3rd Gen pcv valve location, oil catch can install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Yzkiley, Jul 19, 2017.
  1. Nov 26, 2024 at 7:05 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Without starting a pro's vs con's fight, a major reason i've never ran one on my own vehicle(s) is due to winter time.
    As noted above, water/condensation is a major component these cans will take in when the temperature drops and if some ice plugs the inlet or outlet or otherwise restricts the vacuum pulled on the crankcase, you could very quickly have a lot of oil leaks.
    Paddyd[QUOTED] and musicisevil like this.
  2. Nov 26, 2024 at 8:52 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I noticed no difference
    jmneill and Pablo8[QUOTED] like this.
  3. Nov 26, 2024 at 9:18 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    :thumbsup:
    I'd be concerned if I did hear a difference..
  4. Nov 26, 2024 at 11:45 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    That is why he removed his!
    jmneill[QUOTED] likes this.
  5. Nov 26, 2024 at 12:36 PM
    Mt133677
    Mt133677 Well-Known Member
    SoCal
    2020 DCSB TRD OR
    All the things
    interesting, luckily it doesn’t get too cold in SoCal I guess. Never heard of the ice thing
    joba27n[QUOTED] likes this.
  6. Dec 3, 2024 at 3:04 PM
    joba27n
    Nolan
    Alberta
    Some days I envy your comparably temperate climate... stock pcv's even freeze on stock vehicles and cause issues. I believe it was chevy's 1.8L non-turbocharged engine in the cruze/trax that we had to installed a heated pcv system or it would freeze and smoke out the neighbourhood or freeze and blow out every seal on the engine.
  7. Dec 4, 2024 at 5:36 AM
    Paddyd
    Paddyd Active Member
    Pat
    2021 Tacoma, Army Green TRD Off Road
    lift
    I check it once a week same time I check the oil and it has gone through 2 Michigan winters without a hitch as far as freezing goes. That said, mine is located inside bolted to the strut tower about 8" from the engine so even in winter it stays thawed. I think the key is keeping an eye on it and never letting it fill up to the point water backs up in the top of it where the oil separator is. It won't catch the water if it doesn't stay cool enough to condense it though. My point is you can't put one on and not keep your eye on it.
