3rd gen OR coils to level?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tyler2009, Jan 27, 2016.
  1. Jan 27, 2016 at 5:13 PM
    tyler2009
    tyler2009 [OP] Well-Known Member
    Tyler
    NE Ohio
    2009 DCSB TRD Sport
    None
    Can't find enough info here on TW or across the Internet, so hopefully someone can give some insight. local craigslist guy has take off coils and 4 shocks from his 2016 TRD OR. I've learned the 2nd and 3rd gen coils are interchangeable. And I've heard someone on the forum claim that the 3rd gens DO sit higher than the 2nd gen but where his info came from I do not know and of course I can't find any specifics.
    I'm riding on stock sport suspension and would like to maintain a smooth on road ride.
    Will the 2016 OR coils provide any lift up front? And how will they ride in comparison to 09' sport coils? Would I be better off with OME 884's and 5100's for a smoother ride?
  2. Jan 27, 2016 at 5:14 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    i think the 3rd gen sits an inch taller than second gens
  3. Jan 27, 2016 at 10:56 PM
    tyler2009
    Tyler
    NE Ohio
    2009 DCSB TRD Sport
    None
    Id have to measure but I'm pretty sure an inch won't even bring me up to level. Might have to pass on the deal if this is the case.
  4. Mar 14, 2016 at 1:40 PM
    supra90140
    supra90140 Well-Known Member
    telford pa
    08 dbl cab 4x4 lb trd sport speedway blue tow pkg
    weather tech floor liners
    So I just got a pair of 16 trd sport coils. So you are saying they will add an inch of height to my 08
  5. Mar 16, 2016 at 4:03 AM
    tyler2009
    Tyler
    NE Ohio
    2009 DCSB TRD Sport
    None
    That's what is sounds like, but I don't have any experience. All I've found for sure is that they will fit 2nd gen...
  6. Mar 19, 2016 at 5:02 AM
    supra90140
    telford pa
    Would you be able to tell by the size of the spring? The 3rd gens are 14.5" high. Anyone know how high the 2nd gens are
  7. Mar 19, 2016 at 5:16 AM
    tyler2009
    Tyler
    NE Ohio
    2009 DCSB TRD Sport
    None
    It would probably point you in the right direction but I'm sure whatever the height difference is, their still may be a rate difference. Could be the same height but stiffer spring or could be a longer spring with lighter rating. Surprised with them being compatible on our trucks that nobody has more experience on this.
  8. Mar 20, 2016 at 11:13 AM
    supra90140
    telford pa
    My problem now is Im putting on 5100s and planned on setting them at 1.75 with a toytec AAL. But if these springs add another inch to the front I think I want to drop the front to .85 as I would like to retain some rake. So if someone could confirm that the 3rd gen coils do in fact add an inch of lift I would greatly appreciate it.
  9. Jun 9, 2016 at 5:53 PM
    irish_11
    irish_11 Well-Known Member
    Everett, WA
    2011 DCSB
    Just keep throwin' money at it.
    Sorry to bump an old thread. Did anyone find that a 3rd gens suspension added any lift to their 2nd gen? I've got a line on some cheap TRD take offs and I'm thinking based on the 70k mi on my suspension they will add a little lift just being newer and lower mileage. Thoughts?
  10. Jun 9, 2016 at 6:18 PM
    supra90140
    telford pa
    I have the 3rd gen coils with 5100s set to .85 and my front sits at about 22". I don't have pre lift measurements tho. Stock is 20.5 I believe tho.
  11. Jun 29, 2016 at 5:37 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I have a set of coils off of a 2014 TRD OR and they're 14.5 inches
  12. Aug 17, 2016 at 1:53 PM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    So if I had to guess the spring rate is higher and that's what gives it the lift?
  13. Aug 17, 2016 at 2:32 PM
    BassAckwards
    Im not sure about the 3rd gen coils, but i know that the progressive 2nd gen coils have a spring rate 50lbs higher than those on the sr5 and trd sports. I would assume that the increase in spring rate would have to account for the lift since they are the same length. Im getting my coils installed this weekend so i can post before and after measurements if youre interested. The measurements could be somewhat skewed though since im also setting billies at .85 with them.
  14. Aug 17, 2016 at 3:10 PM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Absolutely post. I dont know if we can make a good estimate since we don't have the same truck but somewhere someone has a truck similar to you that will want to know. Thanks.
  15. Aug 17, 2016 at 4:50 PM
    BassAckwards
    Ill keep you updated
    bigfoote13[QUOTED] likes this.
  16. Aug 29, 2016 at 6:20 AM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Did you get your coils install?
  17. Aug 29, 2016 at 6:24 AM
    BassAckwards
    Unfortunately i didnt. The guy that did my clutch was also supposed to install them for me but i dont think he had time to get around to it or he forgot. Either way im gonna have to figure something else out now. Sorry about that..
  18. Aug 29, 2016 at 6:29 AM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    No problem! Which shocks are you going to use?
  19. Aug 29, 2016 at 6:36 AM
    BassAckwards
    I have a set of 5100s that i was going to use with them, but now im contemplating waiting and saving up for kings since i want to long travel my truck. The 5100s were going to get me by till i could afford it
  20. Aug 29, 2016 at 6:40 AM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Gotcha thank you.
