3rd Gen Non-stock, but OEM wheels?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Woodrow F Call, Mar 1, 2017.
  1. Mar 2, 2017 at 2:25 PM
    #81
    Storman
    Storman Fukitol abuser
    South Western PA
    2017 SR AC 4x4 AT AC UP ->LONG BED<-
    Whole bunch of shit! $$$
    Damn, that sucks.....sacrifice MPG for vanity...damn!
  2. Mar 2, 2017 at 3:44 PM
    #82
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Don't forget that the larger diameter 265 will rotate less than the smaller diameter 245, giving you slightly incorrect fuel economy readings (based on odometer). Actual gas mileage is better than you are calculating. The best way to calculate that is using a GPS to record mileage, not the odometer or trip meter.
    Storman likes this.
  3. Mar 3, 2017 at 5:50 AM
    #83
    Woodrow F Call
    Woodrow F Call [OP] Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    265 isn't the diameter of the tire. It's the width. The diameter is as follows:
    2 x (Width x Aspect Ratio) + Wheel Diameter = Tire diameter
    The aspect ration is a percentage.
    Don't forget to convert the width to inches to get equal units. You can do this by dividing with width by 25.4 mm/in.
    For 265/70 R16 tires:
    2 x ((265mm/25.4mm/in) x .70) + 16 in = 30.6 in
    In my case, the tire diameter is about the same as the aspect ratio of the wider tire is smaller than the narrow tire.
  4. Mar 3, 2017 at 6:28 AM
    #84
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    To add my 2 cents, here are my results on wheel/tire swap ...
    16" Steelie (29lb measured) + 245/75R16 Hankook Dynapro HT (33lb) = 62lb
    17" FN fx Pro(24 lb measured) + 265/65R17 Cooper Discoverer AT3 (39lb) = 63lb
    Not much change, but 6lbs of the weight was redistributed farther from center ... which I was a bit worried about. But, no noticeable MPG loss for me.
    Storman[QUOTED] likes this.
  5. Mar 3, 2017 at 7:17 AM
    #85
    Storman
    South Western PA
    Almost same exact set up running except I have the TRD OR wheels and tires at 265 70 16s.....I doubt I would notice anything either.....although I haven't done a fuel consumption comparison yet, I would bet it would be pretty close to the same...
    7r41lbr34k3r[QUOTED] likes this.
  6. Mar 3, 2017 at 9:19 AM
    #86
    Leeland111
    Leeland111 Well-Known Member
    2016 Magnetic Gray TRD Sport Double Cab RWD
    Factory JBL
    I'm extremely happy that I didn't get the black ones. I was second guessing myself until they were installed.
    Spare Parts[QUOTED] likes this.
  7. Mar 3, 2017 at 5:12 PM
    #87
    MannyS
    MannyS Well-Known Member
    Republic of Texas
  8. Apr 7, 2017 at 7:47 AM
    #88
    Woodrow F Call
    Colorful Colorado
    Anyone run the FJ steelies on a 3rd gen?
