3rd Gen Plastidip thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KornSanDiego, Jan 26, 2016.
  1. Apr 11, 2018 at 7:41 AM
    #1741
    Wolverine690
    Wolverine690 Well-Known Member
    North Idaho
    2022 Tacoma TRD Sport
    Nice thing with dip is it's easy to redo. You can try touch up and if doesn't look good remove and redo it.
  2. Apr 11, 2018 at 10:13 AM
    #1742
    JHsieh_3
    JHsieh_3 Well-Known Member
    Jeff
    City of Angels
    2018 Tacoma TRD Sport
    Don't redo the whole thing. First, you need to check the spots to see if there are any peels lifting around. If not, you can re-spray it over the spots. If there are peels lifting around the spots, then you'll need to liquify the plastidip again and smooth it out before re-spraying. Here's a great video on what to do in these situations.
    https://www.youtube.com/watch?v=4T0jEvxxTzE
    snickers, tonered and Hextall[QUOTED] like this.
  3. Apr 11, 2018 at 1:09 PM
    #1743
    Tacoma1818
    Tacoma1818 Well-Known Member
    Thank you very much for posting this! I plan to do the exact same thing to my Cement sport. I think the fender flares and front "chin" piece are just TOO MUCH cement. I realized after I bought my truck in Cement that most (if not all) of the pictures of Cement that I had seen were the Pro trim which has painted flares and front piece. I think that makes a HUGE difference in appearance. When I got mine -- in a sport, it was just too much Cement. I priced out replacement (black) flares and front piece and it's just too much for me to spend so I'm going the same route as you. In fact, I 'm going to plastidip the badges as well to get rid of almost all of the chrome that does not play well with Cement (in my opinion).
    A few questions if you don't mind:
    1. You mention that you only used 3 cans. Is that for the flares and the front piece? I've heard others say they used 6 cans and I want to make sure I have enough (but not too many, ha ha).
    2. How many light coats did you do to each piece?
    3. Did you just use the plain old black plastidip (found at the big-box home improvement stores)?
    4. Did you tape/mask all the way up to the fender edge or did you leave a bit of overlap and do some peeling?
    5. What did you use to fill the license plate holes (and did you dip right over those)?
    I've only plastidipped one time in my life -- a chrome piece on the front of my wife's old Saturn Vue. I still have it and the dip is really weathered from being outside for years and years (but still looks fine, really). I don't anticipate that problem on my truck (garage-kept) but I am curious as to the process you used. Honestly, I don't even remember doing it on my wife's car because it was so long ago.
    Thanks again for posting. I'm hoping to get it done SOON since I really like the truck, but not so much all of that Cement paint.
    EDIT: Added one more question ;)
  4. Apr 11, 2018 at 2:21 PM
    #1744
    Vulteiv1
    Vulteiv1 Active Member
    Vince
    2018 trd sport
    I did the fender flares this morning, turned out pretty sweet. I used 3 cans total, 4 coat each. The pictures are from the first coat and fourth coat. I end up breaking 5 clips, so I couldn't attached the two rear flares. Waiting for the clips to be shipped from Amazon.
    IMG_20180410_101957.jpg IMG_20180410_110739.jpg IMG_20180410_133431.jpg IMG_20180411_120333.jpg
  5. Apr 11, 2018 at 4:57 PM
    #1745
    trds_and_tight_lines
    trds_and_tight_lines Member
    2018 Cement TRD Sport 4x4
    ...pending
    Yeah that's 3 cans for all 4 fenders and the nose with 5 complete coats plus 2-3 light coats over the outer facing edges for good measure.
    I had 48in 3M plastic around all the fenders covering the paint (again, overkill but I had it on hand) so I only had to wipe up a couple tiny spots where the tape came loose. 12in paper in the wheel wells and plastic loosely draped around the tires.
    Wherever I could, I worked the masking tape edge under the edge of the flare. There were a couple spots where I gently used a box cutter to create separation as I unmasked.
    Painted right over the license plate holes which are still there, but the black color hides them well. I'm not required to show a front license in NC but I bought the truck in a state that does so unfortunately the holes are here to stay.
