3rd Gen or 4x4 Conversion?
Discussion in '1st Gen. Tacomas (1995-2004)' started by KidWithATacoma, Oct 25, 2020.
  1. Oct 25, 2020 at 9:23 PM
    TacoG214
    TacoG214 Member
    Garrett
    2003 Tacoma 2.4
    swapped from 2WD to 4WD
    yep looks good. I am sure you will end up buying more as you go and start seeing fit. Get lucky like me and buy a wrecked one with low miles that has none of the parts you need damaged for $700. hahahaha. Good luck my friend.
  2. Oct 25, 2020 at 9:33 PM
    KidWithATacoma
    KidWithATacoma [OP] Taco and Tacos Lover
    Mac
    Arlington, VA
    2021 TRD Offroad
    Debt
  3. Oct 25, 2020 at 9:49 PM
    TacoG214
    TacoG214 Member
    Garrett
    2003 Tacoma 2.4
    looks great. I did not do the wire harness part and had no issues.
  4. Oct 26, 2020 at 5:26 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    I have no experience walking anyone through a bolt by bolt conversion by text.
  5. Oct 26, 2020 at 9:53 AM
    ehvyy
    ehvyy Well-Known Member
    Evan
    2018 Toyota Tacoma TRD Off Road
  6. Oct 26, 2020 at 9:54 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    For?
  7. Oct 31, 2020 at 9:33 PM
    KidWithATacoma
    Mac
    Arlington, VA
    2021 TRD Offroad
    Debt
    I have started to look into the idea of getting a parts truck. Does anyone know if it matters if I get a 2 door or does it have to be a 4 door like mine?
  8. Oct 31, 2020 at 9:35 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The drive by wire is what makes it a tad more difficult for your model.
    It's a 2 year model thing (03-04).
  9. Oct 31, 2020 at 9:35 PM
    KidWithATacoma
    Mac
    Arlington, VA
    2021 TRD Offroad
    Debt
    Not over
    So just keep it within 03-4 but truck length doesn't matter?
  10. Oct 31, 2020 at 9:36 PM
    KidWithATacoma
    Mac
    Arlington, VA
    2021 TRD Offroad
    Debt
    Well not bolt by bolt but a general step by step.
    For example: Rip out this thing and swap it with this thing and then use this thing but don't forget to do this
  11. Oct 31, 2020 at 9:36 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Don't quote me on the rear drive shaft portion, but that is correct regarding the truck length not being an issue.
    Any shop can alter or create a new drive shaft for you for cheap.
  12. Nov 1, 2020 at 5:30 PM
    KidWithATacoma
    Mac
    Arlington, VA
    2021 TRD Offroad
    Debt
  13. Nov 1, 2020 at 5:39 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    if you find a donor 03-04 extended cab or 4 door 4x4 truck with an auto you will be good blown motor ideal but those are easier to fix so most likely will be a wreck). no manual hubs but you will have everything needed including the ECU/ECMs to start the swap
  14. Nov 1, 2020 at 5:41 PM
    KidWithATacoma
    Mac
    Arlington, VA
    2021 TRD Offroad
    Debt
    How bad of an idea is this? https://www.carfax.com/vehicle/5TEWN72N23Z199683
  15. Nov 1, 2020 at 5:42 PM
    #35
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    eh, chunking down 6500 for a parts truck isn't fiscally efficient. the parts list would be below $2500 all day when you can find them. If you are in a rush and have mucho $$$ then do whatever. but I sense you are trying to save the bucks anyway possible so keep looking at parts and hit up our own B/S/T
  16. Nov 1, 2020 at 5:51 PM
    #36
    KidWithATacoma
    Mac
    Arlington, VA
    2021 TRD Offroad
    Debt
    but it do come with a supercharger :mudding:
  17. Nov 1, 2020 at 5:54 PM
    #37
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    oooooo, I missed that. hhhmmmm. still would need to rebuild the S/C unless you can hear it run (~$1500?)
  18. Nov 1, 2020 at 5:59 PM
    #38
    KidWithATacoma
    Mac
    Arlington, VA
    2021 TRD Offroad
    Debt
    They claim it can run and its only 87 miles from home so I could go drive it
    frizzman[QUOTED] likes this.
  19. Nov 3, 2020 at 7:45 PM
    #39
    KidWithATacoma
    Mac
    Arlington, VA
    2021 TRD Offroad
    Debt
    Update:
    I am starting the search for parts and I am also taking a lot of notes because I am learning so much and I want someone who was in the same shoes as me to be able to get a lot of info.
    Here is what I am working on!:
  20. Nov 3, 2020 at 9:15 PM
    #40
    Kwikvette
    Fresno County
    4 run, 2 don't
    When buying a front diff, you need to match your gear ratio that's on your truck.
    Also, consider whether you want to clamp the ADD diff tube or find a manual diff tube since you're going manual hubs.
    As for the hubs themselves, you can buy them new from Low Range.
    May as well also buy manual axle hubs and new wheel bearings that way you can use your current spindles, or as labled in your list, steering knuckles.
