3rd Gen Onboard Air - It Fits!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ekimerpud, Feb 11, 2016.
  1. Feb 11, 2016 at 5:42 PM
    ekimerpud
    ekimerpud [OP] Well-Known Member
    Fort Worth, TX
    Picked up a ARB dual compressor and manifold kit. For those who were wondering, it fits like a glove behind the air box on Tacoma's without the Antilock system in that location. Fab'd a mount to utilize the three studs on the fender well. The manifold bolts up to existing holes on the fender wall. Just waiting on a switch from AirOnBoard to wire it up. Happy with the results.
    [​IMG] [​IMG] [​IMG]
    Couple pics of the mount before paint:
    [​IMG] [​IMG]
    Ganjafornia, Synergy001, 0210 and 2 others like this.
  2. Feb 11, 2016 at 5:45 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    are you talking about that open spot passenger side, next to the firewall?
  3. Feb 11, 2016 at 5:48 PM
    ekimerpud
    Fort Worth, TX
    Yep, that's the place.
  4. Feb 11, 2016 at 5:52 PM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    Cool stuff, when I saw the studs there I too was thinking of an arb compressor. Good to see someone did it, you mind putting up measurements for that adapter you built?
  5. Feb 11, 2016 at 6:08 PM
    ekimerpud
    Fort Worth, TX
    If I ever have the need to take it out, I'll take some measurements. Used 3/16 mild steel plate. From what I remember, the bottom plate attaches level to the ground on the forward 2 studs. The distance from the bottom of that plate and bottom of the lower third stud is 1.562 inches. I built a U shaped section to lower the attachment point of the rearward third stud then plasma cut clearance on the plate to allow access to the nut during install. The risers between the attachment plate of the compressor and the plate mounted to the truck is 2". The top plate ended up perfectly level. Hope this helps
    amazzajr likes this.
  6. Feb 11, 2016 at 8:59 PM
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    That's where I put mine as well, just the single compressor though.
    proven21 likes this.
  7. Feb 11, 2016 at 9:02 PM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    Nice :) Glad to see they left that spot open. That's where mine is mounted on my 2nd Gen too.
  8. Feb 11, 2016 at 11:34 PM
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Oh man that makes me happy. I have my 2nd battery in that spot for my 2nd gen. Not sure if it would fit in the 3rd gen but I don't plan on upgrading for quite a few years.
  9. Feb 12, 2016 at 5:27 AM
    SamChieftan
    SamChieftan Well-Known Member
    Dallas, Texas
    2016 TRD OR AUTO 4x4 Super White
    Interior LEDs, Truck Mat, Door sills
    Wow excellent professional job!
    Looks awesome!
  10. Feb 12, 2016 at 8:13 AM
    nwAdamR
    nwAdamR Well-Known Member
    Adam
    SW PDX
    2016 Tacoma TRD OR LB AT MGM
    I really need to start learning to work with metal. Killer job, OP.
  11. Feb 12, 2016 at 10:18 AM
    NV_Tacoma
    NV_Tacoma Well-Known Member
    Paul
    Northern Nevada
    2013 MGM ACLB TX Off Road
    2016 White DCSB TRD Off Road (Sold)
  12. Feb 12, 2016 at 12:05 PM
    Toneloc
    Toneloc Well-Known Member
    Northwest PA
    2016 DCSB 4x4 TRD OR
    Are you using this for a locker? Or just for filling your tires? Or some other use?
  13. Feb 12, 2016 at 12:11 PM
    krazyscot
    krazyscot Active Member
    Stuart
    Colorado Springs
    I was looking at that location for a second battery, it's big enough for that purpose. I noticed the ARB SEMA truck had mounted their compressor on the drivers side behind the fuse box though they used the single compressor. Not sure I want to give up flexibility of a second battery setup to house the double compressor....
    Arlaghan and Hobbs like this.
  14. Feb 12, 2016 at 12:21 PM
    ekimerpud
    Fort Worth, TX
    For now, filling tires and running occasional air tools. I might explore a front air locker in the future.
  15. Feb 12, 2016 at 12:22 PM
    ekimerpud
    Fort Worth, TX
    I'm planning on the dual battery system with two yellow tops right next to each other in the stock location. By my measurements, I can make that work.
  16. Feb 12, 2016 at 12:41 PM
    krazyscot
    Stuart
    Colorado Springs
    Good to know thanks. I haven't sat down and planned the detail yet, that was just my initial thoughts. Are you fabbing your own tray or do you someone who has designed a specific one for the Gen 3?
  17. Feb 12, 2016 at 12:46 PM
    Leonard Smalls
    Leonard Smalls Well-Known Member
    2016 Magnetic Gray Metallic TRD Sport 4X4
    Forgive my ignorance, but are these compressors designed to handle the heat associated with residing in the engine compartment?
  18. Feb 12, 2016 at 12:49 PM
    krazyscot
    Stuart
    Colorado Springs
    I haven't bought or installed one yet, but if ARB is installing theirs under the hood of the truck, I think it's safe to say that they can handle the temps in the engine compartment.
  19. Feb 12, 2016 at 12:50 PM
    Leonard Smalls
    Cool. Thanks :)
  20. Feb 12, 2016 at 4:34 PM
    ekimerpud
    Fort Worth, TX
    I haven't seen anyone selling a tray for the 3rd gen, so I'll probably end up fabricating one.
    Synergy001 likes this.
