3rd Gen Manual Transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mel2020, Dec 20, 2023.
  1. Feb 3, 2024 at 8:24 PM
    #121
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    At that point I start to wonder about a completely different transmission all together. Although I will be curious what street/used price will be on the 4G unit; if I am not mistaken, 1st, 2nd and reverse are lower and 6th is a touch higher right?
    That dealership in Topeka with the black friday deals better get their forklift in tip-top shape this coming Thanksgiving..
  2. Feb 3, 2024 at 8:24 PM
    #122
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    Now you're just describing the Ford Bronco :p
  3. Feb 3, 2024 at 8:28 PM
    #123
    Cetacean Sensation
    PNW
    Yeah this is a point I touched on earlier too. With a stock transmission I already have to take care to not shift faster than the motor can drop revs. I feel like putting an SSK in this thing would just exacerbate that.
    But if anyone here is in the Portland area and willing, I'd definitely be curious to try it :thumbsup:
    akimmel and moon22 like this.
  4. Feb 3, 2024 at 8:29 PM
    #124
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    Time to pioneer the Bronco Box Swap I guess.
  5. Feb 3, 2024 at 8:31 PM
    #125
    Cetacean Sensation
    PNW
    I’ve driven one. It’s an enjoyable gearbox to use actually. Though it feels like the box in my 1 series.
    shakerhood and moon22[QUOTED] like this.
  6. Feb 3, 2024 at 8:44 PM
    #126
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    RC60F in the 4th gen.
    R-1-2 - 20% lower
    3 - 9% lower
    4 - Same
    5 - 9% taller
    6 - 10% taller
    I’m going to be buying one as soon as the part number (33030-04080) is available for purchase. So far the parts catalog still does not exist to the public but I know that’s what the part number will be. I am regeared already so the lower R-1-2 will be nuts. The taller 6th will actually help compliment the regear as well to bring the rpm back down some at cruise speed. It’s a bit revvy currently (2850@70) which I actually don’t mind at all but bringing it down a titch could be nice.
  7. Feb 3, 2024 at 8:47 PM
    #127
    BLtheP
    Plano, TX
    Definitely worth trying if you can find one to drive nearby just to see. I’d probably lean B&M if I were choosing due to the non blingy appearance and because I drove one and know how it is. And because no noises. But I would be curious to see the Core noise for sure. I imagine on mine it would be extra noisy because of the gear noise I already get.
  8. Jun 1, 2024 at 12:22 PM
    #128
    4point0
    4point0 Well-Known Member
    Simply awesome! I've read your posts here and seen your truck's YouTube video. Hard to keep up but I understand you're still on original clutch and clutch related components? Curious to hear how your throwout bearing is holding up, along with other clutch components? Thanks.
  9. Jun 1, 2024 at 1:07 PM
    #129
    2013logan
    2013logan Active Member
    New Mexico
    2019 Tacoma TRD pro
    icon add a leaf, KD max tune,RSG sliders, Falken 33inch MT, eibach spring, arb front locking diff,ARB air compressor.baja designs squadron fog lights non dot comliiant.
    45 k no issues except the clutch pedal makes that rubbing sound a common problem on tacomas 3rd gen and second gen a little grease will fix it other than that no problems my 2nd gen needed a clutch at 100k the bearing started to go out
    4point0 likes this.
  10. Jun 3, 2024 at 7:42 AM
    #130
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    Everything is still factory. Never had the trans out yet.
    4point0[QUOTED] likes this.
  11. Jun 3, 2024 at 8:05 AM
    #131
    4point0
    That is pretty damn cool :cool:. Are your miles mainly highway miles? Do you do a lot of city driving at all? I also understand that you do a lot of towing? Would be great to mimic whatever you're doing to have the clutch system last that long.
  12. Sep 1, 2024 at 1:39 PM
    #132
    Rhody929
    Rhody929 Well-Known Member
    Rhode Island
    2021 TRD Sport AC MT
    3rd gen feels way different than 1st gen. Only issue I’ve ever had with my 1st gen is replacing the clutch at about 150k miles. Shes now at 260k with no issues.
  13. Sep 1, 2024 at 1:45 PM
    #133
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Is RC60F compatible with 2GR-FKS? does the engine programming behave the same with a different trans?
