3rd Gen Owners with King Coilovers
Discussion in 'Suspension' started by c4lvinnn, Jan 30, 2017.
  1. Apr 5, 2018 at 9:30 AM
    #961
    Pipeworx
    Pipeworx Well-Known Member
    I finally had enough and called Icon yesterday. After speaking with someone in technical support they confirmed that after 200 miles the uniball should be broken in and after seeing the video I posted they said they had a defective batch come through about a year ago. To smooth things over they gave me a healthy discount on a set of Delta Joints with installation tool so as soon as everything comes in I will be doing the install to get rid of these uniballs.
    Lord Helmet and mcharfauros like this.
  2. Apr 5, 2018 at 9:32 AM
    #962
    Gunner123
    Gunner123 Well-Known Member
    2018 TRD OR
    Wow that’s awesome! The guy at the shop I got my kit installed said that most people who don’t like the squeak upgrade to delta joints.
  3. Apr 5, 2018 at 9:50 AM
    #963
    Pipeworx
    If they are squeeking like mine in the video then they are defective. My drivers side is quiet and the passenger side squeeks, both sides are getting replaced and I have over 500 miles on them now.
  4. Apr 5, 2018 at 9:51 AM
    #964
    Gunner123
    2018 TRD OR
    I posted a video mine don’t really sound like yours though.
  5. Apr 5, 2018 at 9:53 AM
    #965
    4x4yotaphan
    4x4yotaphan Well-Known Member
    SoCal
    SOLD: 2016 White TRD Sport DCSB 4x4
    Exterior: King suspension w/compression adjusters Icon billet UCAs Icon 3 leaf expansion pack Timbren rear bump stops w/U bolt flip kit Wheeler’s Offroad front superbumps BFG KO2 285/70/R17 on SCS Ray 10 17” wheels w/black wheel lock lug nuts TRD Pro grill TRD Pro taillights TRD Pro skid plate Demello Offroad front bumper Smittybilt XRC 9.5 comp winch w/Factor 55 fairlead and Flatlink E RCI LCA skids Beast Fab rock sliders 4 Extreme LED 4” pods Baja Design Squadron SAE LED amber fog lights Relentless Fab bedrail mount w/KC Flex dual amber chase lights AVS vent visors Interior: TRD Pro shift knob OEM instrument switch panel conversion (from 3 to 5 slots) Taco Garage DMM with Scosche Magicmount Upgraded Kicker sound system Husky X-act floor liners Performance: Airaid cold air intake system Pedal Commander w/Bluetooth
    Did you see if lubing up your bushings helped?
  6. Apr 5, 2018 at 9:53 AM
    #966
    Gunner123
    2018 TRD OR
    They did and still squeaking.
  7. Apr 5, 2018 at 9:56 AM
    #967
    4x4yotaphan
    SoCal
    Wondering if you just got bushings that’s defective and may be not exact size bc it shouldn’t squeak like that off the bat and the movement you make doesn’t seem like the uniball is moving too much so can’t imagine the sound coming from there. Sounds more like rubber rubbing metal to me.
  8. Apr 5, 2018 at 9:58 AM
    #968
    Gunner123
    2018 TRD OR
    Interesting. Yeah the shop I got it done at does a lot of king and total chaos installs. They told me that it’ll get quiter as it breaks in. I don’t know if that sounds right though.
  9. Apr 5, 2018 at 10:03 AM
    #969
    4x4yotaphan
    SoCal
    I would hit up Total Chaos and ask them. Or what you can do is loosen your UCA bolt a little and then make the same movement to see if the noise is still there or if it improves. Maybe it’s over tightened? Which would cause the bushings to bulge more?? Try it out and make sure your torque it to factory specs aftermarket.
  10. Apr 5, 2018 at 10:05 AM
    #970
    Gunner123
    2018 TRD OR
    Okay I’ll try that out thanks for the advice!
  11. Apr 5, 2018 at 10:07 AM
    #971
    4x4yotaphan
    SoCal
    Also when you lube it up in the zerk fitting, make sure you have the UCA bolt loosened. Here’s a link to their vid.
    https://youtu.be/xvMdAX2uybs
    BobcatSR and Bastek like this.
  12. Apr 5, 2018 at 10:24 AM
    #972
    Chach1
    Chach1 Well-Known Member
    Horacio
    Carson
    2017 DC OR
    I have the same noise coming from mine right now and they were installed about two weeks ago.
  13. Apr 5, 2018 at 10:28 AM
    #973
    Gunner123
    2018 TRD OR
    Mine were installed about the same time
  14. Apr 5, 2018 at 11:42 AM
    #974
    4x4yotaphan
    SoCal
    That’s why I opted out to get heim joints and avoid bushings. Less maintenance and no need to lubricate but they cost a little more. Good luck guys on getting the noise resolved, hopefully it’s a simple fix.
  15. Apr 5, 2018 at 1:29 PM
    #975
    Gunner123
    2018 TRD OR
    I emailed total chaos and they said that it sounds like they need grease. So I’m going to a different shop To have them check it.
    mcharfauros likes this.
  16. Apr 5, 2018 at 1:36 PM
    #976
    4x4yotaphan
    SoCal
    Just make sure to remind them that the bolt needs to be loosened before putting grease in it like in the video I posted. Good luck brotha!
  17. Apr 5, 2018 at 1:37 PM
    #977
    Gunner123
    2018 TRD OR
    I will. I’m going to a shop that total chaos recommend I go to so I hope they know this but you never know. Thanks!
    4x4yotaphan[QUOTED] likes this.
  18. Apr 5, 2018 at 1:50 PM
    #978
    4x4yotaphan
    SoCal
    Might be worth it to invest in a zerk gun in the future so you maintain the greasing and avoid the noise.
  19. Apr 5, 2018 at 1:52 PM
    #979
    Gunner123
    2018 TRD OR
    Yep I’m looking into that now! I just ordered the ballpoint lube, next getting the zerk gun and lube that total chaos recommends!
  20. Apr 5, 2018 at 2:30 PM
    #980
    Chach1
    Horacio
    Carson
    2017 DC OR
    What shop did they recommend?
