3rd Gen Owners with King Coilovers
Discussion in 'Suspension' started by c4lvinnn, Jan 30, 2017.
  1. Aug 23, 2018 at 7:36 AM
    #1361
    riverrat12
    riverrat12 Well-Known Member
    2017 White Tacoma Off Road 4x4
    King all around Custom leafs GFC V2 Redarc / Dakota Lithium dual battery
    Nope, didn't have to do any shock relocating or welding. I got my shocks and UCA's from Camburg and then I ordered the leaf kit from rogue-off road. If you call them up and tell them what your looking to do they are super helpful and will be able to set you up with exactly what you need. I couldn't be happier with my truck and the way it looks / performs.
    2018SMURFPRO and mcharfauros like this.
  2. Aug 23, 2018 at 7:53 AM
    #1362
    CameHonor
    CameHonor Member
    Southern California
    2018 Toyota Tacoma TRD Sport
    TRD Skid Plate / Tweeter & Speakers Upgrade / Tinted Windows / Custom Front License Plate Holder / Flowmaster Exhuast / Etune Knobs Upgrade / TRD Pro Grille / OEM Bed Lighting /
    I'm in the same boat as you, I'm want to throw some OEM shocks on the front and rear and I'm not trying to get much more than maybe 1 inch above stock height on my 18' Taco. I'd rather not change the UCAs or leaf springs on my truck.
    Has anyone just bolted the OEM Kings that dont require any UCAs and had any problems with alignment? I'm planning on going .5" or 1" above stock height. Which is techinally a 1.5" to 2" lift (stock 18' Tacos have 1" of lift if im correct?). Says front OEMs can go up to 2" and rear is 1.5" without UCAs or Leafs.
    I really just want a smoother ride on bumpy open dirt roads and potholes/dips and for my truck to look clean :D
    2018SMURFPRO likes this.
  3. Aug 23, 2018 at 8:16 AM
    #1363
    2018SMURFPRO
    2018SMURFPRO Well-Known Member
    TOTAL CHAOS 3.5 LT RACE 18'S TE37 PROGRESSIVE
    Yes you can buy non-extended travel shocks. For the front it will already come at a 1 inch lift, anything over 2 inches is when it’s recommended to install UCA. For the rear you can run stock leaf springs and you will be pretty close to being leveled. If you later plan to going with a 2-3 inch lift for rear leaf springs, purchase the extended travel shocks.
  4. Aug 23, 2018 at 8:26 AM
    #1364
    smiles2
    smiles2 Well-Known Member
    2017 Blue Tacoma TRD Offroad
    I talked to Ben at Filthy Motorsports. He only sells the deavers as far as I know and he said you need a shock relocation with rear lift. I see many people with the ome springs and no relocation. I was also looking at ads and Marie at Headstrong said there is no relocation requirement for theirs with ome. Its very confusing. Just want around 2" lift but don't want to do any welding.
  5. Aug 23, 2018 at 8:38 AM
    #1365
    dskakie
    dskakie Well-Known Member
    Dan
    Northern CA
    2016 TRD OR DCSB
    Did you extend your rear brake lines? I’m putting the same setup on today.. looks good!
  6. Aug 23, 2018 at 9:12 AM
    #1366
    2018SMURFPRO
    You can get dakar leaf pack (EL095R X2) which will give you a 2 inch lift, you only do a relocation if you are trying to put a 10 inch or longer shock.
  7. Aug 23, 2018 at 9:18 AM
    #1367
    smiles2
    Thanks
  8. Aug 23, 2018 at 9:47 AM
    #1368
    riverrat12
    Thanks man! I bet your stoked, it will look good. And no I didn't have to extend them.
    dskakie[QUOTED] likes this.
  9. Aug 23, 2018 at 10:09 AM
    #1369
    dskakie
    Dan
    Northern CA
    2016 TRD OR DCSB
    Good deal! I’ll see how it looks once I’m done but hopefully will just need alignment then be good to go! Thanks for the reply! Yeah unfortunately I scheduled a dentist appt at noon today but then I can finish what I started late yesterday (front drivers side only, and added superbumps), looks killer so far!
  10. Aug 23, 2018 at 10:17 AM
    #1370
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    So I did a lot of legwork on this question when I was sourcing all my parts. You *CAN* run the non-ext rears, but they will limit travel, and it was recommended to limit strap it as a precaution. That said, just buy the extended version. I got the rears for a screaming deal off a friend so I had to work with what I had.
  11. Aug 23, 2018 at 11:15 AM
    #1371
    unavailableTaco
    unavailableTaco Well-Known Member
    Roy
    Grapevine Texas
    2018 Tacoma TRD PRO
    Full tank of gas
    I have been looking at them. They seem to be of high quality
  12. Aug 27, 2018 at 9:13 AM
    #1372
    20taco16
    20taco16 Well-Known Member
    Beau
    2017 metallic grey double cab long bed 4wd
    what coils are you running? how much preload do you have? I have the similar weight up front, just trying to decide on 650# or 700# coils.
    thanks in advanced.
  13. Aug 27, 2018 at 10:58 AM
    #1373
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    I’m running 700#’s. I have about 13 threads on the drivers side and about six on the passenger.
    It’s a bit stiff, but I don’t mind it. I think I’ve got the clickers adjusted about right for a daily driver. However, I lost count of where there set at.
  14. Aug 27, 2018 at 11:30 AM
    #1374
    20taco16
    Beau
    Gotcha,
    ya I have a hybrid bumper up front, about 110lbs, winch w/synthetic line, ~80lbs, front skid 30lbs, sliders, I run a RTT and such.......I have the 600# coils showing about 13 threads driver, 11 driver........but if im hitting big bumps where there is a quick drop, they top out, so im deciding if I should go 650# or 700# coils so I can pull down the preload.......im assuming that the less preload allows for more droop?
  15. Aug 27, 2018 at 1:21 PM
    #1375
    H3llRid3r
    SLcUT
    I would go with 7’s, if I were you.
    I’m no expert, but I would say since your compressing the spring you would be limiting the droop.
    Are you planning to remove your sway bar? I would if I were you. The stiffer springs helps ease the body roll. Well worth it to take the sway bar off.
  16. Aug 27, 2018 at 1:36 PM
    #1376
    2018SMURFPRO
    I also run the 700's and have been told it feels pretty soft.
  17. Aug 27, 2018 at 2:07 PM
    #1377
    Zchristie14
    Zchristie14 Member
    Zach
    North Dakota
    18 OR tacoma
    Who is in Oregon, specifically around Portland who wants to install front and rear Kings for me for free, in trade of my Bilstein 5100's kit.
  18. Aug 27, 2018 at 2:12 PM
    #1378
    20taco16
    Beau
    Sway bar has already been taken off.........so go with the 700# with what I have on the truck..........my RTT is on my bed rack, would that add weight to the front or just the back? I just don't want to do this coil change again and be out more money lol
  19. Aug 27, 2018 at 2:14 PM
    #1379
    20taco16
    Beau
    you have any pics of your rig with the 7's on?
  20. Aug 27, 2018 at 2:22 PM
    #1380
    2018SMURFPRO
    Acivichb, mcharfauros and chelseafc1 like this.
