3rd gen misfire at 18k
Discussion in '3rd Gen. Tacomas (2016-2023)' started by texas_taco19, Jun 15, 2020.
  1. Jun 15, 2020 at 4:17 AM
    texas_taco19
    texas_taco19 [OP] Member
    2019 Tacoma Cement
    Rago rock rails, rago ditch light bracket.
    Just took in my 2019 Tacoma, 3.5, after the check engine light popped. Dealer needed to keep it over the weekend because the code said “Cyl 3 misfire”, according to my service rep. The truck only has 18,000 miles...and is primarily driven on the highway. Engine oil has been changed in time, I use good gas....is this a normal thing? I thought these things were supposed to be bullet proof.
  2. Jun 15, 2020 at 4:24 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    The idea of bullet proof ended with the first gen six cylinder
  3. Jun 15, 2020 at 4:27 AM
    texas_taco19
    2019 Tacoma Cement
    Ah, a purist. This is my first Toyota, just a little disappointed.
  4. Jun 15, 2020 at 4:35 AM
    Loco_Barbon
    Loco_Barbon Just deez nutz hangin’ out
    Hugh Mungus
    Where ever my 10mm isn’t
    i LiKe tRuCkS!!
    Penis valve stem caps.
    Deffently not a "normal thing" at 18000 miles. I know on some other vehicals the P303 code (cyl. 3 missfire) is a type of generic code the the ECM will throw when it knows something is wrong but can not pinpoint it. I not 100% sure that is the case with the 3rd gens, but I have seen similar situations that resulted in things like a glitch in the airflow meter, or O2 sensor.
  5. Jun 15, 2020 at 4:40 AM
    texas_taco19
    2019 Tacoma Cement
    Oh ok. Still, though. The fact that this happened is a little nuts to me. 50 miles of driving a day, 75 mph on the highway. And has been off-road one time, for 5 minutes to pull a trailer out of sand (MTS for the win)...is a little odd to me.
  6. Jun 15, 2020 at 4:42 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Some parts just fail early, it's under warranty, let Toyota fix it. Could be as simple as a bad coil or fuel injector. Stuff does happen.
    Chew likes this.
  7. Jun 15, 2020 at 4:44 AM
    texas_taco19
    2019 Tacoma Cement
    Yeah that’s what they told me it would probably be. It was taken in the following day of the light pop, so hopefully they get back with me today and tell me it wasn’t anything huge.
  8. Jun 15, 2020 at 8:01 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Nothing is infallible..... Electronic stuff does just have some things that prematurely fail (infant-mortality), most of the time it doesn't (if made well) and it's very reliable. Sometimes you get something that fails. Just a fact of life.
    When everything was mechanical, you could actually ensure this doesn't happen, but that required everyone to be on their A game when building it (and good design). Still, what we have now is better.
    Anyways, as long as something didn't cause the failure, I wouldn't sweat it. It happens. Now if a bunch of things go wrong at different times.... well, then I'd be concerned.
    BTW, this truck ain't perfect, but it's pretty good for what it is.
    Chew likes this.
  9. Jun 15, 2020 at 8:27 AM
    Hank Heel
    Hank Heel Well-Known Member
    WA
  10. Jun 15, 2020 at 4:07 PM
    texas_taco19
    2019 Tacoma Cement
    Update: Service manager called me and told me injector was bad, and "an internal part". when i asked what part, he didn't know and said he'd ask the mechanic....doesn't sound promising. They will have it till Friday or Saturday.
