3rd Gen Mods & Tips
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tcBob, Apr 24, 2016.
  1. Feb 7, 2017 at 6:38 PM
    amontances
    amontances Well-Known Member
    2017 White Tacoma OR
    TRD Pipes | 18" Fuel Assault | Roof Rack | Tint | Steps | Husky Floor Liners | Bed Liner | LED Interior Lights | Swing Arm Bed Storage |
    does anyone have a front camera mod integrated into the stock head? similar to the any time backup camera mod...
  2. Feb 7, 2017 at 8:35 PM
    Hoangde
    Hoangde Well-Known Member
  3. Feb 8, 2017 at 4:51 AM
    amontances
    this is awesome... i've scoured the search tw and google for something like this, but came up empty handed. this is exactly what i was looking for! thanks for the assist...
  4. Apr 11, 2017 at 8:26 AM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
  5. Apr 27, 2017 at 9:33 PM
    Blanco_s13
    Blanco_s13 Member
    Andrew
    California
    2017 Tacoma Trd Sport 4x4
    These are some great write up links!
  6. Apr 29, 2017 at 8:44 AM
    Krytar
    Krytar Member
    Larry
    2016 Toyota Tacoma Limited
    None
    My 2016 Tacoma has GoPro camera mount close to the rear mirror. Just wonder if anyone know how to mod the power from the mirror to connect to the GoPro?
  7. May 1, 2017 at 8:33 AM
    ronoc
    ronoc WisTaco Guy
    Madison, WI
    Bruce 2017 TRD OR DCLB 4x4
    Line-X coated Leer 180 topper Prinsu cab rack Ebay Pro Grill
    http://pinoutguide.com/ChargersAdapters/mini_usb_charger_pinout.shtml
    Find +5V in your mirror power send it to pin 1,
    put a 100 Ohm resistor between pins 2 and 3 on the charger end
    ground pin 5.
    And there ya go.
    Quimby, Khrolar and tcjacado like this.
  8. May 3, 2017 at 7:25 AM
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    I'm still looking for a mod to keep the fogs on while the high beams are on
    Woodzyzewski and tcjacado like this.
  9. May 3, 2017 at 7:34 AM
    tcjacado
    tcjacado Well-Known Member
    Can't you just tap into the high beam wire and put a diode on the wire between fogs and high beam?
  10. May 3, 2017 at 2:03 PM
    2016trdtacoma
    Trevor
    Utah
    I guess.
    I'm not completely inept at wiring, but no expert either so write up's etc help
    tcjacado[QUOTED] likes this.
  11. May 3, 2017 at 2:43 PM
    tcjacado
    Look up the raptor light mod. That will give you a basic idea, I think
  12. May 3, 2017 at 4:01 PM
    2016trdtacoma
    Trevor
    Utah
    is that spelled right... no info
  13. May 3, 2017 at 4:13 PM
    tcjacado
    Thanks. As of yesterday I can't spell don't know what happened. Maybe a mild stroke. Lol
  14. May 3, 2017 at 4:29 PM
    2016trdtacoma
    Trevor
    Utah
    NP
    Looked that up and that brought some info. I will sort through it.
    I find it interesting that there is pretty much zero info on this mod for the 2016 tacomas. I tried fiddling with it today, but no luck. It's been hard to find a diagram of the
    relay so I can kow what each prong is....
  15. May 3, 2017 at 5:12 PM
    #35
    tcjacado
    I will see if I can find anything. You can also pull the relay and bench test I suppose If you want to look that up.
  16. May 3, 2017 at 5:28 PM
    #36
    2016trdtacoma
    Trevor
    Utah
    Ya, I'm going to use this as a guide and go through each prong: https://www.tacomaworld.com/threads...no-splicing-no-bending-100-reversible.309407/
    I even tried the exact prong on the relay (https://www.tacomaworld.com/threads/fog-light-mod-2013.243346/) and used a pig tail to connect it straight to the battery but the fogs did not turn on. Makes me think the other prong is the power in...
  17. May 3, 2017 at 8:15 PM
    #37
    2016trdtacoma
    Trevor
    Utah
    I tried every possible combination with the relay, using this concept: https://www.tacomaworld.com/threads...no-splicing-no-bending-100-reversible.309407/
    I was using one of these: https://www.delcity.net/store/Mini-...5_FcCa5hXZevBtiuW6cfwYG3z8mtFMJ6xmBoC-mLw_wcB
    and then connecting it to varies fuses within the fuse holders... nothing worked
    The fogs would turn on, but not stay on when high beams are on. Either I am doing something wrong, or there are other things going on with the wiring that I do not understand yet.
    Any electrical gurus have any thoughts?
  18. May 3, 2017 at 8:19 PM
    #38
    tcjacado
    @mesojdm have any thoughts?
  19. May 3, 2017 at 8:35 PM
    #39
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    ^ fog light anytime mod is actually on my to-do list. Haven't dug into it yet.. but there is a way I bet
  20. May 3, 2017 at 8:37 PM
    #40
    tcjacado
    @2016trdtacoma just wait. Go look at mesojdm's mods, be patient and if anyone can figure it out he will.
    Rusty_1 and 2016trdtacoma like this.
