try one and I really like it. The shifter being in a more natural position closer to the driver was an added bonus as well. Long story short you don't really need one it's just nice.
  14. Feb 3, 2024 at 6:04 PM
    #114
    Cetacean Sensation
    PNW
    Id definitely be curious to drive one!
  15. Feb 3, 2024 at 6:30 PM
    #115
    AZ_FireTaco
    I had one on my last vehicle and got spoiled. I also have a Rago bridge where I have a Yaesu ham radio display, which the stock shifter gets really close to, never hit but close. Tightens everything up, moves the stick a bit towards the driver. I can keep my arm still and shift with wrist movement, that's how close it is now.
  16. Feb 3, 2024 at 8:02 PM
    #116
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    I have definitely found myself unintentionally in reverse more than a couple times, usually when in a hurry. Almost backed in to a guy at a busy intersection the first time it happened, I am obviously more aware of it now but I would still love an interlock of some sort. “In case of emergency, jam left and shove forward” a little too ingrained in my muscle memory I suppose.
  17. Feb 3, 2024 at 8:07 PM
    #117
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    They’re certainly interesting to drive with a short throw shifter, and I guess you really need to try it yourself to decide. I prefer stock because it’s a lot more “comfortable” to use in my opinion, due to the longer throws. I find short throw shifters to often feel notchy where you can really feel the synchros working, and I don’t like that.
    The rev hang is also slow enough that a super short shift that I complete before the revs fall is counter intuitive to me. Feels unnatural. So between that and the softer shifts with the longer throw stock shifter, I prefer stock.
    The noise aspect of the Core is subjective. I haven’t heard how they sound, but rarely do I find any amount of added noise tolerable. I bet after a while I’d rip out the Core if it added noise, but I need to hear it to confirm that. I will say my regear added plentiful noise, 5th and 6th make some ringing noise from the higher transmission/driveline speeds and I don’t like it at all. I’m used to it and it is what it is, but I certainly don’t like it. But gears are expensive. If something like a shifter added similar noise, I’d likely remove and sell. I am curious to see how the Core sounds. B&M adds no noise and I like that.
  18. Feb 3, 2024 at 8:09 PM
    #118
    BLtheP
    Plano, TX
    I think I’ve done that 3 times in almost 2 years. Mostly front loaded, I think they all happened within the first few months. So not really a problem now, but a true lockout collar or push down requirement would be a better choice. My frontier had you push down on the shifter slightly and then you could get to R, that was perfect to me. I do like it up by 1 better than down by 6. So a lockout and keeping it where it is would be ideal IMO.
  19. Feb 3, 2024 at 8:16 PM
    #119
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    A lockout is more feasible, maybe even a stiffer gate spring; but left and back would be a little more of a natural flow for situations where you need to rock.
    And while I am designing transmissions, how about a lockout, reverse left- forward and a granny gear left-back? Yeah?
    What’s that? From the guy in the back? A reasonable reverse ratio…? Now you’re just getting greedy. Just be happy you have reverse at all.
    AZ_FireTaco likes this.
  20. Feb 3, 2024 at 8:18 PM
    #120
    BLtheP
    Plano, TX
    Unfortunately you have to spend $7k on a regear and a 2024 transmission to get a good reverse. You can get a medium decent reverse spending only $3k and choosing one or the other. Lol.
    Or $120 and do the 2LO dance when needed of course.