    And plain old black plastidip, 5.50 a can! No finish gloss coats in my case.
    Tacoma1818[QUOTED] likes this.
  6. Apr 11, 2018 at 5:14 PM
    #1746
    Auroraboy
    Auroraboy Well-Known Member
    Dave
    London, Ont., Canada
    2017 Quicksand DCSB Off Road
    Husky Weatherbeaters, BAK Revolver X2, front bedrail, Salex console tray, Predator Steps
    $5.50 a can is cheap! Home Depot in Canada wants $23 a can!
    https://www.homedepot.ca/en/home/p.plasti-dip-black-liquid-429-ml.1000139786.html
    arnette64 likes this.
  7. Apr 11, 2018 at 5:23 PM
    #1747
    Pikestaco
    Pikestaco Newbie
    Los Angeles
    2017 Quicksand 4x4 TRD Sport DCLB
    need to learn more about this stuff
  8. Apr 11, 2018 at 5:33 PM
    #1748
    Tacoma1818
    Thank you!! Greatly appreciate the reply!!
  9. Apr 11, 2018 at 5:42 PM
    #1749
    chrisonfire
    chrisonfire Active Member
    Fort Collins, CO
    2017 SR5 DC 4X4
    Has anyone plastidipped their 2017 SR5 snowflakes? Been searching everywhere for a photo before I pull the trigger.
  10. Apr 11, 2018 at 5:58 PM
    #1750
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    I've seen it, and it looked good. Sorry I can't help with a photo
  11. Apr 11, 2018 at 8:49 PM
    #1751
    JHsieh_3
    Jeff
    City of Angels
    Looks great! Thinking of taking on this soon too, but kind of nervous removing the flares because of the clips. I heard you can buy replacement clips at a local auto store for cheap instead of waiting for your Amazon shipment. I might just leave the flares on the truck and plastidip on it, making sure all areas are covered.
    I just finished my side mirrors today on my white sport. I didn't take a photo, but I'll get one tomorrow. Looks great in my opinion!
  12. Apr 11, 2018 at 9:16 PM
    #1752
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    It's to fix their lungs when they accidentally inhale the plastidip.
  13. Apr 12, 2018 at 6:07 AM
    #1753
    Vulteiv1
    Vince
    2018 trd sport
    Thanks, didn't realize that local auto store had them. Toyota wanted $5 for the blue clips and $2 for the red clips. Talk about outrageous.
  14. Apr 12, 2018 at 6:50 AM
    #1754
    tomgru
    tomgru Well-Known Member
    Thomas
    PNW
    2021 TRD Pro
    how hard to pull the flares off?
  15. Apr 12, 2018 at 10:03 AM
    #1755
    Vulteiv1
    Vince
    2018 trd sport
    It was pretty easy, I started at the corners, and slowly work my way up. The first clip will probably break, but just go slow and you'll be fine.
  16. Apr 12, 2018 at 10:22 AM
    #1756
    tomgru
    Thomas
    PNW
    2021 TRD Pro
    what did you use. assume you are just prying from the front? afraid i'll scratch the paint on the body.
  17. Apr 12, 2018 at 11:39 AM
    #1757
    Vulteiv1
    Vince
    2018 trd sport
    Just a plastic pick that I picked up at harbor freight.15235583620027746625913308623903.jpg
    tomgru likes this.
  18. Apr 12, 2018 at 3:51 PM
    #1758
    JHsieh_3
    Jeff
    City of Angels
    Dipped my side mirror covers yesterday. Started to get windy in my area, so before each coat, I had wet sand the dust and specs that got stuck, which made the whole process longer than it should've been. Anyways, I think it gives the white a nice contrast. Looking forward to doing my flares next!
  19. Apr 12, 2018 at 4:03 PM
    #1759
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    I think that color is closer match to cement?
  20. Apr 13, 2018 at 11:03 AM
    #1760
    Taco Caliente
    Taco Caliente WTF?
    San Antonio, TX
    2019 TRD OR DCSB
    I want to do my side mirrors as well.
    Did you derp the side mirror covers in place, or did you remove them first?
