3rd Gen MT Drain Plug
Discussion in '3rd Gen. Tacomas (2016-2023)' started by arthur106, Oct 30, 2023.
  1. Oct 30, 2023 at 2:59 PM
    arthur106
    arthur106 [OP] Well-Known Member
    Jacob
    Houston
    Black '10 SR5 4WD 5MT
    Should the drain plug be magnetic? That’s what I’ve seen in the past with it the vehicles and certainly what I was expecting. The MT drain and fill plugs appear to be identical however, and neither are magnetic. I just wanted to double check that before reinstalling.
  2. Oct 30, 2023 at 3:16 PM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Toyota installs a magnet deep inside the transmission, it can’t be cleaned or serviced w/o breaking down the transmission.
    Adding magnetic drain and fill plugs certainly won’t hurt. I add them to various locations.
    Stevie17 and arthur106[OP] like this.
  3. Oct 30, 2023 at 3:19 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Yeah, not magnetic. Never had a single shaving on my drain plug and I’ve pulled it numerous times.
    Stevie17 likes this.
  4. Oct 30, 2023 at 3:34 PM
    arthur106
    Jacob
    Houston
    Thanks y’all. I figured they knew what they were doing when they assembled it, but I’ve seen stranger things
  5. Oct 30, 2023 at 4:39 PM
    arthur106
    Jacob
    Houston
