3rd gen oil change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TripleTee315, Oct 6, 2024.
  1. Oct 6, 2024 at 4:41 PM
    TripleTee315
    TripleTee315 [OP] New Member
    2023 Tacoma Off-road V6 automatic
    In accordance with the warranty, is it necessary to change the filter EVERYTIME when you change the oil?
    Thanks y’all ,from minnesota
  2. Oct 6, 2024 at 4:49 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Don't know why you wouldn't change the filter on every oil change. Inexpensive and easy to do. Can't answer the warranty question.
    Chew likes this.
  3. Oct 6, 2024 at 4:51 PM
    TripleTee315
    Thanks man
  4. Oct 6, 2024 at 4:54 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Toyota specifies oil AND filter every 10k miles. I suppose if you changed the oil every 5k and filter every 10k you’d still be good. In the end they’d have to prove that your lack of filter changes caused the failure and that’s quite unlikely.
  5. Oct 6, 2024 at 4:57 PM
    MGMDesertTaco
    I don't see how they'd know, but I've always changed both at the same time.
    There's a risk of reintroducing contamination into the system and the filter disintegrating by leaving it in place for extended intervals.
  6. Oct 6, 2024 at 4:59 PM
    Trail Limo
    Trail Limo Well-Known Member
    Why not change it?
    TacoTime55 and Chew like this.
  7. Oct 6, 2024 at 5:20 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Second that.
    It's simple.
    Why cut THAT corner?
    Baffling. Shaking My Head (SMH)
    6MTPro and Chew like this.
  8. Oct 6, 2024 at 5:27 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    This. Check prices of engine replacement before you proceed. The filter is $5 and takes less than 10 minutes to change.
    helix66 likes this.
  9. Oct 6, 2024 at 5:34 PM
    TripleTee315
    Yea , yall right ! / filter change it is / might as well, I got the tool / thanks everybody
    Chew and TacoTime55 like this.
  10. Oct 6, 2024 at 5:44 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    It's for your own good...and that of thy truck! lol
  11. Oct 6, 2024 at 5:45 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    OPs a rebel, let em in!
    23MGM, Irons, RIX TUX and 1 other person like this.
  12. Oct 6, 2024 at 6:06 PM
    Clearwater Bill
    Billy
    Largo Florida
    Actually for the finicky type, changing the filter at 5k, toping the oil, then doing the full change at 10 is even better.
  13. Oct 6, 2024 at 10:08 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    in my f150 i would just change the filter around 5 or 6000 add a quart and at 10 or 12k change the oil and filter.....used mobil 1 .....synthetic oils are great
  14. Oct 7, 2024 at 7:08 AM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    I've only done one change on my '23 and found the filter change pretty easy so I'll likely change the filter with every change at 5K intervals. On my '96, I change the filter every other oil change. The filter is a hassle to get to and I'm changing oil every 1,500 miles.
  15. Oct 7, 2024 at 11:36 AM
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    It’s generally ok to change your filter every other change, but it depends on the quality and rating of your filter.
    I would never push the stock filter past 10k mi, for example. However, you could likely run a Fram Endurance up to 15k-20k mi with no ill effects.
